#32 | |
![]() Join Date: Jul 2009
![]() Feedback Score: 17 reviews
I answered it to the best of my ability on post #16.
http://thatistupid.tumblr.com/ |
#33 | |
![]() Join Date: Apr 2010
Trader Rating: (38)
![]() Feedback Score: 38 reviews
If I'm not mistaken you can monster stretch 215/40 on a 10" or even a 215/35 on a 10". And since your wheels are .25 smaller, theoretically, that SHOULD help. I would not like driving around LA with that kind of stretch though. ![]() But to be honest, it's not worth the extra effort. Your fitment looks fine. |
#34 |
![]() Join Date: Dec 2003
i agree^^
I was gonna say got to 40 series all around and lower it more. But i think if you just lower it a little more it will look fine.
![]() **CoUpe LOve** Member #00 |
#35 |
![]() Join Date: Jul 2005
Take your front fenders off, then beat the shit out of your whole front wheel well with a sledge hammer, LOL. You can beat the top parts up a good 1/2 inch at least. Same goes for the front and back of the wheel well.
![]() Instagram - SJKnoop |
#36 |
![]() Join Date: Dec 2010
The fender wells are beat on quite well lol its just rubbing at the very top where the entry for coilover would slip in. Also my stance coils are maxed out up front and i could slip my hand through. Hopefully a 235/40 will fill in the gap and I could put more tire contact to the floor. Thanks guys
#37 | |
#39 |
More low= more camber. Remove collars.
#40 | |
Trader Rating: (38)
If you're worried about your wheels rubbing on every little bump. Maybe slamming your car isn't for you. But to answer your question, yes. You can fit 18's with a roll. Depending on the width of your wheels and what kind of tires you have will determine if your wheels rubs or not. Camber can aid the fitment a bit. However, a roll will only get you so far, it has its limits. If you plan on slamming the car with wide wheels + low offset, you'll need more fender work than a roll to achieve that kind of stance. Like frsh4 said, you can remove collars to go lower. And if you have Fortune Auto coilovers, you can always cut the lower mounts for the fronts or flip them. As a loophole, get some lame high offset 18x7 wheel and slam that. That won't rub as much when the car is slammed lol |
#41 |
Trader Rating: (38)
My question is for those S13 owners, how much of a pull for the rears will be needed for 10" +18?
I can't tell how much of a pull the couple on the front page has. But it doesn't look like much. I've seen a hatch that was higher off the ground with the same wheel specs and he had to pull the fenders about ~25mm. The hatch is running a 10mm spacer but let's imagine the car without one, will that kind of pull be necessary? Generally, do coupes have wider wheel wells? Or am I trippin out? ![]() ![]() |
#43 |
![]() Feedback Score: 10 reviews
this is a great thread.
im looking to tuck on a stock body zenki, with all fenders rolled. 17/18 stagger, I m not going for the 326 power look of tucking half the rim, just to were the lip of the rim is tucked. my question is, what offsets are ideal for this? i know i can always add more camber but i am trying to do it with minimal camber. I have no problem beating the shit out of the fenderwells to acquire some clerance, and this is not a daily driven car at all. I have done some searching, and found all the information i could ever want on if i wanted flush fitment, but not much on the look i want. thanks! |
#44 |
Trader Rating: (38)
Oh that's right I forgot to take that into account, if I were to run a smaller tire will that minimize the camber? Because according to rimtuck, that hatch is running around 3-3.5* and according to the first page, the coupe is running about 2.3*
#45 |
Yeah, it'll be easier to fit with a smaller tire. On a 10J you could run 215/40 Federal 595's since they run wide. It'll be like running a 225/40... which are damn near impossible to find. Unless you don't mind running 45s.
#46 |
![]() Join Date: Jul 2008
![]() Feedback Score: 13 reviews
Hey knoop, is there a reason you run such a wide front tire other than it being grippier? I have 17x10 +0 front and am thinking of running a 225/45 dz101. Couldn't you step down a size in the rear too so the pull wouldn't be to far out? I'm not critisizing just asking cause your shit looks dope as it is.
#47 | |
The coupe is mine I do look to have a smaller tire a 225/40 dunlop. The pull is very little hardly noticeable.
#48 |
I agree with 100%. I ran dunlop all around and in the front the gap is less with federal and i rub some what with feds where dunlop i actually had a gap.
#49 | |
![]() Join Date: Sep 2009
![]() Feedback Score: 23 reviews
thanks dude ![]() |
#50 |
Trader Rating: (38)
Heard you can only fit 10" +18 wheels up front on the S13 with Apexi N1 coilovers along with Megans.
With that said, how much of a spacer will I need to run in order for them joints to fit stock bodied S13? And what kind of fender work will I need to make them fit? Or should I go with a 9 or 9.5" in front. I really don't want to run staggered at all. But if a 10" +18 is not worth the effort, then what would be a better stagger 9 or 9.5"? |
#52 | |
![]() Join Date: Jul 2006
#54 | ||||
Either way, I'd recommend a 235/40 over a 225/45 just because it has a shorter sidewall, the tires overall height is smaller so you'll have more clearance. Quote:
I loved the way my S14 felt when I was running 17X9s all around...so you don't have to stagger if you don't want to. A 9/10 stagger is fine, but I'd be more inclined to do a 9/9.5 stagger if you decided to run a staggered set up.
#55 |
well i got my wheels on camber is maxed in the front and in the rear is -.5. i want to go lower but i need fender work. now my question do i need a roll and pull? or will just a roll suffice thanks in advance
#56 |
Trader Rating: (38)
For the fronts, if the coilovers can go lower, you can hammer the lips and give it a slight roll. How much camber is in the front anyway?
For the rears, you're going to need more camber to go lower so you're going to need new arms that can dial in more camber & to try to keep the toe as close to zero. After that you're going to need a slight roll and possibly a slight pull. |
#57 |
Roll and pull and lower. Try lowering it all the way and decided what you got to do. Shouldnt take long to lower all the way. What tire size are you running and offset? Looks like the new xxr +25 but pretty sure your running spacers.
#58 |
I already have all arms in the back for adjustability. I'm going to roll and pull my fenders now, and then go lower. As for camber I'm maxed in the front in the rear -.5. I'm trying to keep it minimal in the rear since it gets drifted. And in the front I'm running 10mm spacers and in the rear nothing. After this I'll probably throw a little more camber in the back.
#59 |
who told you half a degree was good for driftiing?
I would say your going to need to go to at least -1.5
#60 |
Also your fronts dont look maxed out.
