Old 01-08-2009, 10:52 PM   #31
gottdeskrieges
gottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enoughgottdeskrieges will become famous soon enough
Send a message via AIM to gottdeskrieges
Sounds good and all. But, on the 4g63 I 've seen over 600awhp on stock bottom end. I was on low 400's with my setup. Always intresting to see people doing something different and finding another alternative. Makes it easier for when you cant find something just get it from another car and work with that haha. Good Luck bro and hope everything works out for ya.
gottdeskrieges is offline   Reply With Quote
Old 01-09-2009, 12:21 AM   #32
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
If i were going to sleeve the block i would just do an entire bulletproof build with forged rods and pistons, the objective here is to do this as cost effective as possible.
timtiminy is offline   Reply With Quote
Old 01-09-2009, 11:08 PM   #33
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
I am not the God of Z32 pistons... I have just been looking into doing this for a long time and I rarely hear any real info about it.
I will be doing this soon... The only thing I am worried about right now is selling my PE headgasket (87mm) and getting a new PE (88mm) one.
Z32 stock Pistons are 87mm... most aftermarket ones only start at 87.5mm... this is my logical choice of size anyway because finding a 89mm headgasket is just impossable... or not something I trust to use.
If your going to do piston swap on the SR20 the RNN15 GTiR pistons are great and cheep... if your planning to build it, go forged... If you planning to Bore, but keep your stock crank , go with Z32 87mm pistons.
The only real issue is finding them in sets of 4.
The local Machine shop that is highly trusted by many engine builders in this area... Said he doesn't want to sleeve the SR because its aluminum and he would have to re-align the mains... I dont think going over 1mm is going to be that bad on a stock wall, but that is my limit!
-Drew
MadScientist is offline   Reply With Quote
Old 01-10-2009, 12:37 AM   #34
slider2828
slider2828's Avatar
I have forged from JE and they have a 86mm bore for sr's
Turn and Burn!
Old 01-10-2009, 05:24 PM   #35
timtiminy
timtiminy's Avatar
okay so is it recommended to go .5mm bigger on your head gasket when you overbore? Like if i did the stock Z32 pistons at 87mm should i go with a 87mm head gasket or a 87.5mm?
Old 01-10-2009, 10:28 PM   #36
MadScientist
^^^ Correct
This is from Power Enterprise website.
How to select right size of gasket:
Standard of Gasket bore vs. piston size
Piston OD + 1.0mm to 2.0mm. The most of car manufacture design the gasket size to be 1.5mm to 2.0mm larger than the piston OD
Caution:
Do not overlap the tip of gasket and champher area
(See the picture)
Compression Ratio Changes by the thickness:
Example: 86mm stroke engine with 9:1 compression ratio can be reduced to 8.6:1 by adding the head gasket thickness, approx. 0.56mm.
Use 87mm Gasket for 86mm piston and 88mm for 87mm piston.
Major Distributor for the 91mm gasket: MAZWORXl 407-281-1223 (Mark)
-Drew
Old 01-10-2009, 10:45 PM   #37
timtiminy
timtiminy's Avatar
Thanks for that info. wasnt sure about that, i figured it worked that way. Are there certain gasket manufactures that list their sized based on the cylinder bore? for instance their actual gasket diameter is 87mm but is listed as 86mm?
Old 01-10-2009, 11:39 PM   #38
MadScientist
I prefer Power Enterprise because they are the best... look at thier site... their HG is like no other... I have a 87mm one and I ordered a rebuild kit... the stock HG is so nasty compaired to PE... I have seen Tomei/HKS/etc... they are good but... PE is god sauce... holds 1400hp and something retarded on boost presure.
MSRP is $230... call Kure.
-Drew
Old 01-11-2009, 12:16 AM   #39
s13envy
s13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nice
Send a message via ICQ to s13envy Send a message via AIM to s13envy Send a message via MSN to s13envy Send a message via Yahoo to s13envy
I believe mazworx recommends Apexi HG's. Said they'd hold something like 60lbs of boost or so....Just over $200
s13envy is offline   Reply With Quote
Old 01-11-2009, 11:40 AM   #40
timtiminy
timtiminy's Avatar
Ive noticed some gasket manufactures make a 86mm gasket for the sr20det so thats why i was wondering if it is just listed as 86mm for the bore of the motor but the actual diameter of the gasket is 87mm. Anyhow i have heard that Power Enterprise Gaskets are one of the best and Apexi uses a similar design so they are comparable. Another gasket i am considering is cosworth. I have heard mixed reviews on cometic so not too sure about that, I have heard that if your block and head are freshly decked you wont have any problems but even though i will have a fresh surface on both the block and head i dont want to have to tear the motor apart again just to change the HG and have to spend money a second time.
Old 01-17-2009, 02:14 PM   #41
MadScientist
OK , so I need a Torque Plate... what is the deal with finding one.
-Drew
Old 01-17-2009, 03:20 PM   #42
timtiminy
timtiminy's Avatar
High Performance Engine Builder Tooling and Harmonic Dampers: BHJ Products, +1 (510)797-6780 <-- They sell a torque plate for the sr20
Old 01-17-2009, 05:22 PM   #43
MadScientist
They sell for the SR20DE... its close to a S13 SR20DET but its far far away from a S14 SR20.
