Old 02-10-2012, 03:10 AM   #2221
Dub's
Dub's's Avatar
Dub's is an unknown quantity at this point
Originally Posted by Broadfield View Post
Dude, is this going on a 240, a semi truck, a tractor? If it's a 240, is it an S13, S14, S15? Are the fenders stock, rolled, pulled? If pulled how much? How low is the car? Last but not least, what are the wheel specs? Size, width, offset? How are we supposed to tell you if something is going to fit if we don't know what it's fitting on and what setup you are running!?!
I think im just going to stick with the 35 then. Everyone thinks its to tall for a S14.
XXR 521 +25 18x10 295/35/18
98 Kouki / ID2000's / 6266 / Full Z32&Q45 drivetrain
Dub's is offline   Reply With Quote
Old 02-10-2012, 01:23 PM   #2222
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
I know i look like a broken record, but i found some new wheels that i might jump on. Just need some opinions. This will be going on a S13 COUPE.
17x9.5 +28 (rear)
17x8.5 +16 (front)
Looking to run a BFGoodrich 275/40/17 Drag radial on the rears.
Tire Diameter = 25.70 in.
Section Width = 11.00 in.
http://zilvia.net/f/chat/166563-maxi...ml#post3535638
This guy is running a 17x9.5 +12 with a 275/40/17 and about 3 degrees of camber.
So i am basing my figures off his car that these wheels i want should be 9/16 more into the wheel well. Whats your guy's thoughts on this?
Should work pretty "well" right?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 02-10-2012, 02:15 PM   #2223
silviaks2nr
silviaks2nr's Avatar
I don't think 16mm of outer clearance is going to allow you to take out too much camber. I'd go for a +35-40 ish personally. Or just leave the car a little on the high side.
Old 02-10-2012, 06:12 PM   #2224
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
17x9.5 +28 (rear)
17x8.5 +16 (front)
This is all going to depend on how low you run the car. You would need to pull the quarters slightly to run that setup if you want to run at a fairly low stance. If you look at my old setup I just posted, those are 275 on a 10" +44. You will be extending out an additional 10mm over the setup I had.... and mine would rub if I went any lower. I had rolled quarters just so you know. I wanted to go lower so I pulled the quarters and now run the 285.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 02-10-2012, 07:23 PM   #2225
gsracer
gsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond reputegsracer has a reputation beyond repute
picked these up to replace my azenis rt615s, i didn't want to replace the azenis, but ever since the 615ks came out the price jumped 100 dollars per tire, and at 410 dollars a tire its ridiculous. Id rather give my money to someone else at this point.
Its not good for drifting but for street and track use it should be great.
ANTI-STRETCH NAZI
Vortech Supercharged Vh45de S14 V8nissans.com
gsracer is offline   Reply With Quote
Old 02-11-2012, 01:04 AM   #2226
One_love_silvia
One_love_silvia's Avatar
Trader Rating: (38)
Feedback Score: 38 reviews
anyone know how an 18x9.5 +15 rpf1 with 255/40/18 all around will fit on a stock body s14? i have stance coils, and im at "legal" height (aka not that low).
im pretty positive il need a roll, but will that rub the inner fender well or the coils? and how much of a roll will i need? will they need to be flared?
also, how would a 245/40/18 fit on that same rpf1 size? like how bad of a stretch would it be?
2016 Nissan 370z
Old 02-11-2012, 09:29 AM   #2227
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Nice, what size wheel are you putting those on?
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 02-11-2012, 11:00 AM   #2228
gsracer
18 by 11 work misters +18 offset 50mm wide body...
ANTI-STRETCH NAZI
Old 02-12-2012, 06:42 PM   #2229
Black R
Black R's Avatar
Black R is an unknown quantity at this point
Late reply but...
Why not go with a q45 rear end and call it a day with 315's?
Originally Posted by mad-ass View Post
maximum tire duders, i has question.
the car this question is for....
I've decided to go with 245/40/18's for the fronts on either 18x9 or 18x9.5[but probably on a 9j because the rpf1's come with +22 offset on those and that'll give me some play room more then the 9.5+15's]
and rears will be 18x10+38 rpf1's. I remember the magic number of tire stagger was with in 30mm of the tire thread to avoid any understeer issues, and I also talked to couple of Formula D drivers with LSx swaps with stock axles, they told me 255's will be about the maximum amount of tire before the stress becomes too great for the axles and start snapping. so that put some stress on me picking out tires for the rear to match the power/torque of somewhat stock LSx swap for the car.
if I didn't know the above information, I'd put on 275/35/18's on a 18x10 and be happy with it..but it's got me thinking about how shitty it is to have a blown axle.
any thoughts on this?
thanks!
