Old 03-05-2008, 05:37 PM   #1
sleepinsilvia23
sleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura aboutsleepinsilvia23 has a spectacular aura about
Things to do with subframe out
I will be dropping the subframe this weekend to have my differential welded, while the subframe is out of the car is there any bushings that should be replaced or anything else? I have urethane spacers on the way but i was thinking while the subframe was out i could replace the bushings themselves. If you recommend replacing these bushings, what are the exact names or part numbers so i can order them.
Thank you very much
sleepinsilvia23 is offline   Reply With Quote
Old 03-05-2008, 05:49 PM   #2
drftwerks
solid aluminum moiunts, new arms, powder coat.
giantroboteyes.wordpress.com/
Old 03-05-2008, 05:51 PM   #3
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Here is my thread on SPL solid aluminum bushings... I highly recommend it...
http://forums.freshalloy.com/showthread.php?t=160757
Nikeboy355 is offline   Reply With Quote
Old 03-05-2008, 07:39 PM   #4
sleepinsilvia23
I remember reading that thread on FA awhile back and i remember wanting to do that. Im not bitching or nothing and you always hear this "I DD my car" but what do u think about the ride, cuz i didnt see a conclusive answer from you in that thread on how the overall ride was, performance and daily drive opinions.
Thanks
Old 03-05-2008, 08:27 PM   #5
drftwerks
best thing i did to my s13, dd and everything, worth it mos def.
Old 03-05-2008, 08:49 PM   #6
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
you're willing to weld a diff on a daily but cant handle manly sounds of solid bushings?
I swapped in solid subframe and diff bushings. Next is painting the subframe (once weather gets warm) as well as upgrade to Z32 uprights (thanks Russ) and throw some adjustable links on rear. Should get the bigger pan for the 2way, but you're probably not too concerned with that.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 03-05-2008, 08:55 PM   #7
!Zar!
!Zar!'s Avatar
Uhh. You aren't driving a FC... You don't need to drop your subframe to take the diff out.
But if you insist, burn out the old bushings and install solid alum bushings.
Since you live in the PA, you should thoroughly clean and repaint the subframe to prevent rusting.
Old 03-05-2008, 08:58 PM   #8
drftwerks
powderfuckingcoat
Old 03-05-2008, 09:00 PM   #9
!Zar!
!Zar!'s Avatar
Originally Posted by drftwerks View Post
powderfuckingcoat
I'll powder coat you with my skeet!
Old 03-05-2008, 09:01 PM   #10
drftwerks
score, i was wondering what color i wanted, now its official, man juice whiteish
Old 03-05-2008, 09:03 PM   #11
drftwerks
Old 03-05-2008, 09:19 PM   #12
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
Haha, from what I've heard, if you can tolerate a spooled diff, you can tolerate the solid bushings. Honestly, if you're looking for a comfy ride, buy yourself something else, the KA/SR is loud as it is.
Sand/strip the subframe if you have it out, repaint or powdercoat it, do the bushings, weld the diff or get an LSD... You're set!
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
Old 03-05-2008, 09:30 PM   #13
CSil80
Banned from the Marketplace
CSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfectionCSil80 is close to perfection
Slightly off topic, but where is a good powder coating shop in Socal?
I'm dropping my subframe later this week as well and want it coated before raising it back.
CSil80 is offline   Reply With Quote
Old 03-06-2008, 09:33 AM   #14
sleepinsilvia23
No i can handle the noise, i already drive a sr'd s14 that makes lots of noise so i think im up to the test. I was just more curious then anything.
I will be ordering the solid subframe bushings and also be looking for differential bushings also.
Thanks for your guys help
Old 03-06-2008, 09:47 AM   #15
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
You can also check for any rust spots while you have the rear sub-frame out.
Maybe even apply some roast preventive paint.
IIIXziuR is offline   Reply With Quote
Old 03-06-2008, 02:44 PM   #16
shade
shade's Avatar
shade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond repute
^You made me hungry.
Check links, joints, grease, boots, bushings, retorque, diff fluid, 5-lug(if not already), paint, aftermarket suspension parts, etc.
shade is offline   Reply With Quote
Old 03-06-2008, 02:51 PM   #17
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
haha whoops** I mean rust preventive paint.
Old 03-06-2008, 03:05 PM   #18
breakindrifts
breakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nicebreakindrifts is just really nice
Wait, why are you dropping the subframe to weld the diff?
[http://www.zilvia.net/f/image.php?type=sigpic&userid=34165&dateline=118172  7650
breakindrifts is offline   Reply With Quote
Old 03-06-2008, 03:15 PM   #19
godzillarb
godzillarb's Avatar
godzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to allgodzillarb is a name known to all
Here's what I did with mine while it was out:
Before:
After:
I upgraded to solid bushings, tilt spacers, some stronger GTR stuff (axles, hubs, lsd), and 300zx-tt brakes.
The subframe was sanded and painted with some sort of rust-proof paint that I found laying around.
INTENSE POWER RIPPED ME OFF
godzillarb is offline   Reply With Quote
Old 03-06-2008, 03:15 PM   #20
Aeroscraper326
Aeroscraper326's Avatar
Aeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfectionAeroscraper326 is close to perfection
Paint that shit pink.
Aeroscraper326 is offline   Reply With Quote
Old 03-06-2008, 03:38 PM   #21
D1GP
D1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the roughD1GP is a jewel in the rough
yes, do subframe bushings and either replace your rear arms or do poly bushings. you might wanna replace the rear ball joints if they are bad.
D1GP is offline   Reply With Quote
Old 03-06-2008, 04:33 PM   #22
Nikeboy355
Nikeboy355's Avatar
Thanks
I don't think it is even a concern on a daily driven car... It's not that big of a deal... Yes it transmits more noise and vibration into the chassis but only as much as your diff is creating...
When I had the welded diff I felt like the rear of the car was going to break at any time... And my car wasn't faster like that anyways (roadcourse events)...
An HLSD and solid aluminum subframe is the way to go... That coupled with good coilovers and good condition bushings/ball joints all around and the car will handle the road as good as any Porsche...
Spend some time aligning it and playing with the settings to get the car how you like it...
I setup my S13 for mild oversteer and will continue to setup my cars like that...
Old 03-06-2008, 04:45 PM   #23
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Whoa man are you gonna be in for a treat...solid bushings and welded diff...
You ever heard of a meat grinder? Thats what your rear ends gonna sound like, specially if you have a hatch...
CLICK HERE!!!
Old 03-06-2008, 08:40 PM   #24
godzillarb
godzillarb's Avatar
I gotta admit, going to a 2way lsd and solid bushings... wow, I thought something was about to break. It's cool once you get used to it and realize the whole back end isn't going to fall off. The car performs better though, and that's what counts.
