Old 11-20-2007, 09:23 AM   #391
Nolmack
Nolmack is on the path to ruinNolmack is on the path to ruinNolmack is on the path to ruin
I just got my new mounts, i will most likely install them tomorrow... we'll see how this goes... gahh im nervous lol.
Nolmack is offline   Reply With Quote
Old 11-20-2007, 09:45 AM   #392
240trainee
240trainee's Avatar
240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection240trainee is close to perfection
Send a message via AIM to 240trainee
I should be getting the second replacements soon too, I have the black ones and the origonal goldish ones.
Goldish ones clunked, black ones don't rotate. Hopefully third times the charm.
Team Pterodactyl
SHARK ATTACK!!!
LookoutDrift
240trainee is offline   Reply With Quote
Old 11-21-2007, 03:15 AM   #393
m tr4nch
m tr4nch's Avatar
m tr4nch is an unknown quantity at this point
heh, you know whats funny? ANOTHER pair of good mounts showed up at my house today for some odd reason after i already got the replacements 2 weeks ago.. so now i got 2 sets. i guess i will save these for later then
IG: @mtr4nch ... build thread
m tr4nch is offline   Reply With Quote
Old 11-21-2007, 05:53 AM   #394
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
What is everyone doing with their old "busted" mounts? Trash? Return? I need a couple sets to try an idea out.... PM me if interested in contributing.
AceInHole is offline   Reply With Quote
Old 11-21-2007, 06:28 AM   #395
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
my mounts came in yesterday. Its not the whole top mount, just the pillowball part that connects to the strut on one end, and the camber plate on the other.... I"ll put it in this weekend. Hopefully it works out for me. ::crosses fingers::
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 11-22-2007, 04:32 PM   #396
Nolmack
installed the new mounts last nite.....
I still have have the spring catching on the perch locks ( this only occurs during sharp turns like such as making a left turn at a light)... but i have no more memory steer. BTW i also lubed the pillow mount with some grease idk if that helped a bit.
Old 11-22-2007, 11:31 PM   #397
DaPCWiz
DaPCWiz's Avatar
Installed mine last night. Everything seems to be moving smoother. Bit easier to adjust height. I too lubricated the pillowballs before I put them in. Lets see how it holds up.
some documentation pics:
old mounts:
new mounts:
compare the two (new left, old right):
The top circle area where the pillowball mounts to appears redesigned. Mount is also now slightly thicker.
Old 11-26-2007, 03:15 PM   #398
nousablenames133
nousablenames133's Avatar
nousablenames133 is making a name for him/her selfnousablenames133 is making a name for him/her self
I just got a pair of the replacement bearings. How freely are they supposed to move? The OE strut tower mounts have almost no friction, but I can't move my new bearings at all by hand.
nousablenames133 is offline   Reply With Quote
Old 11-26-2007, 03:18 PM   #399
DaPCWiz
DaPCWiz's Avatar
I was wondering the same thing... couldn't really turn the new or old ones by hand. New ones seem to work better once installed tho...
Old 11-26-2007, 03:49 PM   #400
mtx450
mtx450's Avatar
mtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura aboutmtx450 has a spectacular aura about
How much preload is everyone running with the new mounts? I have about 1-2 turns worth...
mtx450 is offline   Reply With Quote
Old 11-26-2007, 03:55 PM   #401
DaPCWiz
DaPCWiz's Avatar
I have it just tight enough that I can't spin the spring with my hand, and then a turn more.
Old 11-29-2007, 05:55 PM   #402
ilovecoupes
ilovecoupes's Avatar
ilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to beholdilovecoupes is a splendid one to behold
I just got new mounts also
What are you guys torquing your top bolts to?
Shoot To Thrill
ilovecoupes is offline   Reply With Quote
Old 11-29-2007, 05:59 PM   #403
mtx450
mtx450's Avatar
I tried to do it with a shitty elec impact gun, but it wound up just spinning the strut, not actually tightening it. I don't think it needs much.
Old 11-29-2007, 09:17 PM   #404
DaPCWiz
DaPCWiz's Avatar
I did it by hand - tightened it till the point where the strut spun, then put a wrench on the top perch to hold it, and then tighten it maybe 1/4 - 1/2 turn more.
Old 11-30-2007, 12:20 AM   #405
chuonthis
chuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the rough
Finally got my mounts on Monday. Installed them and they haven't had the spring binding since. I greased all the spring contacts but left the ball joint alone. Will see how it holds up. Finally, after 3 months, the problem may be gone.
chuonthis is offline   Reply With Quote
Old 11-30-2007, 06:17 PM   #406
ilovecoupes
Is there any way to take off the top nut off with out using an impact gun?
I used a breaker bar, but the pillow ball just rotates with the top nut.
