Old 03-26-2008, 09:10 AM   #3
projectRDM
projectRDM's Avatar
There's a few ways to do it, depending on your plans. The entire piece is spot welded, there's a total of about thirty you have to drill out. In between the frame rails there's two on top, two on the side, and two on the bottom. There's a few above the rails on the side, there's three on either top side below the fender on the apron, and there's a line of them below the headlight buckets. The way I remove them to sell is to drill the frame rail and apron welds then just sawzall the rest off, whoever buys it can trim and grind the remaining sheetmetal as needed. You can also just sawzall a few inches behind and cut the entire front clip off, then cut/grind the excess metal off.
FORMERLY R240NA
