#32 | |
![]() Join Date: Mar 2011
#34 |
I bought the turbo from atp. It's about 1600 plus shipping. Shipping was around 40 for me. Plus 400 for the external gate. Might need some other miscellaneous stuff depending on your current set up.
#35 |
![]() Join Date: Jan 2011
Trader Rating: (26)
![]() Feedback Score: 26 reviews
I'm on a 2871 external set up. Only thing I would need to change is the piping I think.
Is it really good for nearly 40psi? What's the power output supposed to be do you know?
IG/TikTok-ThatS14_Z06guy |
#36 |
Okay, so i got my wastegate today, took it to my shop and went to bolt it up. Regretfully it did not fit. The top of the gate hit the strut tower and still needed a good 1/2 inch to clear, not to mention the banjo bolt for the top vent. So i decided to fab up my own elbow. After a few hours of cutting and welding i had it all where i thought it would work best. Pretty bummed that everything didnt bolt up to the housing, but still happy with the end result.
#37 |
The Compressor map shows 40+ lbs/min of air flow. Not real sure of the power out put of the turbo, but hopefully we will all see real soon.
#38 |
You should've known that it wasn't going to fit in-between the motor/strut tower, however I do like your final placement. How close is it to the BMC/booster? When are you going to get tuned?
#39 | |
Compressor map shows this turbo is good for peak of 2.7 bar (39psi) but will bleed back down to 2.5bar (36psi) towards the top of the map. Depending how well your engine flows , you should be able to get a safe 30-35psi out of this turbo without overspinning it. Additionally you can get this turbo for 1283.49 shipped from top speed. http://www.topspeedparts.com/Garrett...ger-gtx28.html |
#40 |
Trader Rating: (26)
Do they make a 5 bolt turbine housing without the external flange and just a blocked off internal?
I want this turbo so bad lol
#41 | |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() Feedback Score: 5 reviews
Garrett GTX2867R Dual Ball Bearing Turbo - less turbine housing : atpturbo.com |
#42 |
Trader Rating: (26)
My 2871 internal is welded shut.
I don't want to switch housings I want to straight up sell the 2871 and get the gtx lol
#43 |
this is awesome.. im excited to see what kind of numbers your putting down..
i wonder if that exhaust housing is efficient or would be better flow with a wastegate on the manifold.. and i would like this a whole lot more if you had a tomei or full race style manifold |
#45 | |
![]() Join Date: Oct 2004
Where the heck did you pull this outta your ass from? The GTX2876 will NOT bolt into a GT2871R.... The housings are not interchangeable cause the compressor wheel is different. Already checked with someone from Garrett....
#46 |
Can't wait to see some actual numbers!
We have a group buy going on these on another site (will be adding it here as soon as they get back to us) as we are also very excited about this turbo. Better spool than the 2871r with the similar power output potential.
http://www.EnduranceMotorsports.net |
#47 |
![]() Join Date: Dec 2004
Trader Rating: (58)
Interesting placement with the external gate on the pre flanged ATP housing, at least we all know now definitivly that it will not fit without some well placed fabrication. I'm curious as to how to how close it is the steering shaft.
Personally, I'm still a fan of how we have JPC put them atop the manifold (which we'll be doing a different setup with the 2 bolt flanged turbos soon) as the MVS is no where near the BMC that way, and out of the way of everything. COol stuff though. When are your planned power pulls? My entire turbo setup is off my car, and dare I say, awaiting your results to see which way I go. However if you're far out, I'll probably just follow through my gut and get one too...I'm hoping to have it back on the dyno by mid march if I do go through with it
#48 | |
![]() Join Date: Apr 2004
Get your facts straight before acting like an arse... ![]()
S13 Hatch - Goes around tracks quickly DEFSPORT |
#49 |
I did misread his post, my bad... he was just talking about the exhaust housing, but doesn't the exhaust housing have a twin scroll option vs your standard gt2871R standard housing?
#52 |
You can purchase it with and without the turbine housing. Your old 2871R housing will work with it....
#53 |
Trader Rating: (26)
But then who am I going to sell a 2872 with no turbine housing to? Lol
I have to get this turbo now. I just need it. I gotta look for turbine housings with just the internal blocked off and not a waste gate connection.
#55 |
I actually have a 2871R .86 AR housing.... It has a hairline crack on where the wastegate is... kinda weird and I can take a pic if you interested in using it.
#57 | |
If you're primarily spool focused I'd go with the .64 A/R and .86 A/R if you want more top-end.
#58 | |
Trader Rating: (26)
I would love to go v band turbine but I would have to get a new downpipe and I fancy my PBM Flex Cobra.
#59 | |
#60 |
Tags |
gt2871, gtx, gtx2867r |
