Old 09-28-2012, 08:37 PM   #1
1slowsilvia
1slowsilvia is an unknown quantity at this point
Exclamation HELP energy Supension bushings INSTALL!!!
so NO write up are the same all have conflicting answers and none give you ANY answers.... WTF do i do. I have cups in each spot where bushings go. i cant knock them out. idk WTF to do. how the FUCKING SHIT do I make these bushings fit? wtf do i take out why do the directions give you NO answers????
btw its a 1998 S14
1slowsilvia is offline   Reply With Quote
Old 09-28-2012, 08:40 PM   #2
AS240
AS240's Avatar
Trader Rating: (18)
AS240 is an unknown quantity at this point
Feedback Score: 18 reviews
http://zilvia.net/f/s-chassis/410117...ion-guide.html
there's lots of other threads too. just keep searching until you find what you're looking for
AS240 is offline   Reply With Quote
Old 09-28-2012, 08:43 PM   #3
AS240
AS240's Avatar
Trader Rating: (18)
a lot of times after you burn/press the old bushing out, there is an inner metal sleeve that has to be cut out before you can put the new bushings in. best way is to take a hack saw blade off a hack saw and cut through it by hand. cut in at least 3 different spots. then take a socket that is the same size as the inner ring and hammer the crap out of it.
Old 09-28-2012, 09:16 PM   #4
1slowsilvia
I've been searching ALL night... there is NO REAL ANSWERS even the damn install guide they give you is bullshit.
Old 09-28-2012, 09:20 PM   #5
AS240
AS240's Avatar
Trader Rating: (18)
what specific bushing are you having trouble with?
Old 09-28-2012, 09:23 PM   #6
1slowsilvia
the front bushings that are closest to front of car on the rear subframe.... the inner rings on the top (not the bottom one that you cant fuck up or subframe is trash basically) I hammer at them with a chizzel and hammer and they bend but wont come out its like they are fucking melded with the cup of subframe...
Old 09-28-2012, 09:28 PM   #7
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
chisel harder. heat them up.
SW Fab
shiftdrift is offline   Reply With Quote
Old 09-28-2012, 09:32 PM   #8
AS240
AS240's Avatar
Trader Rating: (18)
How to Install New Subframe Bushings (240sx) - YouTube
Old 09-28-2012, 09:34 PM   #9
1slowsilvia
The bushings on fire those are the ones im trying to remove the clip from on the top.... that is correct right?
Old 09-28-2012, 09:45 PM   #10
AS240
AS240's Avatar
Trader Rating: (18)
240SX Rear Subframe Urethane Bushing Installation - YouTube
in this vid the guy says that the rear doesn't have the sleeves but the front does. prolly what you're talking about. jump to 4:45
so what i got from this is that you leave the collars in on s13's, but you have to cut them out on s14's. fckin nissan bs
Old 09-28-2012, 09:53 PM   #11
1slowsilvia
makes no sense to me idk wtf i need to do tbh.... too many conflicting answers....
Old 09-28-2012, 10:03 PM   #12
AS240
AS240's Avatar
Trader Rating: (18)
the second vid was a s14 subframe. you have to cut and chisel the collars out. they are only on the front.
the easiest way to do it is get a hacksaw and do what the guy in this video does:
How To Remove Control Arm Bushings - YouTube
Old 09-28-2012, 10:24 PM   #13
1slowsilvia
wish he didnt film with a fucking potato....
I'm gonna go outside and take some pics and burn out the back bushings just to knock them outta the way... I also gotta take out my gas tank have a leak and gonna seal it up with this gas take sealer kit i bought from auto zone bought 2 kits acutally lmao im gonna fill this fucker good!
Old 09-28-2012, 11:05 PM   #14
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
it wasn't easy, burnt mine out too then had to remove the inner collars with a air hammer. wouldnt have came out without it.
rebornS14 is offline   Reply With Quote
Old 09-28-2012, 11:34 PM   #15
1slowsilvia
^^^ thats diff bushings mine are the front bushings on the subframe... I just finished the rears... lmao using sawzaw at 1am neighbors gotta be pissed... then i burned the bushings out of rears and they are ready to go test fitted and all such a breeze. gonna do fronts tomorrow just gotta get those clips they are a CUNT!
