Old 12-27-2011, 04:41 PM   #31
towlie
Originally Posted by fliprayzin240sx View Post
You sure the flanges are not warped? Also, like already stated, since its an aftermaket manifold and you fucked the DP up from bottoming out...are you sure the manifold isnt cracked to hell? I'm willing to bet the manifold is cracked on the collector before anything else...
when my leak first started I had the stock manifold, i didnt install the aftermarket until i was replacing everything. i bought it secondhand perhaps it was fucked up idk, scrap metal now anyways so it doesnt really matter lol.
Im not running a diesel or mitsubushi turbo so using grease or rtv in place of a gasket sounds sketch, also i really dont want to spot weld any bolts.. but thanks for the suggestions
Old 12-27-2011, 04:52 PM   #32
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
I never ran any sort of gasket on my Full Race GT3071R setup... obviously no leaks. I wouldn't attempt this on some of the thin wimpy flanged manifolds out there though. As stated by others, you would need to make sure the flanges are true on both the manifold and exhaust housing. You could always glue some sandpaper down to a board then run both mating surfaces across it to make sure they are good to go. Any weird spots will show up instantly after a few passes. You can then address the issue(s) accordingly.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 12-27-2011, 04:53 PM   #33
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
Buy the mr gasket copper one from enjuku I have it. Seems to do the trick for me. Haven't blown a gasket yet.
Then again I've only been driving it daily for about 2 weeks in the past year it's been on there
SLiDe_WaYz is offline   Reply With Quote
Old 12-27-2011, 04:59 PM   #34
towlie
ill inspect the stock manifold for any sort of imperfections, and the turbo.
Was the gt30 top mount? does that make a difference in using a gasket or not?
Old 12-27-2011, 05:09 PM   #35
Kingtal0n
Kingtal0n's Avatar
The only thing I disagree with is the welded nuts theory. Are you poor fellows off your welded nut brains?
What happens when you need to take the turbocharger off- You packin' a grinder and some new studs and nuts in the trunk? Its not like a tattoo!
Old 12-27-2011, 05:12 PM   #36
Broadfield
Broadfield's Avatar
If it's just a tack weld then you can still break the nut loose without any repercussions.
My Portfolio
Please Share
Check Out My Builds
Old 12-27-2011, 05:15 PM   #37
towlie
tacks arent hard to break dude. thats just a little to, er, extreme for my tastes lol. plus i dont feel like going to the hassle of trying to find a decent welder locally
Old 12-27-2011, 05:42 PM   #38
!Zar!
!Zar!'s Avatar
Exactly.
Lock tabs, safety wire, even regular lock nuts all require the manifold to be removed in order to remove the turbo.
I tried all sorts of bullshit, and in the end the stainless steel gasket and tack welding it has left me trouble freeeeeeeeeeeeeee.
Old 12-27-2011, 05:48 PM   #39
Sileighty_85
Sileighty_85's Avatar
Originally Posted by Sileighty_85 View Post
wait so, your using the S15 gasket on an AM manifold?
is the Port flange a one piece design?
If so thats your problem. You cant use a S15 MLG with a one piece flange cuz of the rivets used to hold the MLG together are keeping the flange from sealing properly
Never got a response on this so just wanna throw this back up
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 12-27-2011, 05:58 PM   #40
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
I never had an issue using the s15 layered gasket and oem locking tabs. I just tighten the 4 bolts real good. Drifted hard with this on OEM mani and aftermarket SS ones.
Can you take some pics of the way it sits now? Is there any visible warpage you can see? Can you still feel the exhaust gases leaking?
Luvs2slide is offline   Reply With Quote
Old 12-27-2011, 06:09 PM   #41
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Well either way, you're gonna have to pull the whole manifold/turbo off. When you take it off, you should see the soot on where its leaking. Depending on where it is will dictate your next course of action. If its leaking between flanges, I'm willing to bet one of the flange is warped. If its not, then its coming from a crack on the manifold.
CLICK HERE!!!
Old 12-27-2011, 06:36 PM   #42
towlie
Sorry dude, yeah pretty sure its a one piece design and yes I am using the s15 mlg. Defiantly a possibility, interesting idea. Happened to you?
Yeah ican get pics of everything tomorrow night after work i really don't feel like touching my car right now LOL. Parked it in the shop that's as far as I'm going :| edit: and no I haven't tried to see if its still leaking in the same spot, turned it on to re park it and I could hear it clearly so I assume yes same place.
I'm really dreading taking it off again, its a pretty big pita! I'll keep my eyes peeled for any signs and post pics to. It's only ran for 5-7 minutes total since everything has been installed,would it show soot or other signs of leakage already?
