![]() Join Date: Jul 2009
![]() Feedback Score: 17 reviews
Wheel Fitment Question Thread
This thread is to post your question about wheel fitment and is used to HELP EACH OTHER. This is not to talk shit about someone because they want to ask a question about fitment.
Rules: 1. SEARCH! If all fails come here. We are here to help. 2. No shit talking if your not gonna help someone out DONT POST! 3. Pics are not mandatory but will obviously help. 4. The main reason for this thread is to not clutter up the OG fitment thread and stop all the chit chatter. 5. An answer like yes or no obviously wont help so by posting a response your helping to make the question work. If it is seems like an impossible setup a simple no is ok. Make you response useful. EX: Q: Will a 18x10 +18 fit on an s13? A: Yes with some camber and stretched tire. Suggested setup 225/40 about 2.3* of camber maybe less with small pull. Pic: ![]() SIMPLE! JUST SHARE YOUR KNOWLEDGE! ![]() ANY SUGGESTIONS TO THE THREAD PLEASE PM ME. ITS MY FIRST BIG THREAD. HEHE. Last edited by frsh4; 06-23-2011 at 10:12 PM.. |
#2 | |
![]() Join Date: Dec 2003
So i posted my car in the fitment whore thread and it seemed to confuse a lot of people so here is my contribution.
My pics have no spacer but you have to remember that when its on the ground its not going to look the same as weight will make the wheels camber in. 17x8 +33, no spacers, stock body, on springs and struts (eibachs and GR-2s if you must know) ![]() ![]() ![]() i was told it will look like this when its on the ground. except this is 17x8 +35. So you do the math. Im also planning on running a 215/40 which is what this cars has also ![]() Now for all you s14 guys who may be looking at similar sizes (assuming you can do math) here is similar fitment. Goes to show how much different there is between 13's and 14's. Quote:
![]() **CoUpe LOve** Member #00 |
This is the first car i can think of that has a lot of width and a good camber. Maybe he can chime in and help. But im think your gonna end of with a lot of poke depending on your aliment settings. I say go with a 255/35 for stock fender and super sweet pull.
http://thatistupid.tumblr.com/ |
Also found this it is the the same width and hes running 225/40 federals, so expect a lot of poke and camber without over fenders. Forgot about this thread. Lets use it!
I need tire and camber suggestions. Im going to be running a 17x9.75 +25 all around. From calculations I'll need a spacer in the front so I have 10mm spacers for te front. Now this car will be drifted so what camber should I be running up front and out back? Currently I'm at about -2 in the front and -.5 out back. And I'm planning on running a 225/45 sounds good? Lmk
![]() Join Date: Sep 2009
![]() Feedback Score: 23 reviews
how about 18x10 & 18x11 +9 all around on s14 kouki
thinking 235/35/18 and 255/35/18 for tires how much camber do you think I'll have to run on stock metal with a good roll\pull? |
i'd say do a little inner fender arch work, and you could be sitting under -1*
http://garagemakeshift.blogspot.com/ |
#12 | |
If your car is slammed and with that amount of camber I'd run a 245/40 or 235/40 for traction sine you need grip for drifting.
Battles 17 x 9.5 +15 on all 4, Isis suspension arm kit, ksport kontrol pros. (Support local!)
What im looking for is tire size advice for a clean look with my new setup. Open to any suggestions so fire away. ![]() Last edited by blingbling; 07-08-2011 at 12:26 PM.. Reason: broken image code |
#14 |
Hey guys lets try and quote the question if you are answering someone just so they know who the answer is for.
#16 |
With you having suspension arms and all that running minimal camera is possible but it means running a stretch tire. So 215/40 is suggested with minimal pull and your super slammed.
