Old 04-07-2009, 07:17 AM   #1
xpinoyxmk
xpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura aboutxpinoyxmk has a spectacular aura about
Exhaust hanging too low?
I just installed my reinhard exhaust yesterday and its hanging lower than the diff. So did i install it wrong. Everything is in the place where the original exhuast was. So i didnt misplace anything.
So do i have to modify the hangers so that it will sit flush under the car?
Has anyone else had this problem before?
xpinoyxmk is offline   Reply With Quote
Old 04-07-2009, 08:06 AM   #2
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
i had this problem with my hks hipower, all i did was took a few worm clamps aka hose clamps and put them around the rubber hanger bushings and tightened them down, which raised the exhaust up a little bit. I'd give that a try before you actually commit to cutting up the hangers and modifying them.
Slip Gypsies Blog
not sure if you realize this
Old 04-07-2009, 08:27 AM   #3
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
^ I did the same with my exhaust. The most simple fix.
Maiku240sxS14 is offline   Reply With Quote
Old 04-07-2009, 08:36 AM   #4
S14DB
AFC #1
S14DB's Avatar
I was amazed at how much better my exhaust fit when I replaced the bushings. Not only did it raise it up. It also centered it better in the tunnel.
Old 04-07-2009, 09:58 AM   #5
xpinoyxmk
Im going to replace the rubber bushings. They are stretched out so we'll sell if that works
Old 04-07-2009, 11:25 AM   #6
240nut
240nut is an unknown quantity at this point
i replaced my bushings and it raised my exhaust a lot.
240nut is offline   Reply With Quote
Old 04-07-2009, 11:27 AM   #7
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
I got poly Circuit Sports one for my Nur Spec; cheap and worth the purchase. No more bouncy exhaust and pulled the system up some
Clever, never even thought of that.......
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 04-07-2009, 06:39 PM   #8
xpinoyxmk
Replaced the bushings and it raised it about a half a inch, maybe a inch. Still too low though. Looks like i will have to get the hangers cut shorter. Ill post some pics of it tmrrw.
Old 04-07-2009, 06:51 PM   #9
slothonaleash
slothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond reputeslothonaleash has a reputation beyond repute
Zip tie the exhaust up to the underbody of the car
My buddy club spec II is literally touching the gas tank and sway bar on my s13--maximum ground clearance, but you don't have to tell anybody you ziptied your exhaust to your car
slothonaleash is offline   Reply With Quote
Old 04-07-2009, 06:52 PM   #10
J40sx
J40sx's Avatar
J40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choicesJ40sx has made poor choices
just wondering if they hit your toe hook
that making it sit so low, if so saw it off
dying is only living, dying to live
J40sx is offline   Reply With Quote
Old 04-07-2009, 08:22 PM   #11
Sileighty_85
Sileighty_85's Avatar
I had my exhaust drag for about 100 mile when driving back from mineral wells TX (exhaust bolts fell out and had to be at work in 5 hours)
pretty much drug it home untill i had to yank it off and make it fit in the hatch with 10 other tires lol....that was a bad day
so just took a 3 in pipe cut it in half conformed it to the flat spot and welded it on
Still holden up and probably will look into replacing the hanger bushings too
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 04-09-2009, 10:49 AM   #12
xpinoyxmk
Exhaust is on now. Still pretty low to the ground but at least not scraping it
Old 04-09-2009, 11:07 AM   #13
ericcastro
ericcastro's Avatar
I hope to fucking god your joking!
Exhaust right up against gas tank?
Plastic Zipties holding a hot ass exhaust pipe?
Originally Posted by xpinoyxmk View Post
Pretty normal dude.
Your car is lowered.
Deal with it.
Stop buying expensive exhaust.
Just get mufflers and have them change the actual pipe as it gets worn through.
Thats how i do it.
Bout every 6-10 months.
Its just part of the game.
Old 04-09-2009, 11:18 AM   #14
Ceepo
Ceepo's Avatar
just add metel to the parts that scrape so it scraps off and not the exhaust... just a thought...
Old 04-10-2009, 10:05 AM   #15
xpinoyxmk
Fixed one of the hangers and got some bigger wheels. Its lifted on the ground a good bit now.
Old 04-10-2009, 10:37 AM   #16
toointoxicated62
toointoxicated62 is an unknown quantity at this point
theres metal zip ties.. not that i would zip tie my exhaust to my gas tank lol
toointoxicated62 is offline   Reply With Quote
Old 04-10-2009, 11:29 AM   #17
dOMEmE
dOMEmE's Avatar
dOMEmE is an unknown quantity at this point
lol....i was picturing plastic ties....
dOMEmE is offline   Reply With Quote
Old 04-12-2009, 03:54 PM   #18
slothonaleash
You can't argue with results...
I'm full low on stance gr+ and I don't scrape anywhere except my driveway and other terrible places.
The zip ties stay on...heat of plastic melting is too high.
The heat of the pipe out by the gas tank has been cooled greatly to the point where gasoline will not ignite upon touching it.
My gas tank doesn't leak so there's no danger of igniting the gasoline, and if my exhaust were dragging low, a leaking gas tank would be a danger anyways.
It's been like this for almost 6 months now, and the only problems I've had were zip ties breaking... and all you gotta do is replace them.
Now I understand this kind of driveway quickfix isn't for everybody, all I'm saying is that I'm perfectly happy with hugging my exhaust up to the underbody of my car with black plastic zip ties.
Old 04-12-2009, 04:15 PM   #19
Sileighty_85
I beg to differ This happend to a guy i knew in Okianwa at Nago
his rear end ran up on the mountain side a little bit when drifting and exhaust hanger punctured his gas tank then the exhaust ignighted the fuel causing this
Luckly he and the passenger made it out in time
後輪駆動車1番
1986 SR86 - 200ish
Old 07-20-2012, 05:27 PM   #20
Dany
Dany's Avatar
Dany is an unknown quantity at this point
im having problems with my exhaust being low also :l and damm this thread is old lol
Dany is offline   Reply With Quote