Any suggestions? I tried reading Munch's post, but it didn't really help
Shoot To Thrill
Old 11-30-2007, 06:28 PM   #407
DaPCWiz
DaPCWiz's Avatar
use a wrench to grab the top collar above the spring. Wedge it against your chassis or hold it. then use the breaker bar up top. Comes open pretty easily.
Old 11-30-2007, 07:49 PM   #408
zads
zads is an unknown quantity at this point
Didn't read through all 14 pages of this thread, but has anyone tried break-in processes for their pillowball/heim joints? Not sure if the Stance joints are PTFE lined or not but...
Its almost a necessity for PTFE/Teflon lined heim joints, otherwise they stick and never really function correctly.
On all our full heim jointed racecars (no bushings) we always break in every rod-end by spinning it up and lubing it in a mill, though you could easily do the same at home with a hand drill. Just put a properly sized bolt and nut through the joint, torque it down, and attach to a speed controllable drill. Spin it at a slow speed until it spins without excessive resistance, adding oil when necessary. Don't let it get too hot.
Never had a problem with my KTS coilovers popping, but then again I broke them in a little..
zads is offline   Reply With Quote
Old 11-30-2007, 08:39 PM   #409
ilovecoupes
ya i just took the coilover off. put my foot on the spanner wrench that was hooked on the collar. And gave the top nut a quick swoop
And thats all she wrote
+1 for you
Shoot To Thrill
Old 11-30-2007, 08:53 PM   #410
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
i called stance when i first got these and they actually told me not to lube them up.
something about how they won't even get inside or something.
overb0ost is offline   Reply With Quote
Old 12-01-2007, 12:11 AM   #411
eulalia
eulalia's Avatar
eulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfectioneulalia is close to perfection
Send a message via AIM to eulalia
seems like stance is taking care of the problem,
im looking to get coilovers this coming week.. should i get stance
or should i look for something else? anyone know if the new shipment has
any problems?
thank you in advance
eulalia is offline   Reply With Quote
Old 12-01-2007, 03:18 PM   #412
nousablenames133
I was skeptical at first, but I just installed the new bearings. They're working great. I sprayed them with some lithium grease before I installed them, but I doubt that made a big difference.
Old 12-03-2007, 12:34 PM   #413
logik23
logik23's Avatar
logik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of lightlogik23 is a glorious beacon of light
For the ones that put in new mounts and have no more noise, does the pillowball rotate easily?
The pillowball is suppose to move easily by hand, not loose, but no resistance either.
I've received a 3rd replacement set, but my car is in storage for the winter so I can't test them until April.
I don't think these work though because if I stick a screwdriver in the hole of the mount, it won't mvoe the pillowball, on my old Kei Office coilovers, the top plate would move freely, not like these.
-1992 Nissan 240SX LE
-1998 Jeep Grand Cherokee 5.9 Limited
logik23 is offline   Reply With Quote
Old 12-04-2007, 10:26 AM   #414
chuonthis
I couldn't get mine to budge at all by hand or screwdriver so I was also skeptical. When I was bolting back on the strut, the pillowball did rotate easier than the previous ones. When I put the car back on the ground and took it for a spin, I heard some clunks right away but I think that was just the springs seating itself. After that, no more clunking.
Old 12-04-2007, 12:11 PM   #415
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
any chance you could just take the front coils out? my third replacement set seems to be promising so far. just install it on the coil and you should be able to hold the body with one hand and use the other to move the pillowball.
D1GP is offline   Reply With Quote
Old 12-04-2007, 12:28 PM   #416
logik23
logik23's Avatar
Nah, I can't take them out. I can't jack up the car where it is and I can't move it.
But it should be extremely easily to move the top plate, there should be no pressure needed. Not loose, but very easily movable.
I doubt these new ones are any good.
Old 12-05-2007, 07:43 PM   #417
zads
Oh, yeah.. shoulda been clearer.
The lube isn't to help the monoball during operation,
You just need it to get the monoball moving during break-in,
and cool it off as you break it in.
Don't leave the lube on there when you run it,
it just grabs and holds dirt that messes up the bearing.
Old 12-12-2007, 05:58 AM   #418
K4RR
K4RR has made poor choicesK4RR has made poor choicesK4RR has made poor choicesK4RR has made poor choicesK4RR has made poor choicesK4RR has made poor choicesK4RR has made poor choices
Well, I have this issue with my front drivers side....gay........Time to make the call to stance...........
K4RR is offline   Reply With Quote
Old 12-12-2007, 09:54 AM   #419
K4RR
Well, I just talked to stance! The guy was really cool! And he is gonna send them right out to me! Not to bad for customer service to me...Answered on the 2nd ring!
Old 12-13-2007, 02:23 PM   #420
logik23
logik23's Avatar
Yeah, they send them out right away, but the ones they send out are just as defective as the ones you have now. :ghey:
