Old 12-09-2011, 01:37 AM   #1
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Billion dollar idea
Who can make something like this that would attach to the pop-up headlight motor knobs, and reach all the way to the cabin?
Preferably if a single knob could adjust both headlight motors together.
Old 12-09-2011, 01:39 AM   #2
Brian04
Brian04's Avatar
Trader Rating: (28)
Brian04 is an unknown quantity at this point
Feedback Score: 28 reviews
Why can't you just cut your brown wire and control them both simultaneously, and manually through the cabin?
I'll take my billion dollars now.
Brian04 is offline   Reply With Quote
Old 12-09-2011, 01:42 AM   #3
Matej
Trader Rating: (39)
That was the first mod I did to my car. The wiring is old and ghastly though. The less wires the better. I have already replaced every component of the pop-up electrical system at least twice when troubleshooting it.
Old 12-09-2011, 01:49 AM   #4
Brian04
Brian04's Avatar
Trader Rating: (28)
maybe third time's a charm?
i honestly see no simple way of manual adjustment through the cabin, without cutting a hole through the firewall
Old 12-09-2011, 01:54 AM   #5
Matej
Trader Rating: (39)
It works, for now. But still, it is silly how much extra wiring there is just to perform such a simple task.
Routing it to the cabin would be no problem. It could go through wherever the underhood harness or the hood release cable are routed through.
Old 12-09-2011, 02:09 AM   #6
Brian04
Brian04's Avatar
Trader Rating: (28)
Yeah, i was thinking something like a gear and pulley system, but i guess custom wiring works well too....
Old 12-09-2011, 02:43 AM   #7
TheRealSy90
TheRealSy90's Avatar
This already exists. It's called the Pivot headlight controller.
*RARE* 180SX RX-7 Miata Pivot Headlight Controller Sleepy Eye JDM | eBay
Such a good signature.
Old 12-09-2011, 04:04 AM   #8
lukeworx
lukeworx is a well-known jackass
240sx Sleepy Eye DIY - YouTube
diy version if any use
lukeworx is offline   Reply With Quote
Old 12-09-2011, 04:06 AM   #9
sharpe_corners
sharpe_corners's Avatar
Trader Rating: (29)
sharpe_corners is an unknown quantity at this point
Feedback Score: 29 reviews
I have a BNIB Pivot HL controller kit, with wiring, instructions etc, missing the unit, va240dude has one to match.....
sharpe_corners is offline   Reply With Quote
Old 12-09-2011, 04:33 AM   #10
ayuaddict
ayuaddict's Avatar
Yeah something tells me that MATEJ is well aware of the cutting the brown wire trick and of the pivot controller, and that he is also aware that neither work very well due to their electronic nature. Hence the reasoning behind a remote way of controlling your headlights motors manually and mechanically from the comfort of your cabin.
I'm thinking e-brake cable.
Old 12-09-2011, 04:45 AM   #11
harrypotter
harrypotter is an unknown quantity at this point
What is the point in controlling them?
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 12-09-2011, 04:48 AM   #12
ayuaddict
ayuaddict's Avatar
because power is nothing without control.
Old 12-09-2011, 05:04 AM   #13
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
I'm assuming looks. Though the front left can be a good place to increase air flow to the intake.
Anyway,
I think there are three things working against you there. First, that's a really long run to get something to go that won't just turn and turn at one end, twist, and do nothing on the other end. Second, those knobs spin super fast when you flip the headlight switch to actually use your headlights, that might pose an issue unless you can disengage the cable. And third, it will be expensive.
Due to issues stated above, I wouldn't go mechanical all the way, I would run wires up there and put little motors that engage/disengage each time I wanted to adjust he height of the headlights. It would maintain oem functions, allow on the fly adjustments, and be kind of standalone from the factory wiring crap. But again, would you pay $400 for a kit like that when all you have to really do is pop your hood and spin a knob by hand?
P.s. anybody ever get a close look at those remote bottle openers for nitrous tanks? That may be a good place to start.
Or better yet, what if we just found a way to make a better controller for the factory headlights? That may be the cheapest/easiest.
nissanfreak317 is offline   Reply With Quote
Old 12-09-2011, 05:16 AM   #14
Bushido
Bushido's Avatar
Problem with the brown wire cut on my car is that one headlight moves faster than the other resulting in uneven and retarded looking sleepies
Old 12-09-2011, 05:46 AM   #15
thatdrifterguy
thatdrifterguy's Avatar
thatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to beholdthatdrifterguy is a splendid one to behold
so that everytime you release the ebrake, you get sleepy eyes! drift points! lol jk
thatdrifterguy is offline   Reply With Quote
Old 12-09-2011, 06:10 AM   #16
MidwestMyriad
MidwestMyriad's Avatar
MidwestMyriad is making a name for him/her selfMidwestMyriad is making a name for him/her self
Yep. For a while, I would just take a philips screwdriver and manually adjust the lights. Can't be popping the hood every night though to readjust.
