Old 05-15-2013, 03:20 PM   #3301
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Originally Posted by ultimateirving View Post
Oh ok. So when you ordered the tune you said I have s3 cams waiting to go in? And had the tune designed around it ?
Nope. I've had the tune for over a year now. I spoke with Ben Pila at Jim Wolf Technology on Friday of last week and he confirmed that the JWT cams I installed are good to go on the tune I have, and no adjustments were needed.
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 05-15-2013, 03:35 PM   #3302
Tom N
Tom N is an unknown quantity at this point
I take it you don't have a S14/15 engine with VTC?
I'm sure the tune is maf based but I would still think you would benefit from tuning for the new cams. I have no experience with tuning a SR motor yet but in other engines I have always seen a increase in hp after dialing in the motor on the new cams. Not that you need to but I'm sure you will get more power out of them if you did.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 05-15-2013, 03:47 PM   #3303
BlackZenkiS14
Yea, exactly. S13 Blacktop with MAF based JWT tune.
Just did a few pulls, AFR is 11.7 all day at WOT.
I dont actually think there is any way for JWT to modify my current tune to be more appropriate for these cams.
-Kyle
Old 05-15-2013, 03:54 PM   #3304
ultimateirving
ultimateirving's Avatar
Thast what i was getting at.
But if your happy with they way its pulling dont change it.
11.7 is a fine AFR, i just think with a retune the cams might be able to help with spool and powerband
Z32 with lq4 swap
Old 05-15-2013, 03:58 PM   #3305
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
S3 cam gears work best installed with OEM setup. I played around with that, and found no 'major' difference/stock was the best compromise.
A tune is NOT needed either with his setup, it will work just fine. Don't get me wrong it could be used to extract some extra power, but nothing world changing nor worth the cost.
How do I know? My car doesn't have a 'cam tune' and works great
Old 05-15-2013, 04:18 PM   #3306
BlackZenkiS14
I gotta admit though, I cant tell if its faster or not lol I mean, its 90 degrees today, and last time I drove the car it was 60 degrees. The power feels much more linear, and less snappy. Guess I wont know til I hit the drag strip.
Now, just cooling and oiling mods next!
-Kyle
Old 05-15-2013, 06:36 PM   #3307
tabasco122
tabasco122 is an unknown quantity at this point
I miss my car so much. i really wish i could have tested the setup before i parted it out.
tabasco122 is offline   Reply With Quote
Old 05-18-2013, 12:16 PM   #3308
SR20HAYES
SR20HAYES is an unknown quantity at this point
Ok so I'm installing the turbo and it seems like no matter how I run my lines the coolant return is in the way for an intake. I don't have an intake yet, but looks to be no room to route it with the line. If anyone could post up a pic of how they routed their turbo lines that would be great. I have an S14 sr20 with the 3" inlet housing 2871r. I'm using the circuit sports lines as well.
Here is a pic of me mocking things up. I saw a pic online of someone else's setup and their coolant return line was much longer which seemed to give the intake a bit more room, but my circuit sports line is not nearly as long. I'm sure there is an easy way to solve this. This is my first time doing a turbo install and I'm a bit lost. So please let me know if I'm routing the lines wrong or what you think im doing wrong.
Oh and the coolant feed line looks to be in the way in the pic, but its just above where my intake(or I should say my coupler) would route giving me just enough clearance.
SR20HAYES is offline   Reply With Quote
Old 05-18-2013, 12:44 PM   #3309
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Mine always hit my inlet pipe on my 2" inlet.
I would just wrap it and let it rub your coupler. Won't do any harm as long as its wrapped good.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 05-18-2013, 12:54 PM   #3310
SR20HAYES
Perhaps, but the extra 1" may cause it to rub a little much..if no other solutions seem evident then I may try that.
Would be nice if i had a 3" elbow to mock up, but no local shops have one other then the really long ones which I would have to cut to fit, but for the $60 they are charging I'd rather wait and order the right elbow.
:EDIT: Ok, after talking to a few more people threw FB it appears you were right. wrapping it and letting it rest on the intake is the best solution. Thanks for the help.
Old 05-18-2013, 02:16 PM   #3311
ultimateirving
Also. Make sure ur 90* is poinTed towards the engine hard to tell from the pic. . It will give you more slack to play with. |.||,
Z32 with lq4 swap
Old 05-19-2013, 12:28 AM   #3312
SR20HAYES
Not sure what you mean. The 90 on the coolant return is facing down. The engine mount is close so I can't really do it another way. Might be able to face it towards the front of the car but it would be running along the block.
Old 05-19-2013, 12:57 PM   #3313
ultimateirving
That's what I meant. Try and cockeye it pointed forward. Any extra slack should be enough to get a 3" coupler on and let it ride on top.
Z32 with lq4 swap
Old 05-19-2013, 01:18 PM   #3314
EsChassisLove
Trader Rating: (26)
Dude just run the damn thing it isn't going to hurt anything lol
Old 05-19-2013, 08:22 PM   #3315
cotbu
cotbu's Avatar
I concur!!!
Old 05-20-2013, 10:12 AM   #3316
SR20HAYES
Lol I'm in no rush. I just wanted to make sure It was right even if it means second guessing myself and asking stupid questions on the forums. Thanks for the help.
