Old 09-25-2007, 11:12 AM   #1
240truk
240truk's Avatar
240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about240truk has a spectacular aura about
SR Noobish question on build
Ok guys,
So I've searched through a lot of people's build threads and I need some advice on building a motor for my track car. I, like many other people that beat on their engines wondered what would keep an engine reliable under high amounts of stress. I learned that SRs need to be getting plenty of oil and need to be cool.
Now, I need to know what else I can do to build the perfect reliable motor for my drift car. I was considering a complete build from top to bottom including all forged stuff in the block but is this neccesary? I've heard of people making 400+ hp with the SR on stock blocks and thats really the in the range that I'm looking for about 375-410 hp.
When it come to getting inside a motor I'm completely a noob so go easy on me. So I've been told by some people that forged internals aren't going to last as long as stock internals but aren't they stronger? Is this the case with a built head but not the block or just a theory?
I basically want to build a motor for my s13 track car (drift). I would like it to have somewhere around the 400hp range with good low-end power and have no problem being beat on. I've been thinking of dry sump, oil cooler, v-mount and anything i can to cool it, tuning of course is one of the most important things. I already have a gt28r turbo, megan turbo manifold, elbow and dp I'm basically just looking for advice on the block, stock or forged rebuild??? if forged, what brand? If stock, should anything in the block be aftermarket?
Thanks for hangin in there guys.
240truk is offline   Reply With Quote
Old 09-25-2007, 11:17 AM   #2
Otis Performance
Guest
Posts: n/a
400hp with a gt28r ?
lol.
Old 09-25-2007, 11:20 AM   #3
240truk
240truk's Avatar
well i can get a different turbo, it could make like 375 right?
Old 09-25-2007, 11:21 AM   #4
240truk
240truk's Avatar
instead of lol why don't you suggest a different turbo? I wanna keep it on the small side for good resonse
Old 09-25-2007, 11:35 AM   #5
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
get a gt3071r or 76r, those seem to be really good for your power range.
I would highly suggest an electric water pump, keep stock compression and go with new bearings and seals throughout, blue print the motor. You should not have any problem as long as your supporting modifications are there.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 09-25-2007, 12:11 PM   #6
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
that is true. Looking at dyno charts from Full-Race their twin scroll gt3071r setup creates power lower in the rpm band (spools faster), and is capable of the number that you want. compared to the gt2871 single scroll setup.
http://www.full-race.com/catalog/pro...dca00960a40e37
good luck
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 09-25-2007, 12:16 PM   #7
240truk
240truk's Avatar
thanks guys!
Old 09-25-2007, 01:30 PM   #8
Dream240
Dream240's Avatar
Here's a noob tip for you. Don't add another response post with another comment. just simply edit your first post to include your second comment. Makes reading threads that much easier.
As far as your question goes, it really comes down to howe much money you want to invest. If money is no object then by all means build up the bottom end. Cryo-treat the entire bottom end, port/polish the head, upgrade all your head components to handle higher boost levels (which you will need to make 400 hp with a GT28). Get an ample supply of guages to monitor your investment.Because all it takes is a clogged or failed oil pump and your work is toast.
If money is a factor, then just swap in the SR, get the cooling stuff installed you already mentioned, and TUNE IT PROPERLY. Then just enjoy it until it dies, and get another.
Old 09-25-2007, 04:36 PM   #9
240truk
240truk's Avatar
Yeah money is a factor for now.
I'm definately considering that turbo now. The twin scroll setup looks awesome!! And people are running this with stock blocks making over 400hp! I like the idea that this setup is less stressful on the motor. Seems like with proper tuning the stock block will do just fine especially with a rebuild.
yeah my bad
Old 09-26-2007, 04:01 PM   #10
chester_ff7
chester_ff7's Avatar
chester_ff7 will become famous soon enoughchester_ff7 will become famous soon enoughchester_ff7 will become famous soon enough
Send a message via AIM to chester_ff7
with that turbo upgrade (gt3071r or 76r), head work(port and polish, and all that jazz), and a good tune you will be pumping out a lot of WHPs... more then what you are expecting... good luck with the build!!
chester_ff7 is offline   Reply With Quote