Black R is offline   Reply With Quote
Old 02-13-2012, 11:34 PM   #2230
Dub's
Dub's's Avatar
Hold on, what does Q45 rear end have to do with putting a bigger tire on. Cause i got the Q45/300zx rear end..
Old 02-14-2012, 06:21 AM   #2231
gsracer
nothing that i know of..
Well apparently the ps2's run a lot wider than the azenis and they don't fit under the over fenders. I miss the sheet metal days where if something didn't fit i could just pull it more.
Side note i have two brand new michelin ps2's for sale in 315/30/18.
ANTI-STRETCH NAZI
Old 02-14-2012, 10:01 AM   #2232
sonomadrifter
sonomadrifter's Avatar
sonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the roughsonomadrifter is a jewel in the rough
gsracer: How much rear camber are you running?
I'm trying to figure out what size overs I need (10"+12) with little to no camber for even wear.
Drifting on 245/40r17 on a 9.5 for most of this season.
sonomadrifter is offline   Reply With Quote
Old 02-14-2012, 10:21 AM   #2233
gsracer
1.5 degrees.
ANTI-STRETCH NAZI
Old 02-14-2012, 11:02 AM   #2234
Chops@MVP
Chops@MVP's Avatar
Chops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really niceChops@MVP is just really nice
Send a message via AIM to Chops@MVP
You are my hero! I have followed the many different stages of your car and have always been jealous of the steamroller sized tire you fit under the rear of your S14.
Regards,
Robert
940-683-8282 x20
Robert Del Angel
CLICK HERE FOR OUR FACEBOOK PAGE!!!
FOLLOW US ON TWITTER!!!
Master Distributor for : RPS, Tein, Seibon, Haltech, HKS, Greddy, Cusco, Blitz, Koyo, AEM, Map ECU, Eibach, Tokiko, Power Enterprise, Work, Volk, Fidanza, Defi, ....and so many more!!!
Chops@MVP is offline   Reply With Quote
Old 02-14-2012, 12:35 PM   #2235
mad-ass
mad-ass's Avatar
Don't want to change my rear end out because I already have Kaaz 2way. but I get what you are going for though, bigger flanges = stronger and less drivetrain power loss from engine to tires.
Old 02-15-2012, 06:48 PM   #2236
Black R
Black R's Avatar
I have 50mm rear overs ready to go on my s13, so how wide of a tire can I go with?
Anybody running 315's in the rear of an s13?
I want to run -1.5deg rear camber.
I've heard of people making the overs wider somehow by pinching them?
Old 02-15-2012, 06:54 PM   #2237
Broadfield
Broadfield's Avatar
305's should not be an issue and you would even be able to tuck them a little if you wanted. You will obviously need to get the width and offset of the wheels spot on though. You may even be able to squeeze some 315's under there.... which is what I would do if I had 50mm overs.
My Portfolio
Please Share
Check Out My Builds
Old 02-15-2012, 10:09 PM   #2238
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
I doubt there is a single tire manufacturer that reccomends running a 245 on a 10", and this is a MAX tire thread, so the gereral knowledge base here can't help u. If you were running a 265 or wider I would think that you should be able to get away with only an extra 11mm beyond what a roll and pull will get you. Overfenders seem to start at 20mm though, and you're running even skinnier tires. So you're likely going to need spacers in the rear to run flush once even 20mm overs are on. Or you stop sliding around and slap on some 295s on there, and ditch the spacers
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 02-16-2012, 06:24 AM   #2239
kalypso123
(ノಠ益ಠ)ノ彡
stretched or die... when im in this thread I wanna gag. lol
but enjoy friends, to each his own :0)
Old 02-16-2012, 08:45 AM   #2240
Black R
Black R's Avatar
I really want to be able to run the same size front and rear for lapping days...
I guess I should find out how wide people are able to go up front on an s13.
How sick would 315's all around be?
315/30/18 is less than 4% difference in size from oem 195/60/15.
How about 335/35/17? . Super tall sidewall yo.
Looks like 17x9 to 17x11 or 17x12 vs 18x11 or 18x12...
* the sumitomo htr-z is available in 315/35/17 at $158 (fits 11"-12" wheel).
