Old 10-26-2006, 09:59 PM   #1
FrancesTheMute
FrancesTheMute's Avatar
FrancesTheMute is an unknown quantity at this point
Better track car
I'm planning on building another track car once I'm back from Iraq. I've been out of racing for wayyy too long and I've been itching to get back in. Which would make a better track car, considering different suspension, engine, power/weight and weight distribution setups. I plan to gut and cage whatever car I choose. I'd like to use the car for auto-x and possibly drifting.
- S13 w/SR20
- S14 w/SR20
- S13 w/RB (RWD)
- S14 w/RB (RWD)
- S13 w/RB (AWD)
- S14 w/RB (AWD)
- S13 w/CA18
FrancesTheMute is offline   Reply With Quote
Old 10-26-2006, 10:06 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
I'll be kind since your doing a very dedicated life duty. Please look into the options you posted. This will create more of a battle between chassis-->motor-->suspension than anything.
Carlos
Old 10-26-2006, 10:06 PM   #3
TAMTANIUM
TAMTANIUM's Avatar
TAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the roughTAMTANIUM is a jewel in the rough
rx7 fc or fd and if you don't like to deal with rotary engine. Corolla AE86 is the way to go.
and thanks for doing a great job over there man. You have my salute haha.
TAMTANIUM is offline   Reply With Quote
Old 10-26-2006, 10:12 PM   #4
FrancesTheMute
Haha, don't spare me simply because of my job. I've done some research, but I prefer personal opinions from people who have actually used the various setups. Granted the RB AWD is not one I expect anyone to have experience on yet, the rest have all been tried.
I have already built two S13's, one was SR20ed the other a KA-T; however neither was a track car, both were my DD's.
Old 10-26-2006, 10:15 PM   #5
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
build a track s2000
BOROSUN is offline   Reply With Quote
Old 10-26-2006, 10:30 PM   #6
FrancesTheMute
Originally Posted by BOROSUN
build a track s2000
My dad would kill me. A Nissan engineer's son driving a Honda...it's sacrilege. I'd never forgive myself either.
Old 10-26-2006, 10:59 PM   #7
JewGal
JewGal's Avatar
JewGal is a well-known jackass
S13 w/RB (AWD)
Not that it's a track car I'd build or like to see built, but just because I doubt the seriousness of your question.
JewGal is offline   Reply With Quote
Old 10-26-2006, 11:09 PM   #8
TheTimanator
TheTimanator's Avatar
AWD in an s-chasis is a pipe dream. Also, last time I checked into auto-x, swaping any of those engines will put you in some really tough classes.
Old 10-26-2006, 11:10 PM   #9
FrancesTheMute
http://www.full-race.com/r14/
Well, dream just became reality. As for being in a tough class, that's fine, it just means I have to become a better driver.
Old 10-26-2006, 11:27 PM   #10
ayuaddict
ayuaddict's Avatar
i like your attitude.
id go with the SR in an S13, tried and true.
Old 10-26-2006, 11:51 PM   #11
bbs114
bbs114 is making a name for him/her selfbbs114 is making a name for him/her self
There are so many factors when choosing a car, most will rely on your own personal opinion and amount of money you wish to spend. If you are actually going to use this car for auto-x and you want to be competitve you might want to rethink your direction, any swap will put you in a street modified class and if you're going to do a full cage and everything I don't know what class you would be in you can look it up at the SCCA website anyway these classes usually have some sick cars like lotus super sevens and other things so it'll be hard to win, except there aren't as many competitors which can be good or bad whatever you think. Anyway I would start with an s14 chassis because they are stiffer, the weight is a little higher but you can trim it down, not to mention s14 usually has less rust. Also s14 can fit much wider tires without major body work than s13. If not s14 because of cost/availability reasons, than s13 coupe its lighter and stiffer than the hatch. As for the engine SR is lighter and easier swap but doesn't have the low and mid range torque of an RB which can be useful in auto-x. But the RB and AWD system would add a lot of weight up front, and ruin the car's balance, you would also need to heavily strengthen the chassis in the front to not only handle the weight but the power that it will be forced to support. I feel like this way would be really expensive. If you're thinking of crazy swaps maybe an s14 LS1, 2, or 7 would be fun, you would definitely have low end torque but probably wouldn't be able to put it down. I suggest s14 with an SR, find a good spooling turbo, if you can make a manifold and get a dual scroll turbo that would be sweet eliminate like all lag too. Check this car out http://www.dentsport.com/gallery/v/d...s/bill240_001/. I think a Miata SR or RX7 LS1 or SR would be pretty good too. I have also seen a VQ go into an s14 before, there are tons of options if you want to get crazy and custom a lot of things. Anyway good luck man, keep up the good work. I'm in the Army Reserve so I'm sure I'll be over there soon too. Hope I helped, Peace.
bbs114 is offline   Reply With Quote
Old 10-27-2006, 12:05 AM   #12
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
Miata.
All the way.
