Old 12-31-2012, 12:44 AM   #2671
doodoojin
doodoojin's Avatar
doodoojin is an unknown quantity at this point
285/35/18 on 10.5 +15 with a 20mm spacer on the 6666 RB kit. I could go pretty wide in the back easy, but this is good for now. Now to figure out the fronts...... any pointers for a 10.5 on a S13 front. I am open to modding the coliover mounting positions or whatever. As far as where I want the wheel in the guard, a 5mm or less spacer would be great.
doodoojin is offline   Reply With Quote
Old 12-31-2012, 02:47 AM   #2672
TigerII
TigerII is an unknown quantity at this point
That looks pretty good to me. 20mm isn't too bad compared to what some of the Tra Kyoto kit fitted cars are running.
TigerII is offline   Reply With Quote
Old 12-31-2012, 01:38 PM   #2673
Corizer
Corizer is an unknown quantity at this point
285 35 18 on 10.5jx18
Corizer is offline   Reply With Quote
Old 01-02-2013, 06:10 PM   #2674
jr_ss
Another shot of the 285's...
Old 01-03-2013, 01:11 AM   #2675
mad-ass
mad-ass's Avatar
Question for you guys.
I'm running 18x10+38 RPF1's with 275/35/18 on the rear of my S14.
I was rubbing wheels on the Rear LCA [the forward portion of the "A" arm] when the car was lowered[tucking 1/2" of tire in the rear with about 0.5degree of camber, 0 toe, 3/4" fender pull/roll on stock metal] on coilovers.
I have sold the coilovers and now am on KYB GR-2's with Tein Lowering springs so no more problems, but I will eventually lower the car back down to it's previous height.
How can I modify the stock LCA to keep it just as strong but give me more wheel clearance? [with out buying after market tubular arms of course]
Old 01-03-2013, 04:29 AM   #2676
jr_ss
Absolutely... You'll have to notch where the wheel was hitting and box it back in. If I recall correctly, Toby has the same thing done on his S13.
Old 01-03-2013, 04:42 AM   #2677
mad-ass
mad-ass's Avatar
I personally enjoy telling people that I tuck 275's in rear with good alignment on stock fender, so this is a must do so I can have the car lower then pictured above when I get coilovers again.
Any pics/ideas would be greatly appreciated.
Old 01-03-2013, 05:11 PM   #2678
dillonbear
dillonbear is an unknown quantity at this point
looked at this thread so long it hurt to blink
dillonbear is offline   Reply With Quote
Old 01-03-2013, 05:37 PM   #2679
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
So i picked up some 17x8 + 35 and some 17x9 + 35 Wheels and i'm finally going to be getting around to getting them put on. I originally was planning on trying to squeeze a 275/40/17 on the 17x9+35's and do a 235/40 or 45/17 on the 17x8+35 But it seems like a 255/40/17 might be the better idea for the 17x9.
This is going on a S13 Coupe. with rolled fenders (can pull if need be but not looking to do any major massaging. Just not sure if the 275 would be a better idea to hold a 500+WHP hit.
Still debating on what tire, Trying to get away from running a drag radial all the time.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 01-03-2013, 05:38 PM   #2680
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
im tucking 335's on my s13...... but definately not on a stock fender....lol
JFoxx is offline   Reply With Quote
Old 01-03-2013, 05:47 PM   #2681
jr_ss
I'm assuming you hit because the angle of that arm was actually at an upward slope towards your ball joint, rather than remaining level/flat to the ground. If this is the case, you have a few options without really modifying the control arm.
1. You could get roll centers, which would correct some of your geometry in the rear and move the arm closer to level. This would probably let the car ride better and lessen the amount you may have to clearance on the control arm.
2. Add a small spacer in the rear (2mm or so). However, you'll have to pull the rear fenders slightly more.
3. You could grind the lip of the control arm away just where the rim impinges.
4. Aftermarket LCA's are an option and would give you the best all around combination of clearance and adjustability.
However, if you want to absolutely modify and give the best clearance, I would mark and pull the arm. Notch it, then reinforce the LCA with the same or heavier gauge material, connecting to the existing portion of the arm not needing clearancing.
