Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 11-07-2011, 01:09 PM   #931
JDMStanced
JDMStanced is an unknown quantity at this point
yes they are used. I should look a production date next time.
JDMStanced is offline   Reply With Quote
Old 11-07-2011, 01:21 PM   #932
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
Originally Posted by JDMStanced View Post
i have a question about tires. Do you guys have trouble with tire treads chipping off?
This happened to almost all my tires except for continental ones.
Is it because of the tires (including no name brands), or is it because i don't warm up the tires?
That happens to me when I use really shitty tires. (Used craigslist shit)
s13_maJiK is offline   Reply With Quote
Old 11-07-2011, 06:41 PM   #933
chiboy002
tires i recommend
Achilles ATR Sport
Sunny SN3800
both very affordable, both very nice for the price. Lasts about 9 hours on one side. stock ka, 17s
Old 11-07-2011, 06:45 PM   #934
fckillerbee
fckillerbee's Avatar
old tires dry rot. it's what rubber does.
and then you add rock debris and the compression of the vehicle, you start to get cut marks ....eventually it'll start taking chunks out.
Old 11-07-2011, 09:24 PM   #935
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
Federals are pretty good too. They are about the same price as the Achilles.
iamtheyi is offline   Reply With Quote
Old 11-07-2011, 10:15 PM   #936
chiboy002
so ive heard
havent had personal experience though, and i heard 18s used to have issues
Old 11-08-2011, 09:22 PM   #937
jasoncanseeoh
jasoncanseeoh is an unknown quantity at this point
Some may be against this or think it doesn't do shit, but i haven't had any tires chunk up or chip off on me by running them backwards. Particularly Federals.
jasoncanseeoh is offline   Reply With Quote
Old 11-08-2011, 09:28 PM   #938
xSoCalxRiderx125
xSoCalxRiderx125's Avatar
xSoCalxRiderx125 is an unknown quantity at this point
All that does is fuck your tires up. Maybe in the rain it would be a little different but running your tires backwards just doesn't make any justifiable sense.
xSoCalxRiderx125 is offline   Reply With Quote
Old 11-08-2011, 09:33 PM   #939
chiboy002
Only downside i've heard to running directionals in reverse is driving in wet conditions. water will be pulled in by the tread pattern instead of out.
Old 11-08-2011, 10:41 PM   #940
!Zar!
!Zar!'s Avatar
If you run with hella pressure in federals, it increases the chance of chunking.
Old 11-09-2011, 02:50 AM   #941
Jeff Jones
Jeff Jones's Avatar
Jeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of lightJeff Jones is a glorious beacon of light
New tires normally don't chunk unless you over heat them by running to much or to little air pressure. The tire will get heat expansion in the middle only if you use to much air. This will make a tire chunk due to the tread not all expanding at the same rate. Like cheap glass cracking on a hot day when you spray water on it.
Old tires just suck....
Jeff Jones is offline   Reply With Quote
Old 11-10-2011, 01:18 AM   #942
JDMStanced
thanks people.
about the toe in the rear, is drifting really effected by the rear toe? i'm contemplating between having both front and rear toe to zero, or front zero toe with .05 toe in rear.
Old 11-10-2011, 05:02 AM   #943
F20cS13
F20cS13's Avatar
F20cS13 is an unknown quantity at this point
Federals chunk unless you run then in the opposite direction.
Honda powered s13
F20cS13 is offline   Reply With Quote
Old 11-10-2011, 09:50 AM   #944
!Zar!
!Zar!'s Avatar
thanks people.
Toe up front changes turn in.
Toe in back changes traction.
Old 11-10-2011, 02:01 PM   #945
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
I have NEVER had a single chunk come off a Federal.
http://bhworld.wordpress.com/
Old 11-10-2011, 04:27 PM   #946
fckillerbee
the ONLY federal tire I have known to chunk was the 235/40 r18 and that was because if you inflated it past 50psi, it would overheat the tire, and chunk. A very normal process for a tire considering it's waaaaay past it's maximum rated heat levels.
Buuuut. According to powers, if you put Nitrogen in them, it's supposed to stabilize the air...allowing for normal temps....fixing that problem.
It's not the tire...it's the abuse we put them through.
Old 11-10-2011, 05:20 PM   #947
!Zar!
!Zar!'s Avatar
I've torn off thread blocks off of 17" federals at 30psi a few times. But I was beating them relentlessly.
