ka compression #'s, what could it be?
So I did a compression test today on my 95 ka24de with "115k" miles to the best of my knowledge. The last 1,500 or so of which have been turboed at 7-8 psi tuned with an apexi afc neo and AEM uego wideband, stock fuel system, stock maf. My symtoms that lead me to the test were: 1. oil blowing out of the breather on my valve cover, only a breather because a catch can plumbed in any manor would cause severe exhaust smoke (the only symptom prior to a trip 3 hours away) 2. general oil leak/s all over motor, and burning oil. (took 5 quarts to drive 3 hours home) and 3. Loss of power, (no sht right).
My readings were (dry) 1:75 2:80 3:85 4:90 I then followed that up with a small amount of oil in each cylinder (wet) 1:80 2:90 3:100 4:120 I can't decide if its a head gasket, piston rings, valve seals, or combination of those. mainly due to the odd patterns that emerged. give a zilvia noob some love. |
#2 | |
![]() Join Date: Dec 2007
Trader Rating: (30)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 30 reviews
real simple and easy... rings are worn or broken and maybe even excessive piston to wall clearances.
KA pistons have thin ringlands which crack or completely break when boosting typically higher numbers (above .75 bar or 11psi est...). It's possible to have this occure in engines boosting lower numbers especially when a severe knock or improperly tuned engine is pushed hard. ~m
**GR Performance facebook** Pics & More! Comments! http://www.facebook.com/pages/GR-Performance/120477531339202 Read My Sales Review 626 Friday Nights San Gabriel |
Yeah I figured I was screwed. I still wanna stick with KA-T though. I'm currently deciding whether to rebuild on my own with the help of local machining, buy reman shortblock and head and assemble myself with arp head studs and nicer hg, or just buy a built longblock and save myself the time and stress. On top of any of those options I'll be adding alum radiator with electric fans, walbro 255, sr injectors, and bigger maf. Possibly better tuning, but I thought mine was pretty decent for just a fuel controller and 8 psi. around 14.5 afr cruising, and 12 under boost.
#7 | |
Trader Rating: (30)
this build will not safely break any hp/tq records but will surly hold the 12psi without blowing a hg or ringland... ~m
I've been looking into it a lot and think my budget might allow me to spring for a built longblock from handcraftedracing.com, anyone heard anything good/bad about em? I'm not looking for hp and tq records, just enough to break loose when I want and (more) reliability.