Or htrzii in 275/40/17 at $111. (fits 9" to 11" wheel)
And the kumho ecsta spt is available in 285/40/17 at $160. (fits a 9.5"-11" wheel)
at tirerack.
So for guys on a budget, some cheap 17x9 / 17x9.5 in low offset and the above htrzii or ecsta spt might be the way to go!
Old 02-16-2012, 11:44 AM   #2241
Black R
Black R's Avatar
It depends on the tire, but a 275 is about as square of a size as you can get for a 10" wheel. A 245 on a 10" would be a stretch to me, but not to the stretch guys.... that's nothing to them. Here are some very old pics of my car with 245/40/18 on a 8.5" +32 up front and a 275/35/18 on a 10" +44 out back...
Did you have any issues with inboard clearance with this setup in the rear?
If not, then a 12" wide wheel should fit perfectly with 50mm overs, and using your example it would need to be a +19.
Old 02-16-2012, 11:53 AM   #2242
Black R
Black R's Avatar
Mad-ss was talking about axles snapping, which just won't happen on q45 / z32tt axles - which is what you use with a q45 rear end.
*Mad, just saw your reply. Stock axles suck! The rear end ratio of the q45 rear end is perfect for lsx gearing. I guess either sell the Kaaz diff and get a q45 rear + clutch diff for it, or be easy on the axles...
Old 02-16-2012, 11:55 AM   #2243
jesse_s13
jesse_s13's Avatar
^^^ Very nice!
jesse_s13 is offline   Reply With Quote
Old 02-17-2012, 05:23 PM   #2244
NAIRB
NAIRB is an unknown quantity at this point
well i was sitting here bored wondering what is really the max width you could run on the front of an s13, so i did this.
so i searched though a bunch of stuff an seen that McCoy was running a 275 stock body with 1.5 camber. (which you can see on page 23 post 667)
his was on a 9" rim with +35 with a 5mm spacer so its +30.
now im gonna running 40mm fenders on my new setup, then was like hmmmm 315s?
so a 315-275 is 40mm. so technaically the tire is 40mm wider just like the fender.
i would like to run a 10.5" rim so gotta figure out how to get this to not hit the coilover. so if is was still +30 the rim would stick in .75" more or 19mm.
so 30-19 is a +11 to make the inside exactly the same.
an which would move the outside of the rim 19mm out more, but you would still have 2mm of clearence. because the rim is 1.5" wider which is 38mm an half is 19mm.
so with a 10.5" rim you would be able to run a +9 to +11 an "technically" it should work, but on here an on the car is a different story.
i was planing on runnning 315-30-18 nt01s on 18x10.5s for my rear track tires. i might just bolt them up to the front an see how it all fits.
sorry for this not having pics an being a bit confusing to read, but i though someone might find this interesting.
NAIRB is offline   Reply With Quote
Old 02-17-2012, 05:25 PM   #2245
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
I think you missed the fact that the 275s poked out a couple inches over stock fenders on his car.
e1_griego is online now   Reply With Quote
Old 02-17-2012, 05:26 PM   #2246
240drifter1
240drifter1's Avatar
240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute240drifter1 has a reputation beyond repute
Send a message via AIM to 240drifter1
Yeahhhh.... that's pretty confusing.
240drifter1 is offline   Reply With Quote
Old 02-17-2012, 05:27 PM   #2247
NAIRB
that was with a 17x10 + 25 with a v710 which run wide iirc
Old 02-17-2012, 05:43 PM   #2248
Broadfield
Broadfield's Avatar
No issues at all on the inside... at least not at that ride height. As I stated earlier, 315's shouldn't be an issue with 50mm overs on an S13.
My Portfolio
Please Share
Check Out My Builds
Old 02-17-2012, 08:11 PM   #2249
Black R
Black R's Avatar
I just checked out a local car that has weld rts 15x11.25 5.5" backspacing on an s13 5lug spindle with z32 brakes.
Apparently they have a brake caliper clearance option.
http://weldracing.com/street-perform...15-in-s71.html
These would be great for anyone looking for an affordable wide wheel.
I'll take some pics tomorrow.
Old 02-17-2012, 09:06 PM   #2250
benz88
benz88's Avatar
benz88 is an unknown quantity at this point
Whats the widest tire you can fit under stock metal on an S13? What would be an ideal Width wheel and offet? im thinking of going with 17's all around in a 10"width
benz88 is offline   Reply With Quote
