Old 09-22-2008, 01:50 AM   #1
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
Z32 turbo pistons in SR20DET
hey guys i was looking around and found that some FWD SR guys are putting Z32 300zx turbo pistons in there DE motors as a cheap alternative to expensive forged overbore low compression pistons. The info i have on them so far is that they are 87mm and 8.5:1 compression ratio and fit the oem rods. I have yet to hear of anyone using these in their rwd SR20DET, I may try it as i have to bore out my block and need to save money somewhere. Plus I wont be going over 350hp so I think these will be a good option. If anyone has any info on this or has done it before, please post. I am really interested in this option rather than spending $500 on forged pistons.
timtiminy is offline   Reply With Quote
Old 09-22-2008, 02:25 AM   #2
GSXRJJordan
GSXRJJordan's Avatar
Originally Posted by timtiminy View Post
... Plus I wont be going over 350hp so I think these will be a good option.
Earth to tim... EARTH TO TIM!
You don't need aftermarket pistons for 350hp... just a good metal head gasket, a bigger turbo, and the associated fuel mods.
BTW, stock SR pistons arent bad. I would imagine the only advantage to the VG pistons would be 1mm overbore, but I'm not all that comfortable boring the already-thin-walled SR anyhow.
Old 09-22-2008, 02:29 AM   #3
timtiminy
timtiminy's Avatar
only reason why i am even considering this option is because i have to overbore.... otherwise i would use oem sr pistons..
Old 09-22-2008, 05:21 AM   #4
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
you can buy forged mahle SR pistons for $350 with rings... how much cheaper are the z32's...
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 09-22-2008, 11:33 AM   #5
Ali 556
Ali 556 is a well-known jackass
Or You Can Get Some 2JZ-GTE Pistons...they Are 86mm And 86.5 And 87....If they Fit On The SR Rods ( I don't Think So)
And On Supra's They Made Up To 1017Whp On STOCK Engine Then the rod bolt's gave up....
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 09-22-2008, 11:35 AM   #6
trsilvias13
isn't the stock sr20det 8.5:1 compress stock?
trsilvias13 is offline   Reply With Quote
Old 09-22-2008, 11:39 AM   #7
GSXRJJordan
Around there, yes.... but read his earlier post:
Interesting. So you've got scoring and must overbore? I'd say it's a decent plan... I'm guessing a set of 4 Z32 pistons is less than $100?
Old 09-22-2008, 02:02 PM   #8
timtiminy
timtiminy's Avatar
about that brand new... looking at getting some used ones for free though...
Old 09-22-2008, 09:04 PM   #9
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why the fuck would you wanna use some used one. You already found a cheap alternate, atleast slap some new ones in there....
CLICK HERE!!!
Old 09-24-2008, 02:32 AM   #10
timtiminy
timtiminy's Avatar
new ones won't be any different than used ones if there is hardly any wear on the used ones and i would put new rings on them. its not like pistons wear out or get weaker over time...
Old 09-24-2008, 06:34 AM   #11
TheWolf
TheWolf's Avatar
this is why 240's will become the new dsm...
Eye on the Prize
Old 09-24-2008, 07:37 AM   #12
Def
Actually they do. It's called metal fatigue, and aluminum constantly fatigues and never reaches and infinite fatigue strength like steel.
Whether it will fail as a result, I doubt it. But to save $100 and risk the PITA of replacing pistons or scrapping a block - why would you even think about tossing in used OEM pistons?
Old 09-24-2008, 03:42 PM   #13
fliprayzin240sx
Personally, use the Z32 pistons and get better rods/bearings instead of the stockers. Im not a big fan of OEM rods...
CLICK HERE!!!
Old 10-25-2008, 08:20 PM   #14
timtiminy
timtiminy's Avatar
i have heard that Sr Rods are actually a strong point to the motor... Check this out... 4G63 Turbo Rebuild with VG30DETT Pistons 87mm - Zerotohundred.com - The Automotive Lifestyle Network I guess they rebuilt a 4G63 with the VG30DETT pistons and are pushing 600hp.. oh and thats with used VG turbo pistons and stock rods.
Old 01-05-2009, 07:53 AM   #15
timtiminy
timtiminy's Avatar
Alright so i sourced a set of low mileage used VG30DETT pistons, Dirt cheap and in great condition. I also found a guy who has a SR torque plate that is willing to let me use it to get my block overbored the 1mm needed. Machining cost are going to be the most expensive thing but i think after everthing is said and done I will have saved hundreds of dollars from going aftermarket pistons and only have spent a little bit more than if i would've had a good block to have started out with and was just doing a OEM rebuild. So basically I will have an 1mm overbore OEM rebuild when everything is said and done.
