Old 05-02-2008, 09:07 PM   #9
Pacman
Pacman's Avatar
Pacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura aboutPacman has a spectacular aura about
Originally Posted by Addicted2Kouki View Post
hes right on this one.
it just has to be parallel with the flywheel so it can read off of it.
you can put the sensor of the side or bottom of the tranny even...
as long as it can read off the flywheel.
Really? So if its parallel to the flywheel 18" away it'll be okay and read? Don't think so, buddy. The air gap has to be correct to get the right on/off signal of the digital waves (created by the flywhheel teeth flying past the sensors magnet). Its like an ABS sensor, too far away, won't get stong enough signal (thus not working properly), too close, signal will be sloppy (might not get true on/off waves).
I just checked my FSM ('96 model as well) and it gave me no dimensions. If you have any questions and need FSM info, hit me up.
Pacman is offline   Reply With Quote
