Old 04-23-2013, 02:25 PM   #2821
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Rebuilding some bbs rs's into track wheels.
They were 16x7.5 +30.
They will be 16x9.5 +6 w/ 245/45
16x10 +0 w/255/50
Should have them done next month some time when the new lips come in.
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 04-23-2013, 02:39 PM   #2822
Zumin
Zumin is an unknown quantity at this point
So… ive been going through this all and i haven't been able to find exactly what I'm looking for. I'm have a little trouble deciding on my rear tire set up…
1997, godspeed toe arms, (not sure which RUCA I'm gonna get) ive pulled my fenders in the rear and rolled them up front.
i have a set of 18x9.5 RPF1 SBC +15 for all four corners.
before ill be installing the wheels/tires and coilovers all at once (BS coilovers)
i want to go with a 245/35 in the front, I'm pretty sure that'll fit fine and will look pretty good.
out back I'm trying to decide between a 265/35 or a 275/35… i don't want to run a lot of camber, and since my rear fenders are pulled, i don't think ill have to, i also don't want bulging tires, either. if anything id like my rear to be square…
File Type: jpg 65188_10151389015116616_185390382_n copy.jpg (105.7 KB, 40 views)
Zumin is offline   Reply With Quote
Old 04-23-2013, 02:45 PM   #2823
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
Start with the 265s because of only running +15. Then if they still fit with a 5mm spacer, up the ante to 275s on your next set. Or maybe by then you'll get some custom offset wheels... you could easily run +30 at that width.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 04-23-2013, 03:04 PM   #2824
CaptainVlad
CaptainVlad's Avatar
CaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really niceCaptainVlad is just really nice
Do you guys think 17x9.5 +17 with a 255/40 will be pushing it up front, on stock fenders? I am not low like some of the people on here, but I am pretty low. (about 3.5 inches from ground to frame rail)
CaptainVlad is online now   Reply With Quote
Old 04-23-2013, 06:22 PM   #2825
GripTerror
GripTerror is an unknown quantity at this point
^I've had that, you will have to bend the fender ALOT to the point of cracking, but man does the car drive good.. and the harness has to be relocated or raised and zip tied it will rub otherwise. I also removed the inner plastic shielding.
Uuuh being slammed like that, no chances, that's retarded raise your car up.
GripTerror is offline   Reply With Quote
Old 04-23-2013, 08:38 PM   #2826
CaptainVlad
GKTech roll center correcting spindles are going on the car in less than a month, so raising it too much will actually also be bad...
Old 04-24-2013, 12:13 AM   #2827
SofaKingFast
Trader Rating: (43)
SofaKingFast is an unknown quantity at this point
Feedback Score: 43 reviews
Send a message via AIM to SofaKingFast
Hey guys, I've found similar setups to what I'm trying to run on this thread, but nothing exactly. Here's my setup:
Car: S14
fender modifications: F+R fenders rolled, no pull
camber settings: -3 front, 0.5 rear
wheel size: 17x9.5 +30 front and rear
purpose: autox/track days
I want to run a square setup with 255/40 all around, thoughts?
Ryan
SofaKingFast is offline   Reply With Quote
Old 04-24-2013, 03:59 AM   #2828
mad-ass
mad-ass's Avatar
I can't see you fitting 17x9.5+30 in front with coilovers, it's possible with normal shock/spring combo though.
Old 04-24-2013, 08:44 AM   #2829
simmode1
simmode1's Avatar
It'll be an extremely tight fit, but it's possible. You have to pick your coilovers VERY carefully. Megan's with their extended bracket add-on might be able to do it, but McCoy did 17x9.5+28 with 255's up front on an S13. But it should be noted that his coilovers were a custom Koni Yellow/Ground Control setup.
But if it's all the same, I'd say pick something other than 17x9.5+30. Fitting 255's up front with that ain't for the newly initiated, IMO. The pics above literally have only millimeters of clearance and MOST coilovers would even get close to that kind of room.
Old 04-24-2013, 09:24 AM   #2830
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Yeah, 9.5+30 prob won't clear the coil.
With a 9 +22 I run a 255 in front. My setup provides a +14mm increase in inner clearance, and 2mm less outer clearance versus a 9.5 +30.
My friend Tyrone put 255s all the way around on his s14, 17x9 +22 all around: http://zilvia.net/f/cars-sale/512890...-15-300-a.html
e1_griego is offline   Reply With Quote
Old 04-24-2013, 12:53 PM   #2831
SofaKingFast
Trader Rating: (43)
Thanks for the reply guys, its nice to see actual intelligent responses for a change. Simmode thanks for the photo. I'm currently running Apexi coils with a moderate drop almost identical to the link e1_griego posted. If I spaced out the wheels 5mm would the 255's clear the front fenders without pulling them?
E1_griego, do you know if Tyone pulled the rear fenders at all? I can't tell from the pics he posted. Are there any issues running 17x9.5 +30 with a 255/40 tire in the rear?
Old 04-24-2013, 01:42 PM   #2832
e1_griego
e1_griego's Avatar
Trader Rating: (24)
I'm running 9.5 +33 in back of my s13 with a 255. With an s14 you shouldn't have a problem.