Old 01-05-2009, 08:01 AM   #16
Teambadrun
Teambadrun's Avatar
Teambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to allTeambadrun is a name known to all
Just make sure the pin height , and amount of CC in the dish...
you need around -12cc of dish on a stock SR or there abouts...
VG pistons in a SR sounds good if its that cheap thou.. go for it
Teambadrun is offline   Reply With Quote
Old 01-05-2009, 06:00 PM   #17
timtiminy
timtiminy's Avatar
Its been done before i know that alot of fwd na SR guys use the na VG pistons to bump compression up. The VG turbo pistons are even more stout then the SR turbo pistons too. I will take pictures of everything as the process goes along.
Old 01-05-2009, 06:12 PM   #18
alexander500
alexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond reputealexander500 has a reputation beyond repute
Hold it, hold it, hold it
This sounded like a good idea until it shit all over itself right here.
I genuinely hope this works out, but I can tell you from experience that it is cheaper to do it right.
alexander500 is offline   Reply With Quote
Old 01-05-2009, 06:18 PM   #19
MadScientist
MadScientist's Avatar
MadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really niceMadScientist is just really nice
HKS Driver (NOB) Nobuteru Taniguchi uses Z32 pistons in his S14 SR20.
I have been thinking of this and keeping it on the DL... This is one of those rare things you hear little about.
-Drew
MadScientist is offline   Reply With Quote
Old 01-06-2009, 12:21 AM   #20
GSXRJJordan
-Drew
I didn't know that! Wow. Does that mean he's running HKS forged Z32 pistons, or OEM? Moarrr infoooooz pllzzzzzz.
Old 01-06-2009, 07:55 AM   #21
MadScientist
He is using stock Z32 pistons... not the HKS.
He also suggest that the Z32 pistons creates a 2.1 option... if you look at the pistons (SR vs Z32) the Z has a shorter profile.
This is a Z32 Piston from Wiseco (88mm)
This is a SR20DET Piston from Tomei (87mm)
-Drew
Old 01-06-2009, 10:51 AM   #22
slider2828
slider2828's Avatar
How does this affect tuning and the overall performance? This is interesting....
Turn and Burn!
Old 01-07-2009, 09:55 PM   #23
timtiminy
timtiminy's Avatar
Alexander500: I dont see why its such a bad idea to reuse used pistons? plenty of rebuilds are done reusing original oem pistons. I will be using new rings. The pistons dont necessarily wear out...The only thing to worry about is metal fatigue.
Old 01-07-2009, 10:00 PM   #24
timtiminy
timtiminy's Avatar
MadScientist: Please tell us more about this, I am quite interested.
Old 01-07-2009, 10:09 PM   #25
s13envy
s13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nices13envy is just really nice
Send a message via ICQ to s13envy Send a message via AIM to s13envy Send a message via MSN to s13envy Send a message via Yahoo to s13envy
i think what everyone is getting at is why would you not replace something critical to your motor like pistons, especially when they are so cheap to replace???? to me its a no brainer whether or not to replace the pistons in this situation.
s13envy is offline   Reply With Quote
Old 01-07-2009, 10:14 PM   #26
!Zar!
!Zar!'s Avatar
I never have heard anything about this before.
Old 01-07-2009, 10:36 PM   #27
timtiminy
timtiminy's Avatar
I dont see it as such a big deal as most people are making it out to be to use new pistons rather than good condition used ones. I think that if i agreed that it was such an important thing to use new ones then i would also want to get new rods, which see about the same abuse as pistons do in my mind. I have yet to get pistons so my mind isn't completely made up in whether or not i am going to get new pistons or just use used ones.
Old 01-08-2009, 08:44 AM   #28
slider2828
slider2828's Avatar
I have actually heard this in other cars. Like 2zz motors used like honda pistons or something like that.... I think the esprit's mrs does that....
Turn and Burn!
Old 01-08-2009, 10:55 AM   #29
timtiminy
timtiminy's Avatar
yeah i have heard of D series honda motors using suzuki grand vitara pistons which lower compression and are stronger, they use them when the turbo the D series motors and have been able to get like 400hp with no problems. Thats what got me looking into alternative pistons for the SR motor, especially since i have to overbore my block and didnt want to spend and arm an a leg on forged slugs since im not planning on making huge power.
Old 01-08-2009, 08:45 PM   #30
slider2828
slider2828's Avatar
z32's would rock... Try it! But I would spend a little more and sleeve it though.... Just for piece of mind.
Turn and Burn!