I have roughly .500" between my LCA and wheel. Im also running +36 rear wheels and not nearly as low as you were. I intend to have my fender arch even with the top of the tire, not really looking to tuck.
I've been looking for photos of notched LCA'S but no dice as of yet. It seems that everyone wants to be herraflush and sacrafice grip for fitment.
Old 01-03-2013, 05:51 PM   #2682
jr_ss
A 265 would probably be the most you'd be able to squeeze on a 9. If you look at some of the tires available they run extremely wide. I had 265/35/18 Azenis RT615's and they were less than an .125" or an 1/8" smaller than the 275's, which is why I went to 285's.
Old 01-03-2013, 06:17 PM   #2683
mad-ass
mad-ass's Avatar
Roll center adjustment with stock LCA at that height would also require a notching/reinforcement, because at that point, the LCA would be berried into the wheel.
spacer is not an option as I absolutely want to be able to stay hub-centric, so the minimal amount of spacer I would use is 10mm slip-on with built in hub-lip/ring.
I have ground down the lip leaving about 1mm of metal on it still not wanting it to bend, but it's still so scary close to the wheel.
I don't care for the aftermarket LCA's as I am not doing any professional racing or drifting.
yeah, i have no luck in finding anyone with notched LCA's either. but I want to be herraflush and have no camber either
i unno..trying something new here, not trying to prove anything to anyone but to myself.
I want to be about 1/4" lower then this picture eventually.
Old 01-05-2013, 04:59 PM   #2684
mojos13
mojos13 will become famous soon enoughmojos13 will become famous soon enoughmojos13 will become famous soon enough
Looking for GRIP on my 1JZ powered S13-hatch, figured I need 245/35/18's or 17's in front and 285/35/18's in the rear.. willing to roll/pull but no over-fenders or wheel spacers, no drifting/racing just wanna have a killer ride :-) but, don't know where to start :-( ..any advice is greatly appreciated....Thanks ZILVIANS!
mojos13 is offline   Reply With Quote
Old 01-05-2013, 07:04 PM   #2685
JDM SPUG
JDM SPUG is an unknown quantity at this point
If you don't mind rolling and pulling just go for some 285/30-18 or 295/30-18 (common size for 993 Porsche Carreras) in the rear and a 245/40-18 in the front.
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 01-06-2013, 09:20 AM   #2686
mojos13
Yes I like those but, what about offset and rim sizes, that's where i'm confused as hell..lol, I have old-school K-SPORT coil-overs but don't wanna buy anything that's gonna be way too much hasle to make it work and want to figure this out before I have the car painted of course!..Thanks guys!
Old 01-06-2013, 09:43 AM   #2687
JDM SPUG
You have an S13 so I'm really not too sure. But on my car I'm running 18X10.5 ET30 with ta 275/35-18 with less the -2 degrees of camber and I still have about 10mm from the inner lip to the coilovers and i could probably even go up to a 295/30-18 and I only have my fenders rolled. NO PULL.
So if you're willing to pull I would probably go with a 18X10.5 ET22 Varrstoen or something like that.
Old 01-06-2013, 10:17 AM   #2688
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
He would need a pretty decent pull to fit a 285 on a 10.5 +22 on an S13. I'm running 18x11 +30 on a 285/30/18 and it's absolutely perfect. That's with -2.75 degrees of camber, about a 25mm pull and I'm fairly low. Mojos13 If you want to be low at all you will also need wide front fenders to fit a 245 on an S13. Not to mention you will need to modify the upper wheel housing lip, back wheel housing lip and relocate the drivers side chassis harness. Otherwise a 245 will rub on all of those while at full lock.
My rear fitment and pull for reference... this is probably exactly what you are looking for:
Front fitment: 18x9.5 +12 with a 245/35/18 with -2.5 degrees of camber and 20mm wide fenders:
Let me know if you need any other pictures to check out.
Note: with an 11" +30 I had to modify the upper wheel housing, and notch the OEM lower control arm. So you may want to roughly stick to the size that JDM SPUG mentioned... a 10.5" in the +24 range or a 10" +17 range.
