#31 |
![]() Join Date: Oct 2006
![]() ![]() Feedback Score: 23 reviews
Your revs drop then go back up to normal, that is not running correctly.
Try going to a track day or autocross and then having to brake abrubtly. Better yet, recirculate for a week and see if you ever go back. I am willing to bet you will not, unless of course you are more concerned with proving to people around you that you have a turbo and make cool noises. We are not saying it will die at every stop with the BOV vented. But it will not stay alive at the correct idle with the blow off valve vented. And modifying your car to run worse and behave wrong is just plain retarded. |
#33 | ||
Thank you for clearing the confusion up. Hopefully I can get a recirc fitting for this knockoff greddy.
#34 |
I suggest you don't run a BOV- unless your Mapped... no point in really running one if your still stuck on a maf/afm. Sure it sounds cool, but your driving your car daily right? Swoosh Swoosh (big shiny FMIC) Cop magnet my friend.
But... If your still fixed on it... to fix your rev/bog problems (been covered many times) run a POS AFC on that meter and call it a day. |
#35 | |
![]() Join Date: Mar 2010
#36 | ||
#38 |
i went from a smic with stock bov to a midmount setup with atmosphere dump bov and the stock was a bit louder and not as responsive as my current setup but to each their own i guess...
#39 | ||
![]() Join Date: Dec 2004
Trader Rating: (58)
No BOV on a Maf car? You are kidding right? run a AFC on the car? Dude... Quote:
Can't get much more recirced than that? What is that supposed to mean?
#40 |
![]() Join Date: Feb 2010
![]() Feedback Score: 7 reviews
wow...
all ill say is i run a hks ssqv ser iii non-reciruclated i can hit full boost, go straight into N, and come to a stop no bog, no un-even idle, nothing my sr20det drives like a new car .... to the OP, its your car... be your own judge and learn from your own experiences and take this all as advice not the truth |
#41 | |
#42 | |
![]() Join Date: Dec 2008
![]() Feedback Score: 12 reviews
my old hks was leaking that is why i replaced it. IIRC i didnt have any problems untill it started to leak. i will let you guys know how it works when it dries up. |
#43 | |
lol, i guess so but i will say that i have driven both recirculated and atmospheric BOV'S and im not declining the mechanical benefits of a recirucalted bov's when running maf's BUT....all this talk of how it makes it "lose power" or run like garbage is all just he said she said BS imo |
#44 |
I think i have magical SR #3 I have a SSQV. no probs with it, no stalling no rev drops.
I guess the point is that there is no benefit to the OP by changing his stock recirc setup. He can do it if he wants and it wont really hurt anything either.......
#46 | |
Well, first off, I got mine done at PG like you, and so here are the things I did.
My upgrades so far: 1.)Reset the Mine's ECU that came with the clip back to the stock tune. 2.)Walbro 255 lph 3.)FMIC(CX racing with knockoff Greddy Type S) 4.)Circuit Sports turbo elbow 5.)3 inch downpipe 6.)Circuit Sports Test Pipe(Not much louder) 7.) 2.5 inch catback(custom made from previous owner, gonna get a real exhaust soon) I set my idle to 850, and my BoV isn't very tight(so I only get a tiny amount of compressor surge when I'm at like 1/2 psi and let off too slow). In second, I'll hit full boost 8 psi(washer on my turbo), and then let off, pshhh blowoff, rpms go down from 3600, then it goes to about 450 at the lowest, then shoots right back up to 850. Yeah, it's not how i'd LIKE it, but it doesn't bother me too much.
#47 | |
blitz tuned ecu. apexi intake kit.(need to replace the cone) 3" turbo elbow 3"JDM downpipe SMIC hks ssqv3 full exhaust with 2 resnators and 3 "magnaflow muffler. my car is pretty quiet and it sounds bad ass! set at 10LBS |
#48 | ||
http://zilvia.net/f/engine-tech/352940-mines-ecu.html Mine's Inquiry Form I can tell you it caused problems with my engine, because I replaced my oil pan about two months ago, no metal or anything in the pan. I started to run the car a bit harder, and noticed it would stutter a bit after 4k rpms, did an oil change about three weeks ago, to find gold sparkles in my oil. Luckily its still running, but I'm assuming there was some damage done to my bearings, which sucks since I just bought this motor, and will probably have to rebuild it. Be careful with that blitz ECU.
#49 | |
i dont know but my sr is pretty fucking tits. i stay side by side with my buddys s14 w rb25. he gets me on the stop but on a roll im side by side. but i am going to get my car retuned with diffrent injectors and a maf in about 6 month aswell as a turbo..? i jsut have to finish some other things and pay for some tickets. |
#50 | |
Trader Rating: (58)
THere are way to many variables with these sr20 cars in terms of previous owner and setup to say that they all do or do not work...you are correct...but 98% of the ones that 'work just fine' either have high idles, have extremely tight blow off valves, or have their IACV cranked or similar to help compensate. There is no other reason for it...no magical setups, not mystery tunes, nothing. So while we may seem overbearing saying it won't work, the truth is that the only reason it 'will' work are due to extracurricular issues.