If you allow the tires to cool down between runs and aren't going balls out for a long time, nor running a high psi, the tire will last.
Old 11-10-2011, 05:26 PM   #948
chiboy002
nitrogen is really nice shit but damn near no one has it, especially on track. and filling nitro and mixing with air will just cause some wierd shit
anyone ever use federal 595 RS-R? reviews?
i wanna know how they stack up as front tires
Old 11-10-2011, 05:27 PM   #949
fckillerbee
^they are real nice. smoke a ton. henry schelley ran them in FD on the s13. ;D
I ran them for a while on my s14 in the front. grips really well.
Old 11-10-2011, 08:59 PM   #950
JDMStanced
Are you saying toe in in the back will give better traction while drifting?
Old 11-10-2011, 09:17 PM   #951
chiboy002
alright cool
thats what i heard on a bunch of other car forums
i was thinking ad08 up front but the rs-r are like 90$ cheaper
my only concern, a 215/40 feddy will stretch like a normal 225/40, right? never used those tires before
Old 11-10-2011, 09:31 PM   #952
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
When I first lowered my car and aligned it on an uneven surface I had toe out in the back. You know how if you have toe out in the front it makes the steering twitchy/super responsive?? Well toe out in the back made my car feel like the rear end was on marbles. It felt like the subframe was attached to the car via jell-o. Just put it this way:
Front toe in - stable front end
Front toe out - responsive but twitchy front end
Rear toe in - stable/somewhat harder to break loose rear end
Rear toe out - scary as hell will make you feel like you're driving sideways in the rain with your eyes closed...
pacotaco345 is offline   Reply With Quote
Old 11-11-2011, 02:25 PM   #953
JDMStanced
With rear toe in, "somewhat" harder to break loose rear end which means more smoke when drifting. no? sorry i'm noob
Old 11-11-2011, 02:30 PM   #954
fckillerbee
imagine skiing. it creates friction.
Imagine trying to transition and you have added friction. It will snap more.
as far as adding extra traction...I personally haven't noticed it. But I've ran zero toe almost all my life, and it hasn't been a big deal. I'm sure those calculations are more for trying to move up the ladder in FD.
Old 11-11-2011, 06:25 PM   #955
pacotaco345
^^ listen to this guy, much better driver than me lol. But seriously, you should run 0 toe in the rear.. there's not really any benefits to running to out or in back there. The front end is where you should mess with stuff, camber/toe/caster... I mean in simplest form they are what steer the car.
Old 11-11-2011, 07:23 PM   #956
!Zar!
!Zar!'s Avatar
Toe out in the rear is wack since it makes the care really sketch.
Toe in increases traction and stability. As of right now, I run no toe in rear.
Old 11-12-2011, 01:37 AM   #957
chiboy002
0* toe in rear is pretty much ideal
toe in also does some wierd shit to traction. people on this level of driving wont notice, or need, the difference anyways
Old 11-12-2011, 10:06 PM   #958
Perfect Balance
Perfect Balance's Avatar
Perfect Balance is an unknown quantity at this point
Love that video of the 240 at Ebisu. That's the guy from roadsterdrift, forget his name. I've always been a fan of drifting like that. For me, smooth, precise drifts with smooth driving > super aggressive driving where the driver is flailing around, even with backwards entries and whatnot. Smoothness does it more for me. (that's what she said) That's why I've always liked watching driving videos of Taniguchi, and that's the kind of drifter I strive to me.
EDIT: Shit, I'm a page behind. But yeah.
Perfect Balance is offline   Reply With Quote
Old 11-13-2011, 03:26 PM   #959
word sux
word sux's Avatar
word sux is an unknown quantity at this point
toe in, in the rear helps with traction and for drifting helps allot with the forward bite. I will be bumping up the rear toe from 0 to -.5 in the rear for next year. (oem spec is -1/16th of a degree in the rear)
for a low hp car i would not bother but if you are going north of 300whp I would suggest adding some - rear toe, you will love it..
word sux is offline   Reply With Quote
Old 11-13-2011, 03:28 PM   #960
word sux
word sux's Avatar
smooth driving has more to do with the car setup. I used to flail around like my cabin was full of bees but since this past year I have had a good suspension setup and its sooo different.
I let the car steer itself allot more now, with stock caster its really hard to do that.
