need help with r33 brake swap
i Have a s13. does 300zx rear rotors work with the swap and what size rims with correct offset should i use to fit with out using spacers. if any body has r33 skyline rims for sale ill like to buy them bec i know they will fit.
![]() Join Date: Jun 2007
300ZX rear brakes & rotors are identical between R33, 300ZX (Z32) & R32.
As far as offset goes, you may need spacers, you may not... provided you have 16" rims or more. Not sure if they will fit on 15's. There is an "offset 101" thread. Give it a read.
i been reading up on the swap im feeling 17 inch rims right now, that's what i have seen alot of people use but i do not want to use spacers that's for sure. and thanks ill check that link forr the offset for dummies.
#4 | |
![]() Join Date: Apr 2006
Trader Rating: (55)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 55 reviews
If u want stock 17" wheels that are cheap go for 350z rims i have a set for 400 with tires i can sell if ur interested text me 973 513 3613 ![]() |
#9 | |
Been using them for daily and drifting for 2 years now, and the best part is that I don't care if it got curb rash, or dented because I could always replace them. If you want to cheap out get either a 300zx stock 16 inch or 240sx SE wheels. They both have the same off set of +40 and they clear the front brakes. As for the 240sx SE I have not tried them on the rear with z brakes, make sure you try them on first before buying. |