#20 | ||
11 +9? Soo I have 9.5 +17, which fits perfect with a slight roll. With 11 +9 you're going to need to extend the fender out another 26mm, which is more than a little fender arch work. A nice roll and pull will get you there. I don't know why you would want to be under -1* of camber though, around 1-1.5 is guuuuuuud. Also, I feel like these two links could help people out a lot... Wheel Offset Calculator -- Wheel Offset Calculator ^ So basically enter the wheels you have now, and the ones you want, it tells you how much wider the new ones are going to be. And then there is this more advanced one which takes into account tire sizes ect... Online Wheel & Tyre Fitment calculator. Offset and Tyre Stretch -- This one is cooler, just takes a little more time. |
#21 |
![]() Join Date: Sep 2006
![]() ![]() Feedback Score: 10 reviews
here is my question about S14 wheel fitment
for the rear to be able to tuck 20's like this dude what offset would the wheel need to be for the rear to tuck and not have the rear fenders pulled, just rolled (obviously flatten the inner lip against the body, but still left stock looking on the outside) ![]() these wheels in picture MMR HR3 come in 20x8.5 +35 or 20x9.5 +40 im guessing he bought the 20x9.5 +40 i want to know what spacer he is running to have the car the way it is, or no spacer at all? also how much camber do you think he is running? -2, -3?? that question is just for the rear now question for the front lets say this car had a S15 front end conversion running S15 stock metal fenders i been told that the S15 fenders are wider than S14 fenders So if i want to run 20x9 or 19x9 in the front with S15 fender than what would the offset need to be to be tucked similar to the s14 in picture running lets say -4 camber Im going for this look on the S14 ![]() ive done lots of research and tried to find the wheels specs on it but no luck. i came to the conclusion that its probably 19x9 +6 front and 20x10 +23 rear this is based on multiple pictures that i seen of the Empress wheels in diff offset for the 9in and 10in someone please answer these question for me if you really know, if you have no idea please don't try to guess Thanks
*Pen Fifteen* |
#22 |
all these questions are honestly silly
stop worrying about the offset pretty much get the lowest you can if you're going for the 326 look you're going to have to run a lot of camber and in the end you'll probably have to use spacers 326 runs -7 to -10 degrees of camber in the FRONT and some what less in the rear right now on my S14 my fitment goes like this stock fenders with flattened lips -7 degrees front -6.5 rear 17x9 +22 front with 33mm spacer 18x10 +19 rear with 15 mm spacer I could easily lower the car and it would be tucking like you want its all in the camber |
#23 |
dude i know its all in the camber
thats not what im asking tho i know you can buy a 18x10 with -whatever offset and put it on the car and run like -8 of camber or whatever just to make it fit thats not what im trying to do tho i want a 20x10 in the rear tucking like 1in of rim and just want to know what offset the wheel needs to be to run like 2, 3 or 4 degrees of camber thats all
*Pen Fifteen* |
#24 |
Im looking at running 16x10 zero offset wheels in the front on my s13. Probably going to run 205/45s on them too. My question is, am i going to have any problems with rubbing coils or frame? Also, think i could get away with running little to no camber at all?
#26 | |
#27 |
![]() Join Date: Dec 2010
![]() Feedback Score: 19 reviews
hey guys! idk.. i like my fitment but then sometimes i feel like this can be alot better. specs are 17x9.75+25 and a 6mm spacer in the rear. tire size for the front is 215/45 which might be a bit overkill on the stretch and im running 224/45 in the rear. im rubbing on top of the wheel wells so any opinions on a more "fit" tire size? im also running-2 degrees of camber all around
#28 |
on a 350Z, 18x10 wheels, will -5 offset require pulling the rear fender? or will just roll and some stretch work? im not on coils yet, just springs that lower a little over an inch...
#30 | |
![]() Join Date: Jul 2005
This is ~-2.5 camber with a 255/40/17 BFGs on a 17X11 +12. ![]() Front shot: ![]() The fronts in those photos are 17X10 +7 with 245/40 S-Drives and ~-2.7 camber.
![]() Instagram - SJKnoop |
