Old 03-18-2008, 11:20 PM   #1
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
SoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud ofSoloSilvia has much to be proud of
Feedback Score: 36 reviews
Stumped...Car turns over very slow, and wont start
Car is a 92 240sx se. Just put a new battery in it and looked over all grounds and wires, and checked fuses. The starter I noticed had junkyard writing on it. I have another off a running KA Im going to swap tomorow to see if thats the case, but I dont think it is due to the way it turns over, but it may be...
Symptom, you turn the key and the engine turns over VERY SLOW! Like slower then any engine with a fully charged batery should crank. Not near fast enough to actualy kick over and start. I also noticed the power wire that bolts to the starter got extremely hot when trying to start the car. Car has power, is getting fuel, spark, but I realy beleive the issue is that it will not turn over very quick, maybe once outa 20 times it will give me false hope and sputter, then slow down to barely any crank!
I searched hi and low and couldnt find anything this specific to my problem. And I figured Id ask trusty Zilvia to see if anyone may have had this problem or can help before I start replacing everything under the hood!
Thanks in advance!
Brian
Hatas Keep Hatin, I Keep Rollin!
SoloSilvia is offline   Reply With Quote
Old 03-18-2008, 11:27 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
KA24DE? Did this just start happening? Did you swap this motor in?
Old 03-18-2008, 11:59 PM   #3
turboboost12004
turboboost12004's Avatar
turboboost12004 is an unknown quantity at this point
your starter.......................................
Sieze the day or Die regreting the time you lost
turboboost12004 is offline   Reply With Quote
Old 03-19-2008, 06:45 AM   #4
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
car is auto ka24de....original motor, just died one day as the guy told me that I bought it off of.
Im going to swap starters here in the next few hours, will update asap!
Ive worked on a ton of 240's but never heard one crank this slow....
Old 03-19-2008, 07:33 AM   #5
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
Compression test?
posdrift240 is offline   Reply With Quote
Old 03-19-2008, 07:43 AM   #6
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
could be lack of oil at the crank/cams causing alot of stress...you check your oil?. i over tourqed cam towers too much once and experienced the same symptoms as you. but it didn't just happen out of nowhere, it was MY mistake.
clark is offline   Reply With Quote
Old 03-19-2008, 10:37 AM   #7
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
OK, I replaced the starter... Same thing...
I cannot compression test it due to it cranking sooooo slow....
As far as I know, nothing internaly was messed with, but my next step will be pulling valve cover off and inspecting everything atop the head. ...
Any other thoughts?
Old 03-19-2008, 12:11 PM   #8
Justinrl613
Justinrl613 is an unknown quantity at this point
Bump Bump Bump
Justinrl613 is offline   Reply With Quote
Old 03-19-2008, 12:15 PM   #9
azanprophet
azanprophet's Avatar
azanprophet is an unknown quantity at this point
Send a message via AIM to azanprophet
What about the ignition. I had a similar problem not too long ago and I changed my ignition switch and it worked fine...until my starter died and I had to replace that too but I knew that was on the way out already.
azanprophet is offline   Reply With Quote
Old 03-19-2008, 12:21 PM   #10
KiLLeR2001
Trader Rating: (46)
Make sure the ignition wire is making a good connection on the starter. The black wire with yellow stripe, they always tend to not be on there tight enough. Ignition switch is another possibility...
Old 03-19-2008, 12:50 PM   #11
posdrift240
My guess is something in the rotating assembly is Screwed, Since the car just died on him before. The bearings in the motor is prob shot and your probably screwing the crank up every time you turn it over IF it is turning over that slow. If I was you, I would get a Flywheel tool and turn the motor over by hand as see how tight it is by hand vs by starter. If its really tight. Better start yanking the motor out.
Old 03-19-2008, 02:42 PM   #12
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
push start it, see if it runs.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 03-19-2008, 02:54 PM   #13
SoloSilvia
SoloSilvia's Avatar
Trader Rating: (36)
Its auto!
Ok, after tryin about everything, I think posdrift240 is right... I was hoping this whole time it would be a simple fix, but Im pretty sure something is screwed in the bottom end! Tryed cranking by hand, and I couldnt get the thing to move!
So off to source a new motor!
Thanks for all the input!
Old 03-19-2008, 07:48 PM   #14
danman04x
danman04x is an unknown quantity at this point
hope everything goes well
danman04x is offline   Reply With Quote
Old 03-27-2008, 09:29 AM   #15
turboboost12004
it could not be a compression problem, if it was then the starter would just make the engine crank fast.....it is right u have an engine problem.....