-Drew
Old 01-21-2009, 12:13 PM   #44
timtiminy
timtiminy's Avatar
I knew that the S13 SR and SER SR have the same head bolt pattern but I wasnt sure about the S14... They could possibly make you a custom one. Seems like they are capable. if not have emachineshop.com make you one.
Old 01-21-2009, 12:54 PM   #45
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
I can bore and hone your block, PM me
Hashiriya415 is offline   Reply With Quote
Old 01-21-2009, 02:02 PM   #46
timtiminy
timtiminy's Avatar
Hashiriya415: Do you use a torque plate when you bore?
Old 01-25-2009, 02:21 AM   #47
SleeperTT
SleeperTT is an unknown quantity at this point
Send a message via MSN to SleeperTT Send a message via Yahoo to SleeperTT
Hey I was wandering some things... I had a built vg30dett. in my Z. well it took a dump and now I'm looking at a s13 to play with. The plan is a S15 Black top. Well I just want that cause of the 6 speed tranny but any ways. I have 6 cp pistons .002 over stock bore..out of my TT motor. I'm intrigued in this conversation cause i already have three eagle rods and the cp pistons. Are the rods the same, and the .002 over stock pistons, would that be a problem with boring the stock sr block to fit the pistons. I'm not familiar with the limits as far as bore for the SR.
SleeperTT is offline   Reply With Quote
Old 01-25-2009, 12:17 PM   #48
TheRealNighthog
TheRealNighthog is an unknown quantity at this point
The problems with the VG pistons are two things. Number one, they are heavy, much heavier than the stock SR pistons by quite a bit, its obvious that these would not be well suited for high rev applications as they would put a lot of stress on the wrist pins. Secondly they use thick rings which does not help out with high RPM sealing. The pistons I am running were designed to use the thin low tension rings from the 2001-2002 Sentra SE. These are much better for high RPM sealing as I am planning to turn 9.5K with my build.
TheRealNighthog is offline   Reply With Quote
Old 01-25-2009, 02:31 PM   #49
MadScientist
Stock v:s Stock - yes the Z32 piston is heavier.
Aftermarket - weight is not an issue. rings are better.
IMO... I wouldn't put stock pistons in anything I have went through the trouble of Boring/ Building.
SleeperTT -The pistons will work but you will neet to bore the SR... you dont need a S15 engine... buy an S14 SR20 and the S15 Tranny, Actually you have a VG tranny... get a Maxiworx kit. The Rods, I doubt will fit the crank, or have the correct length.
-Drew
Old 01-26-2009, 12:03 PM   #50
timtiminy
timtiminy's Avatar
This is kind of what I am struggling with, since I am overboring I am spending quite a bit of money just on machining costs and would like to save as much money as I can, which is where the idea to use the Z32 pistons came into play. I would like to know the actual weight difference between stock SR pistons and stock VG pistons. I would imagine since the VG piston is 1mm larger in diameter even if nothing else was different it would make a small difference in weight. I would just like to know if it is of any significance. The ring sealing issue that was brought up seems like a bigger issue than the weight, but when I was reading about the SR build with VG pistons in Sportcompactcar they did not mention any adverse effects in this area.
Old 01-26-2009, 05:01 PM   #51
MadScientist
SR20DET
Stock
Bore: 3.386, 86mm
Stroke: 3.386
Rod Length: 5.366
Head cc: 46.5
Gasket: .036
Deck: .000
ARIAS Pistons
Bore - 3.406 / 86.5mm
Comp. - 1.260
Dome - (-15)
Compression RatioComp. - 8.5
Gram - 334
VG30DETT
Stock
Bore: 3.425, 87mm
Stroke: 3.270
Rod Length: 6.071
Head cc: 49.5
Gasket: .040
Deck: .000
ARIAS Pistons
Bore - 3.445 / 87.50
Comp. - 1.255
Dome - (-6)
Compression RatioComp. - 9.1
Gram - 360
More tech info to feed on!!
-Drew
Old 04-16-2009, 01:17 AM   #52
timtiminy
timtiminy's Avatar
talked to a guy that did this, seems to be like he had good luck and made over 500whp
Old 04-17-2009, 12:01 PM   #53
timtiminy
timtiminy's Avatar
I have heard that boring without a torque plate is and isnt a good idea... im thinking it would be better with the torque plate, but i cant find anyone in socal that bores with a torque plate for the SR20, JWT used to but they no longer offer machining services, anyone know of anyone else?
Old 04-17-2009, 02:49 PM   #54
GSXRJJordan
GSXRJJordan's Avatar
Overall, it's probably not THAT big a deal for an SR... but obviously if you had a choice, you would go with the torque plate over nothing.
There's still a few shops that have a torque plate for the SR20 - of course, I see the threads in passing, and never bookmark shit, because I've never needed it done. The thread I'm thinking of had a link to a torque plate manufacturer, and it listed all the motors that used the same plate - there were a few that used the same plate.
I'd start with known SR20 builders, like Garagewerks in Palmdale, and then ask some of the more serious shops (Boso, SP Eng, etc) who they use, and get referrals to machine shops - eventually you'll find one that's got a torque plate for an SR!
Old 04-18-2009, 08:56 PM   #55
timtiminy
timtiminy's Avatar
yeah... I am just wondering the long term effects if i dont use a torque plate to bore.
