![]() Join Date: Jan 2009
Missing and Stalling at idle.I've Spent 2,000$+trying to fix. Its Cursed HELP!
Ok so here is the deal-
After spending thousands of dollars trying to fix my SR i really need some advice on what my problem could be, I am completely out of Money, so i need to get this thing running myself. Rundown, I'll keep it brief- -Motor is stock redtop sr, car is 93 240sx -Motor has never run correctly after swap -Like the post says, Motor seems to miss-fire at idle (mechanic says its running very rich), -In the higher RPM's, car runs smoothly, but also lacks power. -After a drive, it will stall at idle, but then start up and and idle again (still misfires) What has been done- (if you think its something i checked, ill check it again) -No codes on ECU -replaced TPS (bad) -replaced MAF (bad) -replaced injectors -replaced ecu -replaced coolant temp sensor -replaced spark plugs (ngk iridium) -checked for boost leaks -checked for vaccum leaks -checked vaccum hoses (correct hookup locations) -checked timing -checked grounds -checked power and grounds on ecu plug -checked Greddy Bov (closed all the way) -checked turbo (for runout/ missing teeth) -checked compression (150psi x4) I have been to two shops, both can't figure it out, One shop hooked up a power fc and got it running pretty well like that. (should i just consider going this wrought) The only other thing i could think of is the harness, but i dont really want throw any more money down the drain. I will take any Ideas at all! ![]() ![]() ![]() Last edited by redsx13; 01-13-2009 at 12:50 AM.. |
