Solid Avid Mount/Xcessive Solid Tranny Mount
So I've got these^ but the Xcessive is a defect and needs to be re-drilled. I don't have the time today to drill em but my stock engine mounts are pretty bad and it's my only day off for a week and wanna throw em on. Bad idea with the stock tranny mount for a week or so?
YES it's a daily, idgaf about pussy-ass vibrations. YES I understand I have to locktite all my small bolts and re-torque everything to be safe. NO there isn't any plastic pieces in the interior, or carpet, or heat (I scrape frost off the INSIDE of the windshield daily), or a/c (obv), it's a daily/drifter in the making for next season. |
![]() Join Date: Mar 2009
Wow, my Xcessive trans mount had to be re drilled also, I called them and they said they would have it fixed. So much for that.
It also lowered my transmission so I can't run a shift boot anymore, not to pleased with that... |
![]() Join Date: Jan 2010
Trader Rating: (24)
![]() Feedback Score: 24 reviews
you guys might be doing it wrong. i thought the same thing also, but in fact i was installing it the wrong way. there is a specific order to installing it but i cant remember exactly what that was off the top of my head.
but yes everything rattles like a BITCH and it lowers the transmission a good couple inches. nothing a "JDM" Knob from 9K cant fix. i'll go run out right now and snap pics for you bros
my for sale thread: http://zilvia.net/f/sale-items/53975...e-30-less.html NISMO, NRG, JDM turn signals, misc engine parts |
Trader Rating: (24)
It's not an issue with the shiftknob. My shifter hits the hole in the sheetmetal where it comes through the bottom of the car. Thus I can't run the rubber boot there because it binds up and won't go into 2nd 4th and reverse. Also due to the new angle of the motor and transmission, I blew up the rubber bushing between the stock two piece driveshaft twice. I had to purchase a Driveshaft shop one piece after that to avoid it.
#10 | |
You can see here the holes that were pre drilled, and where I had to drill new ones. I actually didn't get the second hole lined up correctly still and only used one bolt ![]() ![]() So this was the resulting angle of my stock driveshaft. ![]() And after a week of driving, this happened. ![]() Replaced the bushing and it broke again after about another week. ![]() And this fixed my problem from there on. Sorry about the blackberry pictures :$ ![]() |
#14 |
#15 | |
3rd gear. ![]() Neutral. ![]() 4th gear. Touching the sheet metal. ![]() |
#16 |
At the time of purchasing these mounts, I was under the impression of "plug and play" installation. I did not have the time to make my own mount. Of course if i would have known of the issues I eventually had, I would have made my own mount.
#19 | |
![]() Join Date: Apr 2007
Trader Rating: (50)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 50 reviews
tried this then they made some messed up shit! who would want their transmission lower than the frame rails?? |
#20 |
![]() Join Date: Apr 2003
![]() Feedback Score: 15 reviews
Yep I did the same thing when i had a set of xcessive mounts. I originally installed the tranny mount wrong and had similar issues. I flipped it around and it worked great. Unfortunately, I don't have pics of it correctly installed and it's no longer installed on the car.
1993 KA24DE-T |
#21 |
![]() Join Date: Aug 2009
Trader Rating: (28)
![]() Feedback Score: 28 reviews
You can clearly see that mount is suppose to be mounted the opposite way.. I can't believe so many people can get it wrong and think it's right...lol
Use some ingenuity once in awhile.. If something seems that far off with what should be a quality product from a reputable company then something probably isn't installed correctly.. Would've taken 5 minutes to flip it and try it the other way... Or you could've just called them and explain the situation.. They probably would've just said "flip it dummy"... |
#22 | |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
JESUS....I really hope you all have only paid $10 for this thing or got them for Free.
WTF is the point? Just bend a Metal bar and drill some holes - Done & Done. Its a wonder its not fitting correctly. ![]() Is Seriously a $60 solid poly mount just Drowning the wallet? Is this some New JDM tyte hype I'm missing out on? Sorry just had to chime in on this one because of how retarded that thing looks and the problems your having from it. Quote:
z-tERty-2 |
#24 |
I did not have a problem with any height change in the tranny. Picked up the mount for 20 bucks knowning of the defect and after drilling the plate and installing the avid solid motor mounts there was only one possible way the xcessive plate would line up. I'll grab a couple pics to compare during lunch break.
#25 |
Lmao "this shit doesn't fit right, oh they fucked up in making it."