Old 12-27-2011, 08:16 PM   #43
Sileighty_85
Its cool,
Nah seen it happen a few times
後輪駆動車1番
1986 SR86 - 200ish
Old 12-27-2011, 08:57 PM   #44
R33E8
R33E8 is an unknown quantity at this point
You can always try making your own gasket using flexible graphite sheet/graphoil.. It's really compressible and could easily conform to any minor defects in the mating surfaces.. Mcmaster carr has some, I think it's less than $20 for a 12x12 sheet that is 1/16" thick(which is what I use)..
R33E8 is offline   Reply With Quote
Old 12-28-2011, 10:47 AM   #45
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
Problem solved.
di-devol is offline   Reply With Quote
Old 12-28-2011, 11:02 AM   #46
Sileighty_85
That's nuts, Im surprised how many ppl have issues with that gasket.
I have an unknown AM manifold, Oem gasket with stock locking hardware daily and drifted the car for 5 years now and never had that that gasket blow, even bashing my exhaust and down pipe on all the shitty roads over here
後輪駆動車1番
1986 SR86 - 200ish
Old 12-28-2011, 03:56 PM   #47
sharpe_corners
sharpe_corners's Avatar
Trader Rating: (29)
sharpe_corners is an unknown quantity at this point
Feedback Score: 29 reviews
Exactly.
+1917327376376373647637364737336746365736547354774 637436463+7436436
Originally Posted by Goofs View Post
Reminds me of a guy around here who bought a e36 because he said his truck has a "rap sheet, and a high heat level." I told him this isn't need for speed most wanted.
sharpe_corners is offline   Reply With Quote
Old 12-28-2011, 04:29 PM   #48
arg23
arg23's Avatar
arg23 is an unknown quantity at this point
[QUOTE=di-devol;4429564]Problem solved.
QUOTE]
Love this. If surfacing hadnt resolved our issues back in 2009 we were going to do exatcly this. Came up on another project recently as well, wasnt certain I could weld inconel though...
the clock IS ticking!
Last edited by arg23; 12-30-2011 at 05:42 PM.. Reason: dont really need to quote piccy
arg23 is offline   Reply With Quote
Old 12-28-2011, 07:55 PM   #49
towlie
Lol, that's yours Tim? I dunno ive been considering tacking it. I really DONT wanna have to do this a third time -_-
Old 12-28-2011, 08:58 PM   #50
di-devol
Naw, it's something Alex showed me when I was having the same problems. I used one of those really thing steel gaskets that failed alot. Getting the multi-layered one and locking tabs fixed it for me.
Hope you fix it man.
Old 12-28-2011, 09:08 PM   #51
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
hey zach,
Sorry to hear you are having a leaking problem. I never had a problem with it leaking... this is the same gasket I was using with it installed on my car and Im reusing it on my car now. I think its the normal 2 layer.
huffandpuff00 is offline   Reply With Quote
Old 12-29-2011, 03:18 PM   #52
towlie
thats my plan of attack, it should fix it. I hope
Originally Posted by huffandpuff00 View Post
hey zach,
No worries, tomorrows my day off im tackling it then. picked up this gasket:
Looks legit
Old 12-29-2011, 06:16 PM   #53
huffandpuff00
so you are going to tack the bolts?
Im ordering my exhaust tomorrow, so ill hit you up when it shows up next week
Old 12-29-2011, 07:51 PM   #54
towlie
Nah, Alex suggested I use FRSports copper lock nut. Above post was a typo my bad i was at work. If that fails I doubt I'm going to touch it for another year LOL. And word just shoot me a text
Old 01-03-2012, 04:27 PM   #55
towlie
update, sorry for taking so long stupid life has been keeping me busy lol
heres the SUCKY sr
Manifold in question'
lol
Found the problem.
into the scrap metal bin!
anyways, i think the only aftermarket manifold im ever going to run is Full-Race. my SR runs fine now, few kinks here and there i need to find time to straighten out but i fixed this, no more leaks! got me to work yesterday. thanks duders fot your help
Old 01-03-2012, 04:45 PM   #56
!Zar!
!Zar!'s Avatar
Wow, that thing is super shitty.
Stock SR manifold that is honed and extruded, then ceramic coat it > your butt cheeks.
Old 01-03-2012, 04:51 PM   #57
SLiDe_WaYz
SLiDe_WaYz's Avatar
This, waiting to get mine back, it cost 170$ total. That was buying a old stock manifold shipping it off to get it honed ext, and getting it ceramic coated.
Old 01-03-2012, 04:53 PM   #58
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
For the record, Stock Manifold time and time again is the best T2 manifold available Leave the tubular junk for the hood poppin hardparkers
Stock SR manifold that is honed and extruded, coated, and modded for external gate > your butt cheeks.
Corrected for level 10 awesomeness
Old 01-03-2012, 05:06 PM   #59
towlie
yeah, i definatly learned my lesson lol. i dont think ill be doing any fancy flow work with the manifold anytime soon, i never want to take it off again!!
also,
Old 01-03-2012, 07:42 PM   #60
codyace
codyace's Avatar
Trader Rating: (58)
External gate FTMFW
