Old 02-17-2008, 01:33 PM   #1
S14DB
AFC #1
S14DB's Avatar
How To: Rebuild Clutch Master Cylinder and Slave Cylinder
I was bored this weekend and decided to make this guide.
Parts needed:
Master Cylinder Rebuild Kit with new Piston(valve in piston tends to go making difficult to bleed.)
Slave Cylinder Rebuild Kit
1qt. Brake Fluid.
Glass or Metal Cup to hold Brake Fluid.
Parts washer or Wash tub.
Toothbrush.
Master Cylinder rebuild:
1) Secure the MC. I used a vice 2nd set of hands work also.
2) Inspect the Rebuild Kit and lay it out.
From top left clockwise. Rod boot, Piston, Rod Clip, Piston Retaining Pin O Ring, Spring.
3) Remove and clean fluid reservoir.
4) Remove rod boot. Remove Clip holding rod cup. Remove Rod
Replace dust boot.
You can see the Piston now.
5) Push the piston in slightly and remove it's retaining pin(screw)
6) Replace the O ring on the pin with the one in the kit.
Release the piston and it will pop up.
7) Remove old piston and spring and discard. Note any damage.
8)Clean the Housing. Soap and water, Toothbrush work the best.
Any damage, scoring or wear make the housing worthless. Toss and get another.
9) Soak Piston in Brake Fluid. This lubricates the seals and primes the valve.
10) Install new spring on the new piston.
11) Install Piston in housing. Install retaining pin(screw).
12) Install Rod and Cup with new retaining C clip.
13) Install Dust cap.
14) Install Reservoir.
Slave time.
1) Inspect parts and SC.
2) Remove Boot. Rod will come with. Replace boot on rod and set aside.
3) Remove piston. Ether by air in the line in or banging the open side.
4) Inspect Piston and Bore for scoring or wear. Again any damage and the unit is trash. Buy a new one.
5) Replace piston seal
6) Place piston in brake fluid to lubricate.
7) Reinstall piston in bore.
7) Resintall boot and rod.
Done.
Questions? Comments? Suggestions?
Old 02-17-2008, 02:11 PM   #2
sikkk240
sikkk240's Avatar
sikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond repute
Send a message via AIM to sikkk240
great write up..
vote sticky ?
+1
damn... ive given out to much rep..
lol
sikkk240 is offline   Reply With Quote
Old 02-17-2008, 02:57 PM   #3
95Blue240sx
95Blue240sx's Avatar
95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection95Blue240sx is close to perfection
good stuff. Archive this.
Please leave me feedback
95Blue240sx is offline   Reply With Quote
Old 02-17-2008, 09:36 PM   #4
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
good shit dude, archive for sure
Review Thread
bardabe is offline   Reply With Quote
Old 02-17-2008, 09:45 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
You should do this for z/skyline calipers. Master and slave cylinders are so cheap that there is pretty much no point in re-building them.
Old 02-18-2008, 12:03 AM   #6
S14DB
AFC #1
S14DB's Avatar
New Master is $100 and a New slave is $50. The MC kit with new piston was less than $15 and the Slave Kit was less than $10. I dunno how you can call ether cheap in comparison.
I may do other write ups in the future. This was sort a feeler.
Old 02-18-2008, 01:25 AM   #7
racepar1
racepar1's Avatar
Ya but 99% of the time the bore is scored anyways. You cannot hone an aluminum cylinder as all of them have a special anti-wear coating, without that coating the bore will score extremely easily. Re-building a master cylinder is a bad idea in my opinion. $100 is not a lot of money to spend on a modified car, or ANY car for that matter.
Old 02-18-2008, 01:52 AM   #8
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
I can head to my favorite shop and pick up OEM master and slave for $60 out the door. So I'm good. But even though I can pick em up, the DIYer in me wants to rebuild the ones I have now for the hell of it. Thanks for the writeup S14DB.
it's a RUCKUS life
Xandy Boosts is offline   Reply With Quote
Old 02-18-2008, 06:27 AM   #9
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
Very nice information to have man thanks alot
Slip Gypsies Blog
not sure if you realize this
Old 02-18-2008, 07:26 AM   #10
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Where was this last month AJ? I ended up buying new ones!!!
CLICK HERE!!!
Old 02-18-2008, 07:33 AM   #11
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
i agree great writeup but i just bought new ones myself and put them on last month . now you should figure the size of the fittings to make a hardline dude between them
bigOdom1 is offline   Reply With Quote
Old 02-18-2008, 08:08 AM   #12
Slidin240Wayz
Slidin240Wayz's Avatar
Excellent write-up.
Do you have part numbers for the re-build kits?
Agency Power makes a SS replacement line.
Carlos
Old 02-18-2008, 08:19 AM   #13
bigOdom1
bigOdom1's Avatar
i already have one myself
Old 02-18-2008, 08:59 AM   #14
90KAcoupe
90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future90KAcoupe has a brilliant future
Send a message via AIM to 90KAcoupe
i have rebuilt 4 master cylinders and 3 slave cylinders.. they are extremely easy and i have yet to see one where the bore was scored. normally the seal on the piston gets a rip in it. but if u feel more comfortable buying one then by all means do that.
the sig rules are gay!!
