Old 05-13-2009, 12:25 PM   #1
s13.dark1
s13.dark1's Avatar
s13.dark1 is making a name for him/her selfs13.dark1 is making a name for him/her self
Subframe bushing removel
so how did you remove stock bushings?
ive seen fire used has anyone taked them off differently.
you better cut, weld, and paste that sh!t
http://zilvia.net/f/sale-items/24340...kets-more.html
s13.dark1 is offline   Reply With Quote
Old 05-13-2009, 12:31 PM   #2
aznpoopy
aznpoopy's Avatar
burn it out as much as you can, then cut through the remaining metal collar with a sawzall. be careful not to notch the subframe.
once the metal collar has been cut through, wedge something into the cut to peel the first edge away from the surface. then jam a screw driver (and eventually a pry bar) in there, and go around and pry until you have a good portion of it loose. then hit it with a hammer and it should pop out.
Old 05-13-2009, 12:34 PM   #3
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
torch the bushing till its nice and hot.
remove the center sleeve with vice-grips.
CAREFULLY hacksaw the casing. be sure not to cut into the subframe itself.
then use a flat head and a hammer to pound/pry out the bushing.
once the casing is cut, it will collapse and the bushing will pop right out.
it can be done in an hour or two, if you know what you're doing. BUT expect to spend about half an hour on the first one if you've never removed bushings before.
you can use a press, but you can easily deform the subframe.
BTW, did you buy some PSM solid sf risers? they are AWESOMETOWN.
you will feel your diff in your ass
Marcus is offline   Reply With Quote
Old 05-13-2009, 12:44 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
i "taked" them off with fire. then an air chisel for the outer.
Old 05-13-2009, 01:36 PM   #5
s13.dark1
s13.dark1's Avatar
fire plus some cutting tool seems to work best im actully doing it right now, torch saw long flat tip as the pry bar it seems to be going well.
ima going to install cuirct sports alum spacers any feed back on them while we r on the subject?
Old 05-13-2009, 01:40 PM   #6
aznpoopy
aznpoopy's Avatar
wait. what?
aluminum spacers supplement stock bushings. if you want to use spacers you should retain the stock bushings.
Old 05-13-2009, 02:11 PM   #7
jholman05
jholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nicejholman05 is just really nice
Send a message via AIM to jholman05
I did it just like the first two guys who replied did. Took a while but they all came out after a while. I used a delrin subframing bushing that I'm having a hard time finding right now, I think they were around $60 for all four. I love them, after replacing those, all the rest of the bushings with a prothane kit, and having new inner/outer tie rods and front lover ball joints the car handles better than what I would expect from the factory.
jholman05 is offline   Reply With Quote
Old 05-13-2009, 02:19 PM   #8
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
Uh O!! Your supposed to keep your stock bushings if you use spacers, you remove them if your using solid bushings which are different!!
essforteen is offline   Reply With Quote
Old 05-13-2009, 03:12 PM   #9
s13.dark1
s13.dark1's Avatar
the bushings where bad so i was just going to put new bushings in along with the spacers or should i just put in solid ones
Old 05-13-2009, 03:41 PM   #10
JeremyR
JeremyR's Avatar
JeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the roughJeremyR is a jewel in the rough
Send a message via AIM to JeremyR
just get the PBM subframe risers and call it a day.
Originally Posted by slow40sx View Post
drive your car into the garbage and leave it there
JeremyR is offline   Reply With Quote
Old 05-13-2009, 04:01 PM   #11
aznpoopy
aznpoopy's Avatar
if you put in new bushings, you don't need the spacers. it's one or the other.
Old 05-13-2009, 04:48 PM   #12
Marcus
Marcus's Avatar
Trader Rating: (18)
ohh shit. i think you messed up.
just buy these from them do this and be done.
cchhyyeaaaah baby. Blang blang
Old 05-13-2009, 04:58 PM   #13
Wake
Wake's Avatar
daaamnn epileptic much? paint looks clean but thats a damn fuzzy pic. kinda makes me wanna repaint mine tho
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 05-13-2009, 05:04 PM   #14
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Where you get the solid bushings?
OP failed, do not get spacers, even with new OEM because the spacers will just rip the new ones to shreds.
Easy way to remove OEM bushings is heat up area around bushing, along with torching the fcuk out the the rubber, take a nice long hard candle and shove it in and around the metal casing area to penetrate, to further lube the removal of the casings.
If the OEM bushings are still intact, and youve broken the bond with the subframe, you can use a monster cock hammer and a massive socket and pound it out. Use enough lube i.e pbblaster+candle wax and you should beble to pipe that bitch down hard enough to slide the bushing right out.
Bigsyke is offline   Reply With Quote
Old 05-13-2009, 05:55 PM   #15
aznpoopy
aznpoopy's Avatar
that looks pretty awesome!
i just por-15'd the subframe i'm going to install. now i'm thinking i should paint it.
Old 05-13-2009, 06:00 PM   #16
Bumnah
Bumnah's Avatar
Bumnah is an unknown quantity at this point
Send a message via AIM to Bumnah
Burn the bushings out and cut like everyone says. It works pretty well, and is relatively painless.
I had mine sand blasted and powder coated lime green. Link to pics in my sig.
Bumnah is offline   Reply With Quote
Old 05-13-2009, 07:02 PM   #17
Marcus
Marcus's Avatar
Trader Rating: (18)
LOL my bad, i was actually falling while i took that pic. hah
OP:::hope this was of help. what kind of bushings did you buy to replace the old ones?
iirc, the sf spacers only work with oe bushings right?
i got the solid subframe risers from POWEREDBYMAX. they actually push up your subframe and help correct suspension geometry. RUSTOLEUM FTW lol
Old 05-13-2009, 08:18 PM   #18
johngriff
johngriff's Avatar
Man, replacing the subframe bushings is such a mess, you can do it quick but it really is allot of labor.
and I hate loosing goose rear ends too...
[email protected]
Old 05-13-2009, 08:30 PM   #19
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
I just did this and i removed the stock ones using a torch, but i didn't melt the shit out, you heat up the outside of the subframe so you make the metal hot enough you can loosen the bond between the rubber bushing and metal.
it does take time and patience, but yeah, of course it's gonna take time if you want to do it right and feel accomplished.
too me 7 hours.
so just get a regular torch from home depot.
drop the subframe.
just heat up the outside as good as you can with the torch to loosen the bond. just jimmy a screw driver in there and pick it out, again each one takes around an hour.
then get a drill and a wire wheel to buff the inside to remove all the rubber that is still stuck.
LET ME MAKE THIS VERY CLEAR, IF YOU USE THE ENERGY SUSPENSION POLY BUSHING REPLACEMENTS (NOT INSERTS) YOU MUST NOT DAMAGE THE OUTER SHELL OF THE BUSHING IF YOU HAVE AN S13. I REPEAT, DO NOT BE A DOOSH AND DAMAGE THE OUTER SHELL OF THE ORIGINAL BUSHING IF YOU HAVE AN S13.
if anyone has a question about this please feel free to PM me, i went through the process recently and it was actually very painless because i had the proper tools and patience.
oh yeah, my rear is friggin TIGHT now.
clark is offline   Reply With Quote
Old 05-13-2009, 08:39 PM   #20
s13tilldeath*
s13tilldeath*'s Avatar
s13tilldeath* is an unknown quantity at this point
Torch the bitches.
dont use spacers and new bushings. If you want a stiff ride get aluminum bushings ftw.
"Im a god mother fucker and its judgement day!"
s13tilldeath* is offline   Reply With Quote
Old 05-13-2009, 08:55 PM   #21
johngriff
johngriff's Avatar
7 Hours!
Holy hell, thats a long time..
[email protected]
Old 05-13-2009, 09:27 PM   #22
Marcus
Marcus's Avatar
Trader Rating: (18)
Originally Posted by johngriff View Post
7 Hours!
hell yea thats long. may have been his first time.
got mine out in about an hour.
you dont need to clean the casing of the bushing itself, just enough to get a blade in to cut it.
Old 05-13-2009, 09:38 PM   #23
jamg
jamg is an unknown quantity at this point
at my local shop, they charge 500 for a full bushing swap.
worth it?
jamg is offline   Reply With Quote
Old 05-13-2009, 09:46 PM   #24
projectRDM
projectRDM's Avatar
Originally Posted by clark View Post
LET ME MAKE THIS VERY CLEAR, IF YOU USE THE ENERGY SUSPENSION POLY BUSHING REPLACEMENTS (NOT INSERTS) YOU MUST NOT DAMAGE THE OUTER SHELL OF THE BUSHING IF YOU HAVE AN S13. I REPEAT, DO NOT BE A DOUCHE AND DAMAGE THE OUTER SHELL OF THE ORIGINAL BUSHING IF YOU HAVE AN S13.
Same for S14. And Z32.
FORMERLY R240NA
Old 05-13-2009, 09:51 PM   #25
murda-c
murda-c's Avatar
Is that just subframe or all the bushings.
Old 05-14-2009, 07:57 AM   #26
turbo_dreams
turbo_dreams's Avatar
turbo_dreams is making a name for him/her selfturbo_dreams is making a name for him/her self
If i do use a solid subframe spacer (pdm), what's the outcome? I already have solid subframe spacers, and my bushings are shot, you guys suggest i just slide the solid spacers in or do the bushings?
www.tm-spl.com
Kouki's & some apple juice.
turbo_dreams is offline   Reply With Quote
Old 05-14-2009, 07:58 AM   #27
enkei2k
Super Moderator
Trader Rating: (29)
enkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfectionenkei2k is close to perfection
Feedback Score: 29 reviews
worth it?
does it includes parts and labor? i got a quote for about 300 for labor only. then again, i'm pretty sure he was just messing with me and if i do actually do it, it'll be more lol.
Ask enkei2k
xquizitditz
enkei2k is offline   Reply With Quote
Old 05-14-2009, 08:21 AM   #28
oneviaman
oneviaman's Avatar
oneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond reputeoneviaman has a reputation beyond repute
i use an ingersol, with the cutting blade
oneviaman is offline   Reply With Quote
Old 05-14-2009, 08:25 AM   #29
SILVIA_KIDs14.5
SILVIA_KIDs14.5's Avatar
Trader Rating: (-1)
SILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choicesSILVIA_KIDs14.5 has made poor choices
Feedback Score: -1 reviews
go solid and call it a day never again have to replace them it would though have ben easier to get the bushings pressed out
SILVIA_KIDs14.5 is offline   Reply With Quote
Old 05-14-2009, 08:31 AM   #30
clark
clark's Avatar
oh shit i gotta get one of those haha.
yeah i mean i'm talking 7 hours start to finish meaning start the clock at jacking the car up, stop the clock at getting the car on all 4 wheels.
i was by myself so it's hard to fenagle the subframe back up there.
yeah i don't know why these poly bushings don't have more popularity. i mean yeah, aluminum ones are awesome, but these are fantastic too.