Old 09-28-2012, 11:52 PM   #16
Wabash9000
Wabash9000 has a little shameless behavior in the past
I was able to get mine out without any fire. I don't remember how I did it though. I do remember sawing through the ring like was shown in the s14 video but I got the rubber out somewhat cleanly.
Wabash9000 is offline   Reply With Quote
Old 09-29-2012, 12:04 AM   #17
rebornS14
rebornS14's Avatar
^^ did you use a press?
Old 09-29-2012, 12:49 AM   #18
1slowsilvia
for there to be no mess sounds like he deff used a press.
Old 09-29-2012, 08:29 PM   #19
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
I just used a reciprocating saw and cut out the big chunk of rubber in the middle, then turn the blade sideways and cut away the rubber against the metal sleeve..
Then just make a cut in the sleeve down to the sub frame.
Hammer + big screwdriver or chisel: Fold the sleeve inward until the tension gives and the sleeve pops out.
I found that burning the bushings just makes a lot of smoke, smells bad, and makes the neighbors wonder why i'm setting my car on fire
nismoracingsx is offline   Reply With Quote
Old 09-29-2012, 08:42 PM   #20
Alamo_City_210
Alamo_City_210's Avatar
Alamo_City_210 is an unknown quantity at this point
ImageUploadedByTapatalk1348973196.590307.jpgImageUploadedByTapatalk1348973215.222890.jpg
Cut 2 reliefs and they will come out. I just did mine. Get over the frustration and think about how they should come out. Believe me, I wanted to quit too lol
Alamo_City_210 is offline   Reply With Quote
Old 09-29-2012, 08:44 PM   #21
Alamo_City_210
Finished product.
File Type: jpg ImageUploadedByTapatalk1348973325.156829.jpg (85.5 KB, 17 views)
Old 10-03-2012, 02:55 PM   #22
cnazzaro240
cnazzaro240's Avatar
cnazzaro240 is an unknown quantity at this point
the best way i found is to burn them out, then use a sawzall to cut a slit in the inner sleeve(carefully), then use an air-chisel to shoot them out, and to put the new ones in i just used the 130$ press from harbor freight. hope that helps
cnazzaro240 is offline   Reply With Quote
Old 10-03-2012, 04:10 PM   #23
Alamo_City_210
no press is needed. save yourself 130$. just put a lil grease on the outside as it states on the instructions and they slide right in.
Old 10-03-2012, 04:58 PM   #24
cnazzaro240
ya you dont really need the press i had it already and also was putting in solid subframe bushings which did not go in easy even with the press
Old 10-04-2012, 11:40 AM   #25
Br Dori
Br Dori's Avatar
Br Dori is an unknown quantity at this point
If your still looking for a good guide, look for project car last magazine they changed up all the bushings. It's a really good guide and magazine.
www.FlawlessMotion.net
Br Dori is offline   Reply With Quote
Old 10-16-2012, 04:31 PM   #26
In The Works
In The Works's Avatar
In The Works is an unknown quantity at this point
OK not trying to thread jack but I figure I will jump in on the same subject. I didn't burn my old ones out either, I just saw zalled them out. I took everything out of all 4(this is on an S14) Now the ES bushing are pretty loose in there. I keep seeing 2 diff words. 1 says you take the cups out on the S14's and others say you need the cups in there for the ES bushings.
Anyone know for sure?
In The Works is offline   Reply With Quote
Old 11-19-2012, 10:46 AM   #27
Alamo_City_210
There are 4 sleeves total that need to be taken out. The top 2 which is the pic I posted previously and 2 bottom sleeves. You can hit them out by heating up the outside and with some sort of chisel, hit betweent the lil fin looking things from te bottom.
Old 11-19-2012, 11:13 AM   #28
inopsey
the best way is NOT to burn them out unless you want to weaken the integrity of your subframe. weather or not you need to remove the outer race on the bearing depends on if you have full replacement bushings (nismo) or not (ES).
Old 11-19-2012, 12:16 PM   #29
oni jake
oni jake is an unknown quantity at this point
What? Melting rubber does NOT have enough energy to weaken or distort your subframe. Hands down, the best way to remove them is with FIRE! Then use regular old man power to finish the job.
oni jake is offline   Reply With Quote
