Old 01-14-2009, 06:10 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Strange click
Um... I just noticed a strange clicking sound starting on my car. It sounds like its in the steering/suspension/wheel system on my S14. Its not loud, and its not a constant click. Doesn't change with engine speed, but changes with speed. Sometimes I hear it while going straight, sometimes I don't. Also, it may just be in my mind, but it clicked more consistantly while turning right. I haven't really made any left hand turns since I first heard the sound.
But as before, there's no play in my rim that would suggest a bad bearing... but I think the whining at 40mph, whining when decelerating at about 20mph, and this click might all be pointing to a wheel bearing. Do you guys agree, or have any other ideas?
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 01-14-2009, 07:27 PM   #2
Sileighty_85
Sileighty_85's Avatar
Ckeck for bad wheel bearing, lift off ground and and check for play in the hub.
Any rocks in your tires? Zip Ties Hitting the tires?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 01-14-2009, 07:33 PM   #3
LA_phantom_240
My car is unusual for Zilvia; it isn't yet held together with zip ties, lol. I thought maybe a rock... but it would have to be a big rock, cause I dunno if you've seen the tread pattern on the BFG G-Force KDWs, but yeah a rock isn't likely. I did, however, notice what looked like a nail embedded in my tread too far for me to get with pliers. Doesn't leak air, so I didn't fuck with it.
Hmm....
Old 01-14-2009, 08:34 PM   #4
Mathetai
Mathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to allMathetai is a name known to all
LOL thats awesome!
Mathetai is offline   Reply With Quote
Old 01-14-2009, 09:24 PM   #5
LA_phantom_240
I'm thinking the pillowball upper mounts up front. Any easy way to check?
Old 01-14-2009, 09:36 PM   #6
Sileighty_85
torn boots and sloppy ball joints
後輪駆動車1番
1986 SR86 - 200ish
Old 01-14-2009, 09:43 PM   #7
LA_phantom_240
No no no.... I'm talking bout the pillowball mounts on the top of my coilovers lol.
Old 01-14-2009, 09:58 PM   #8
Sileighty_85
ohhhhhh.....
Kinda same thing look for "play" everything should be "snug"
後輪駆動車1番
1986 SR86 - 200ish
Old 01-14-2009, 10:24 PM   #9
LA_phantom_240
Hmm... i got one last thing to check out if that fails to yield info.
Old 01-14-2009, 10:51 PM   #10
bbejj123
bbejj123's Avatar
bbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura aboutbbejj123 has a spectacular aura about
baller!
let us know if it yields any results =)
bbejj123 is offline   Reply With Quote
Old 01-20-2009, 11:37 AM   #11
LA_phantom_240
None of my ideas on what could be wrong produced fruitful information. My noise hasn't gotten worse, but it hasn't gone away.
I do, however, have some new info now that I have a quiet exhaust.
My clicking seems to be while cruising or accelerating slowly, or decelerating slowly. When I accelerate moderate to WOT, I don't hear it. When I apply the brakes, I don't hear it.
Therefore, I think I could possibly be on the verge of needing to replace my center carrier or have a bad U-Joint in my driveshaft. If this is the case, I'm going 1 piece aluminum.
Old 01-20-2009, 11:41 AM   #12
murda-c
murda-c's Avatar
I thought the topic title was strange dick.
I was thinking a relay or circuit breaker, but i can't think of any where you wouldn't notice the electrical problems to go along with it.
Old 01-20-2009, 11:45 AM   #13
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
My car does the same thing, I think you're right about the driveshaft... it's either that or the axles
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 01-20-2009, 04:17 PM   #14
LA_phantom_240
I was thinking axles maybe.
Any ideas how I could troubleshoot the axles and/or driveshaft without having to remove them?
Old 01-21-2009, 06:37 PM   #15
LA_phantom_240
Jacked the front up last night, and I don't get any clicks with the wheel rotating. I do, however, have a small bit of play in my driver's side tie rod end. At least, that's what I think. I get about 1/16th of an inch or so left to right play, and it does make a small thud type sound, but not like what I hear rolling. Also, I wouldn't think a worn tie rod would click in relation to wheel speed, but rather when I hit bumps.