You can also go here if you want to see some of the different size setups I have had over the years. Let me know if you need additional close-up fitment pics of any of those setups.
http://broadfield.wordpress.com/2010...hbackexterior/
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 01-06-2013, 10:48 AM   #2689
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
^^^looks freaking sick....your projects never disappoint.
2muchboost is offline   Reply With Quote
Old 01-06-2013, 12:06 PM   #2690
mad-ass
mad-ass's Avatar
Broadfield, can you please take a picture of your rear lower control arm that's been notched?
I'm scratching my head on this one to figure out how to actually do it.
Thank you.
Old 01-06-2013, 02:02 PM   #2691
mojos13
Broadfiled, you're absolutely correct!...your rear fitment is exactly what i'm looking for, not sure about the notching/wheel housing mod ( picture plz ) but it's straight forward & worth considering, JDM SPUG's sugestion of 10.5 +22 or a 10.0 +17 will be alot easier for a NOOB like me??...245's in front sounds like too much work/science for me, how about 17" rims or 235's on 18" or is that much stagger gonna make my ride look/steer like crap?..Thanks for your help, your car is absolutely gorgeous and I know I ask for TOO MUCH!
Old 01-06-2013, 03:52 PM   #2692
kewilso3
kewilso3 is an unknown quantity at this point
I run a 245/40 on a 17x9.5 +19 up front on my s13 with just a mild roll (you can see in this picture the edge isnt flat). 3 degees of camber. 255 should work with a slight pull
kewilso3 is offline   Reply With Quote
Old 01-06-2013, 03:53 PM   #2693
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
As I've posted in this thread, I run 255 in front with no pull.
e1_griego is offline   Reply With Quote
Old 01-06-2013, 04:24 PM   #2694
Broadfield
Broadfield's Avatar
You are not very low though... what you can fit is GREATLY going to depend on ride height. I use to run a 245 with zero camber, stock fenders, no roll, no pull, no nothing.... but my ride height was as high as yours.
My Portfolio
Please Share
Check Out My Builds
Old 01-06-2013, 04:47 PM   #2695
Grimace
Grimace is an unknown quantity at this point
Send a message via AIM to Grimace
This is after the pull/alignment.
Specs,
Front.
18x9 +14
275/35/18 Nitto NT-05
-1.15 camber
Rear
18x10.50 +20
285/35/18 Nitto NT-05
-2.25 camber
Not sure how much I pulled the fenders, but It maxed out an eastwood roller.
Grimace is offline   Reply With Quote
Old 01-06-2013, 05:33 PM   #2696
Chris28
Chris28 is an unknown quantity at this point
255/40/17 Toyo RA1's all around. 17x9 +25 front, 17x9.5 +30 rear. -3 camber up front, -2 in the rear. Fronts are rolled, rears are rolled and pulled.
Chris28 is offline   Reply With Quote
Old 01-06-2013, 06:16 PM   #2697
mojos13
Chris28, since you run 255/40/17 in the front, 245/40/17 should be cake on the same 17/9 +25 rim correct?...that's the kind of info i need so i can get my rims/tires and start massging/hammering stuff to make fit. I don't need to be so much slammed/hella-flush, just don't want the 4X4 look...lol!
Old 01-06-2013, 06:29 PM   #2698
mojos13
Yeah that looks doable to me, the biggest issue is the 285's that i need in the rear, what do you guys think of the 245/40/17 in front & 285/30/18 rear???
Old 01-06-2013, 06:36 PM   #2699
ka-titties
ka-titties is an unknown quantity at this point
Specs,
Front.
18x9 +14
-1.15 camber
Rear
18x10.50 +20
-2.25 camber
how the hell do you have a rear windshield wiper?
ka-titties is offline   Reply With Quote
Old 01-06-2013, 06:54 PM   #2700
Chris28
You might run into some issues with inboard coilover clearance, nothing a slip on spacer can't fix though. It's not a great picture, but this is a 245/40 on a 17x9.5 +10 with about -2.5 degrees of camber up front. I have modded knuckles so I rub my sway bar and tension rod, but I don't have any issues with fender clearance.
As far as 245/285 stagger, that might give you some understeer. How much power are you making? This is the maximum tire thread haha, but do you need that much tire in the rear?