90KAcoupe is offline   Reply With Quote
Old 02-18-2008, 11:29 AM   #15
mrpeepers
mrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nicemrpeepers is just really nice
now we should have a write up on how to properly bleed the system...i am having so much trouble =(
mrpeepers is offline   Reply With Quote
Old 02-18-2008, 12:11 PM   #16
S14DB
AFC #1
S14DB's Avatar
That's why I say to spend the extra $5 on the MC kit with the new piston. Makes it so much easier to bleed with the new valve.
I assume you removed the damper and loop.
Old 02-18-2008, 03:38 PM   #17
racepar1
racepar1's Avatar
You must ALWAYS bench bleed the master cylinder before you install it. If you don't it will take forever to get all the air out of the system.
Old 02-18-2008, 03:45 PM   #18
rhs13
rhs13's Avatar
rhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant futurerhs13 has a brilliant future
Send a message via AIM to rhs13 Send a message via Yahoo to rhs13
what is that thing for, anyway?
cuz i dont give a fukk. that's why.
rhs13 is offline   Reply With Quote
Old 02-18-2008, 04:13 PM   #19
coolcatracing
coolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to allcoolcatracing is a name known to all
Clutch Master-$23.99
Slave-$17.99
Available everyday at Oriely's. Sorry but there is no point in rebuilding them when I can get new ones for that much. Great sticky but I never bother rebuilding them. I also remove the damper since it only causes problems.
coolcatracing is offline   Reply With Quote
Old 02-18-2008, 04:13 PM   #20
S14DB
AFC #1
S14DB's Avatar
Makes the pedal movement and feel more comfortable. N/H/V issue. I don't think anyone is here is big enough pansy to care.
It's a PITA to bleed cause the loop has to be level with the ground in order to get all the air out. Most people just put the front end on jackstands to bleed and it's not level. Need a lift or 2 sets of jackstands to get the whole car in the air and level.
Old 02-18-2008, 04:34 PM   #21
rhs13
rhs13's Avatar
i took it out and never noticed a difference in pedal feel, but maybe because my whole car vibrates. thanks for the reply.
Old 02-18-2008, 04:49 PM   #22
g6civcx
g6civcx's Avatar
It's impossible to bleed the clutch line if you have the damper. You need a power bleeder.
Old 02-18-2008, 04:52 PM   #23
S14DB
AFC #1
S14DB's Avatar
Slave-$17.99
Those aren't new, those are rebuilds that you have to return a core. Same thing I am doing here with crappy seals to save money and bulk processing. I think many can attest to the fact those blow out fast. I can get the seals for $5 and $3 that they used. I bought the most expensive Japanese kits and spent under $25 for both.
Old 02-20-2008, 08:22 PM   #24
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
I wish I knew that the first time I tried to replace my slave. Had to have the car towed to the dealer. 3 hours of bleeding later...at dealer labor prices. I'm getting a headache just thinking about it. I could have wasted that money on way more useless stuff.
I was also wondering about the part number on those rebuild kits. Do they make them for the nismo slave as well?
PhilthyS13 is offline   Reply With Quote
Old 02-20-2008, 08:40 PM   #25
nissanguy13
nissanguy13's Avatar
nissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant futurenissanguy13 has a brilliant future
+1 for the write up. Next time mine goes out I'm going to try this instead of buying new ones.
Originally Posted by unicoladron;
dick, i had like 4 posi reps in a row and you ruined it
nissanguy13 is offline   Reply With Quote
Old 12-05-2008, 02:08 PM   #26
theronin
theronin's Avatar
theronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfectiontheronin is close to perfection
Send a message via AIM to theronin
just wanted to say thanks for the writeup. saved me a lil cash. with the slave cylinder i couldnt figure out how to get the piston out. had an old grease gun lyin around, threaded it in and voila! just incase that helps anyone.
Originally Posted by HalveBlue View Post
That first picture is totally bad ass.
It just screams, "Hey, I'm a fucking Christmas Tree. What are you gonna do about it?"
theronin is offline   Reply With Quote
Old 12-05-2008, 03:16 PM   #27
S14DB
AFC #1
S14DB's Avatar
I used a air compressor but, banging it on a wood table works too.
Old 12-05-2008, 03:22 PM   #28
slider2828
slider2828's Avatar
Where can I get a rebuild kit for this?
Turn and Burn!
Old 12-05-2008, 03:35 PM   #29
Om1kron
Om1kron's Avatar
He's rich, now post up a rebuild for brake calipers lol.
Wayne Edwards
https://om1kron.blogspot.com
Old 12-05-2008, 04:47 PM   #30
theronin
theronin's Avatar
i got mine at autozone. im guessin any major parts store will have it mang. Kragen, Autozone, napa, maybe even Pep Boys.