@MMyriad
MidwestMyriad is offline   Reply With Quote
Old 12-09-2011, 06:20 AM   #17
axiomatik
axiomatik's Avatar
^^^^ Don't drive at night. Problem solved.
Old 12-09-2011, 06:38 AM   #18
EnemyS15
EnemyS15 is an unknown quantity at this point
This idea is worth ohhhhhhhh ............. about Tree Fiddy.
EnemyS15 is offline   Reply With Quote
Old 12-09-2011, 07:01 AM   #19
CamryOnBronze
CamryOnBronze's Avatar
Trader Rating: (131)
CamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud ofCamryOnBronze has much to be proud of
Feedback Score: 131 reviews
Send a message via AIM to CamryOnBronze
RHU-M #1 Matej!
It's only four wires. haha If I can wire it up, anyone can. I guess the way it functions is pretty jenky though. For sure better than cranking by hand.
CamryOnBronze.com
CamryOnBronze is offline   Reply With Quote
Old 12-09-2011, 07:08 AM   #20
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
That's what I always liked about my STi... it had a headlight adjustment knob in the cabin. It was only 4 preset positions, but it was useful nonetheless.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-09-2011, 07:50 AM   #21
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
i love the wiring version,...lol
id always double-tap the headlight position button when i saw other 240s / cool cars / or at the track,. and you could get one of the lights to 'wink'
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 12-09-2011, 08:00 AM   #22
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
I think by the time you find a long enough adjustment knob/cable, the cost would be prohibitive to a point.
Old 12-09-2011, 08:02 AM   #23
Om1kron
Om1kron's Avatar
why not relocate the motors? why manual adjustment? and why is that even an idea anyone cares about.
Wayne Edwards
https://om1kron.blogspot.com
Old 12-09-2011, 08:58 AM   #24
ILoveMyRHS13
ILoveMyRHS13's Avatar
Trader Rating: (25)
Feedback Score: 25 reviews
I was going to recommend this.
Old 12-09-2011, 09:16 AM   #25
didderson
didderson's Avatar
didderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enoughdidderson will become famous soon enough
Send a message via AIM to didderson
It's possible to fix a Lazy headlight. Depending on which one moves slowest, you have to unbolt the swingarm from the electric motor and match it to the other side when both are in resting position.
Once this is done usually they're pretty close, and all that is left is the max height adjustment via the double sided (toe rod-like) ball joint links.
I've done it w/ both my cars to get the sleepies in synch.
What I REALLY want to know is.. My left headlight will sag 1/8" after driving (with pbm coils) for a decent amount of time.
If I flip the lights up and down they reset and the left one is perfect height again.
I think this is due to the magnets in the electric motor being old and unable to hold the light steady with stiff coilovers.
I should make a video about this to explain. It's been bugging me since I retrofitted hid's... Ends up making the left cutoff sag after a drive. wah wahhh.
didderson is offline   Reply With Quote
Old 12-09-2011, 09:48 AM   #26
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
Shit made me LOL so hard
mattack69 is offline   Reply With Quote
Old 12-09-2011, 02:57 PM   #27
lflkajfj12123
here's my idea don't mind the shittiest drawing ever
tie two pieces of fish line the the motor knob somehow... punch a hole through it on both sides or something
then tie the line around clockwise and the other line counter clockwise
route them to the cabin and you can just pull on the lines to turn the knob left or right which will raise the headlights up or down
they would automatically rewind themselves aslong as you get clever and make the knob into something like what sewing thread is rolled on
Old 12-09-2011, 03:49 PM   #28
Brian04
Brian04's Avatar
Trader Rating: (28)
this is like de-evolution of technology
Old 12-09-2011, 04:19 PM   #29
blingbling
blingbling's Avatar
blingbling is an unknown quantity at this point
Soaps gettin his creativity on
blingbling is offline   Reply With Quote
Old 12-09-2011, 04:32 PM   #30
mysharonna
mysharonna's Avatar
mysharonna is an unknown quantity at this point
WHAT HAVE YOU DONE??!?!
mysharonna is offline   Reply With Quote