He didn't do a pull, just a roll, but he's running -2.5* or so in back.
Old 04-25-2013, 08:01 PM   #2833
SofaKingFast
Trader Rating: (43)
I just picked up my track wheels today. I did a quick test fit and just like you guys said i'll need to run a 5mm spacer up front to prevent rubbing. From the looks of it I should be able to get away with a 255/40/17 setup all around but we'll see after I get the tires mounted. I'll be sure to post up pics, thanks again for everyone's help.
Old 05-10-2013, 07:05 PM   #2834
SofaKingFast
Trader Rating: (43)
Whew! 255/40/17 (17x9.5 +30 w/ 5mm spacer) BARELY clearing my apexi coils without rubbing.
Sent from my DROID X2 using Tapatalk 2
Old 05-10-2013, 07:52 PM   #2835
gostrider
gostrider is an unknown quantity at this point
225 40 18 all around
+12 all around
9.5 all around
stock fenders
-1.5 camber
240 with illegal engine mod.
gostrider is offline   Reply With Quote
Old 05-10-2013, 08:04 PM   #2836
JDM SPUG
JDM SPUG is an unknown quantity at this point
^225 is definitely not MAX rubber.
1998 240sx 2jz swap in progress
2006 FULLY built WRX Rotated w/ PPG's
JDM SPUG is offline   Reply With Quote
Old 05-10-2013, 08:05 PM   #2837
jr_ss
+12 all around
9.5 all around
stock fenders
-1.5 camber
Wrong thread hoss...
This isn't the stretch thread, its the MAX tire thread...
Old 05-10-2013, 08:08 PM   #2838
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
add 100mm and then you'd be in the right place....
Drift_FX is offline   Reply With Quote
Old 05-11-2013, 11:58 AM   #2839
Zumin
235/40
NT555
Rpf1 SBC 18x9.5 +15 on all corners
Old 05-11-2013, 12:03 PM   #2840
Zumin
ImageUploadedByTapatalk1368295303.565994.jpgImageUploadedByTapatalk1368295314.123114.jpgImageUploadedByTapatalk1368295326.607157.jpgImageUploadedByTapatalk1368295335.873554.jpg
Just ordered battle version RUCAs and SPC tension rods,
BC coilovers just got delivered to the shop
Old 05-11-2013, 08:37 PM   #2841
SofaKingFast
Trader Rating: (43)
^ Any reason you didn't go wider or did the +15 offset not allow it? How much camber are you running? I hope to get a meaty setup for my te37's but I need to pull my fenders. For now here's my track/autox setup:
Rota p45r +30 all around + 5mm spacer to clear coils
255/40/17 all around
-3 degrees camber front
-1 degree camber rear
Stock front fenders
Rolled rear fenders
I'll take better pictures when I get my meaty volk setup .
Old 05-12-2013, 07:03 PM   #2842
Zumin
I'm not sure yet, haven't lowered it. I could easily run a 275, my flared fenders help, I could probably buy a 10.5 and run a 285.
I plan on running 1.5 degree out back and 2 in the front. Anyone see a problem with this? Rubbing shouldn't be an issue, I had all fenders pulled when I did body work
Old 05-13-2013, 08:12 AM   #2843
Romango3
Romango3 is on the path to ruinRomango3 is on the path to ruin
Romango3 is offline   Reply With Quote
Old 05-21-2013, 08:51 PM   #2844
Zumin
Function! ImageUploadedByTapatalk1369191007.433481.jpgImageUploadedByTapatalk1369191019.995006.jpg
Need help on alignment. All I keep finding is drift crap.
I can run 0-1 degree of camber out back but I'm not sure what is ideal. Also not sure what to put my camber and caster to up front...
Daily driver, occasional road course and auto cross. Will hopefully being seeing tail of the dragon too. I also put about 70 highway miles on it everyday driving to school
You guys got any ideas?
Old 05-21-2013, 09:23 PM   #2845
mad-ass
mad-ass's Avatar
get it to close as stock as possible. and slight amount of front caster increase[0.5 degree+ or so].
Old 05-26-2013, 02:35 AM   #2846
KiwiZenki
KiwiZenki's Avatar
KiwiZenki is an unknown quantity at this point
Liking the rubber gents! I'm in the right place now. 16x8+10 225/50/16
1995 SE Hardtop - Sold
Bicycle
KiwiZenki is offline   Reply With Quote
Old 05-26-2013, 03:51 AM   #2847
mad-ass
mad-ass's Avatar
225? that's the size of my spare tires my man.
Old 05-26-2013, 11:27 AM   #2848
KiwiZenki
KiwiZenki's Avatar
Haha, i know they aren't very wide but they're what fit these wheels. Pretty meaty look though.
Bicycle
Old 05-26-2013, 01:24 PM   #2849
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
There are a lot of tires that'll fit that wheel, including a 245.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 05-26-2013, 01:30 PM   #2850
silviaks2nr
silviaks2nr's Avatar
This is the max tire fitment thread not meaty looking tire thread... Anyone can put narrow wheels with bulgy 225s on their 240sx.