Old 05-20-2013, 11:02 AM   #3317
datsr510
datsr510's Avatar
datsr510 is an unknown quantity at this point
Hello fellow 2871 users, here is some info on my current setup:
2871r .86 a/r
BC 264 cams
550 Tomei injectors
Tomei ras
Cosworth HG
ARP studs
Safc2 for tune @ 15lbs
Also I had to change the original internal wastegate to an hks one.
Anyways I made 340.9 whp & 329.5 torque on dynojet
TIGER RACING FOR ALL YOUR SR NEEDS
datsr510 is offline   Reply With Quote
Old 05-20-2013, 11:53 AM   #3318
MedHat240sx
MedHat240sx is an unknown quantity at this point
The problem is the rod is now too short. I extended to rod end all the way out and still can't attach it. Maybe if i preload the shit out of it would, but obviously I wouldn't want to do that.
I had the same problem then i bought a Waste gate actuator extension from Z1 Motorsport super cheap and 100% adjustable... then i went external cuz i got a brand new turbonetics for 190.
MedHat240sx is offline   Reply With Quote
Old 05-20-2013, 12:02 PM   #3319
BlackZenkiS14
Hey guys, running an oem internal Wastergate actuator, and it falls off of boost at high rpm.
Does installing an HKS actuator correct this? I'm running a Greddy Profec_B for boost control, so i just need something that will maintain 17psi to redline.
And if not, can i convert to external gate without permanently welding the door shut on the turbo? I plan on selling it in the next year, and don't want to weld it. And my option for going external would be extrude honed oem manifold, but what kind of wastegate?
Cody, can you shed some light on this please? What does it cost for one of those manifold done up right?
-Kyle
Old 05-20-2013, 12:40 PM   #3320
SR20HAYES
I almost bought that same extension arm, but ended up getting an adjustable bracket that worked great. I paid a bit more then what the extension was, but oh well. What manifold are you using with your external gate? I want to do the same in the future.
Old 05-20-2013, 12:55 PM   #3321
datsr510
datsr510's Avatar
[QUOTE=BlackZenkiS14;5277122]Hey guys, running an oem internal Wastergate actuator, and it falls off of boost at high rpm.
At first the oem one was fine then got stuck closed. It started breaking up afer 5k... so it was overboost and there wouldent be enough fuel. Now I'm only running the hks internal and I have no problems holding 15lbs to redline.
All the people I know running higher then 12lbs break up with the profec-b. Not bashing just saying
Old 05-20-2013, 05:43 PM   #3322
180sxqc
180sxqc is an unknown quantity at this point
hey guys,
I have a JWT ecu and some basic mods: 740cc, Z32 maf, GT2871R
I have been running 10psi for almost a month now
AFR was between 11.4-11.6 to redline
I cranked up the boost to 12-13 psi today and noticed that the AFR drops to 11.0-11.2
Is it normal or should I worry about something, 11.0 is probably not bad but I was expecting 11.5 up to redline
I've only done a few pulls, will the ECU correct itself to 11.5 after a few moments?
*I have an AEM wideband btw
I was wondering if I should be contacting Ben at JWT, thought I could ask here before..
Thanks guys
180sxqc is offline   Reply With Quote
Old 05-20-2013, 06:41 PM   #3323
AsleepAltima
AsleepAltima's Avatar
AsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura aboutAsleepAltima has a spectacular aura about
11.0-11.5 is nothing to be scared of at 10psi. with my 2871 i was getting 10.5-12.1 at redline with 20lbs.
AsleepAltima is offline   Reply With Quote
Old 05-20-2013, 07:07 PM   #3324
BlackZenkiS14
Originally Posted by 180sxqc View Post
hey guys,
Thanks guys
AFR is very dependent on other things too, such as fuel pressure. The ECU is seeing more air moving therefore increasing fuel output to meet demand, it's not always going to be dead spot on perfect. I make very minor adjustments to my fuel pressure to fine tune for AFR like that.
-Kyle
Old 05-21-2013, 12:42 AM   #3325
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
^But wouldn't that only be effective if the ECU/Tune was made to only run Open loop.
Cause if it was closed loop reading the O2 wouldn't it just keep adjusting the Inj PW until it either gets what it wants or can't adjust anymore?
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 05-21-2013, 04:05 AM   #3326
180sxqc
I am running stock fuel pressure, afr is a little rich on higher rpms but perfect for idle/cruising speed
Old 05-22-2013, 02:10 PM   #3327
SnaggleToof
SnaggleToof is an unknown quantity at this point
What intake is everyone using off their 2871??
I have the 2871 and tubbed engine bay, worried about space for the intake... Filter might have to sit behind the radiatior along the frame rail. Im guessing everyone is using a custom made intake pipe?
SnaggleToof is offline   Reply With Quote
Old 05-22-2013, 02:25 PM   #3328
801nismo104
801nismo104 is an unknown quantity at this point
mine goes straight down towards the ground
801nismo104 is offline   Reply With Quote
Old 05-22-2013, 04:21 PM   #3329
AsleepAltima
i picked up a fujita sri from a member, here.
Old 05-27-2013, 05:51 PM   #3330
turbolino
turbolino's Avatar
turbolino is an unknown quantity at this point
if i sayÃ*m running a gt2871r 64A/R at 23 psi 11.5AF to red l
anyone believe me
turbolino is offline   Reply With Quote