SochBAT is offline   Reply With Quote
Old 10-27-2006, 12:09 AM   #13
datboibrad
datboibrad can only hope to improve
s2k if i could afford one
datboibrad is offline   Reply With Quote
Old 10-27-2006, 12:17 AM   #14
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
last time i was at autox, the fastest cars by far were corvettes...
old mr2 are fast too
but in the end, it's more on driver skill than anything, i've seen civic dx hatch eat up evo's/wrx's in terms of time at autox
Wei240 is offline   Reply With Quote
Old 10-27-2006, 12:21 AM   #15
redsuns3838
redsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the roughredsuns3838 is a jewel in the rough
Send a message via AIM to redsuns3838
there is no better track car. u gotta narrow down ur choices by what you want to achieve. theres better cars suited for certain situations, but no "best track car"
if you want to make an AWD "track" car, why dont you just get a skyline from canada for cheap and set it up for the track? it would be a lot cheaper and a lot less headache than swapping it in a S chassis and making it AWD.
after all its a track car, doesnt need to be run on the street rite?
otherwise, a 240 with a SR or RB and RWD is really just about whether its worth the extra cash and difficulty in finding parts, and howmany HP you are planning to turn out, and which motor you prefer.
you can offset some of the weight from an RB with suspension settings..
also if you want a car for autox AND drifting, your better off with a RWD car, AWD currently cant compete in drift events per rules, IIRC
redsuns3838 is offline   Reply With Quote
Old 10-27-2006, 01:06 AM   #16
wootwoot
wootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to allwootwoot is a name known to all
Send a message via AIM to wootwoot
Miata with an f20c. Mr2 Spyder with fun stuff done. Ollldddd mr2 with practically any fwd motor you can ever think of.
I'm on the hunt for a Miata to beat on
I'm from Florida so I'm probably a bit more strange than you
wootwoot is offline   Reply With Quote
Old 10-27-2006, 01:39 AM   #17
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
+1 for the miata. even better with the sr or f20
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 10-27-2006, 01:46 AM   #18
!Zar!
!Zar!'s Avatar
Miata, 510 or, mazda fb. That's the only options I would suggest.
If you want tons of power, ls1 in a miata. Or sr in a 510.
Old 10-27-2006, 08:34 AM   #19
swwifty
swwifty is an unknown quantity at this point
stripped s13 with stock KA. Once you get really good at driving it, add more power whether that be a RB, SR, or KA-T.
swwifty is offline   Reply With Quote
Old 10-27-2006, 08:43 AM   #20
FrancesTheMute
I've actually considered that. I may just keep the car stock for a while till I can decide which route I want to go.
Old 10-27-2006, 10:07 AM   #21
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
FC.
/thread.
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline   Reply With Quote
Old 10-27-2006, 10:15 AM   #22
LB.Motoring
LB.Motoring's Avatar
r32 awd
/pipedream
Robby Leuer
Old 10-27-2006, 10:30 AM   #23
DoriftoSlut
FC
/Nissan
www.pinkgodzira.com
Old 10-27-2006, 10:31 AM   #24
FrancesTheMute
Originally Posted by LB.Motoring
r32 awd
/pipedream
I love when people say that. Just cracks me up. Sure it's a lofty goal, but when I come back with $75K and no expenses, what else should I spend it on? I've already been in contact with the guys at Full-Race figuring out prices and what not just to see how much it would cost if I did decide to go through with it. From what I can tell, the pricing is actually pretty reasonable.
Old 10-27-2006, 10:38 AM   #25
Duzzes_Wild
Duzzes_Wild can only hope to improve
what are you going to be using the car for, drag, drift, time attack, endurance, circuit..............you want to build the car around what you want to do
Duzzes_Wild is offline   Reply With Quote
Old 10-27-2006, 10:43 AM   #26
FrancesTheMute
Not trying to be a dick.
Old 10-27-2006, 10:51 AM   #27
exitspeed
aWingThing.com
exitspeed's Avatar
240z with VQ...Nuff said.
Old 10-27-2006, 10:51 AM   #28
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
The RB weight issue is a myth perpetrated by people that have actually never had a RB in thier cars. Speaking from a point of reality, I can honestly say that the RB does not upset the balance of the car, or cause an undue weight issue. My car handles great running a RB25. In fact a car with a RB25 is the exact same weight as a car with KAT. Its a complete non issue and does not need different suspension settings to work. hhahhahhahhahhahha
Now as far as autocrossing goes or scca road racing what other people have stated is true. If you want to build a track car just to go out to track and have fun on track days and whatnot you can install a RB or SR and have fun. If your planning on serious competition then its study the rule books and expect intense competition from other very competitive platforms. That said figure out what you want to do yourself and have fun.
New Video
Buy my mounts!
Old 10-27-2006, 10:55 AM   #29
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
s13 w/ sr, quick and nimble.
FC with huge Picnic table drift wing, because its functional and mazda is awesome.
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 10-27-2006, 11:12 AM   #30
DoriftoSlut
FCs are the harest car I've ever drifted. But its also the most rewarding.
As a grip car, the damn thing is so much more sorted than my S13. It makes me realize the HUGE shortcomings in the 240 chassis.
that being said, you really do need to be a very good driver to control an FC. Its low polar moments and short wheelbase make it very squirrely and easy to get into a heap of trouble with. But god damn its awesome.
www.pinkgodzira.com
