Group Buys Dedicated Forum for Group Buys. |
02-22-2011, 05:21 PM | #1 |
TF★ - Evo 8/9 Brembo Caliper adaptor bracket - Stainless Steel!
Hey guys,
After looking at poor fitting brackets on customers cars, we designed our own bracket that properly centers your caliper on the rotors. Also the bracket is designed so that you don't have to grind down the calipers to fit. The bracket is stainless steel for strength and anti corrosion properties. This kit comes with shortened bolts for the bracket and spindle. This bracket will fit S13 and S14. Currently these are in production and will be ready for shipping in 3-4 wks. We're offering a Pre-Order special for those you purchase them before will received automatic $20 off of the total price! Put in "TF20" in the Coupon section when checking out for the discount. Click here to order the TF★- Evo caliper bracket !
Performance Parts // Track Prep // Fabrication **Follow us on Instagram @TFWorks For all the latest TF★ news visit our blog!! Last edited by tougefactory; 05-05-2011 at 12:23 PM.. |
02-23-2011, 09:32 AM | #5 |
projectslider >> $150 shipped to Puerto Rico. I applied the discount. Please paypal to [email protected]
Please include your full name, ship to address and phone # Thanks!
Performance Parts // Track Prep // Fabrication **Follow us on Instagram @TFWorks For all the latest TF★ news visit our blog!! |
02-23-2011, 09:33 AM | #6 |
umm....Mitsubishi Evo 8/9 front calipers.
Read the title and desc
02-23-2011, 09:40 AM | #7 |
Evo caliper uses stock 240SX brake lines. But you will need to upgrade to the 1-1/16" Z32 brake master cylindar.
We sell the master cylindar that already has the flare fitting built in to fit the 240sx as well.
02-24-2011, 01:25 PM | #9 |
Evo 8/9 front rotors
02-25-2011, 11:32 AM | #10 |
Evo Brembo's on our S14!!
03-01-2011, 06:08 PM | #14 |
As if right now these only fit the Evo 8/9 calipers, STI and EVO X do not share the same mounting points.
All the hardware is SAE Grade 8.8
03-01-2011, 07:03 PM | #15 | |
Sell your STI calipers and get a set of Evos.. They are much much cheaper than STI calipers..
2006 WRB STI|FP 20G 8cm^2|E85 2006 SGM IS250 AWD Daily | 2007 cbr600rr |
03-02-2011, 08:59 AM | #17 |
03-02-2011, 04:06 PM | #18 | |
Pm's being sent in regards to the Z32 BMC.
03-07-2011, 04:22 PM | #19 |
Quick update...
The Brackets should be in-stock in 2weeks.
03-07-2011, 05:10 PM | #20 |
Trader Rating: (63)
Feedback Score: 63 reviews
How is stock EVO rotors work with bracket?
I have EVO9 brakes and calipers sits higher so make rotors smaller size that what it should be.. my break pad worn unevenly... out side of pads don't even get used.... |
03-08-2011, 03:42 PM | #25 |
With our brackets you will need to use any STOCK sized Evo rotor, meaning the pads will wear evenly. You can see in the above picture (in post #19) that the whole pad is touching the rotor.
03-10-2011, 06:02 PM | #27 |
http://zilvia.net/f/tech-talk/93748-...ml#post1272584
you designed these brackets??? really are you sure... and yes mr. Li you are correct there is too little thread engagement (esp considering it is stainless and not cr/mo steel), there is far less R&D in these parts than TF is letting on, considering several people/companies have brought these to market (and some have even sold quite a few sets and have gotten rave reviews!!!)
I am SKULLWORKS |
03-12-2011, 04:34 PM | #28 | |
We did test the brackets on our cars and have not had any problems. Thanks!
03-14-2011, 03:16 PM | #29 |
are you even going to try and address your potential customers concerns of minimal thread engagement, or the request for material type?
and from scratch would suggest you came up with and executed the idea yourself...but you already admitted this was in response to "poor fitting" brackets on others cars, so we know you had atleast one set of someone else's brackets in your hands before you started "from scratch" I'm just trying to keep things honest here,
I am SKULLWORKS |
03-16-2011, 05:27 PM | #30 |
Sobay>> Here's a simulation test we did for our brackets before we even tested on the car. We used a chassis weight of 2700lbs, braking force of 1.5G's, which is what most of the cars will see with race compound tires at a race track.
You can see from the stress and displacement test that the minimal thread area you're concerned about does not see much stress, hence we were able to design it that way. As for the material, unless your car is pulling close to 5G's during braking, our bracket will not distort or deform.
