Old 11-09-2011, 06:18 AM   #1
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
Originally Posted by Slo_240sx View Post
Fred, do you have the part number for that radiator? Looks perfect. I wonder if flexalite fans will mate up to that.
Here ya go, AFC-80107N from Summit. I think I'll have to run a surge tank to get it to bleed right, might get away with just putting a rad cap in the upper rad pipe but it's iffy.
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 11-09-2011, 01:51 PM   #2
Slo_240sx
Slo_240sx is an unknown quantity at this point
Thanks Fred! I think an inline fill tube and cap on the upper hose should suffice.
Here is info for the AFC-80107N Radiator:
Afco #80107N Scirocco-Style Radiator...$256.95
Overall Height...13-1/4"
Tank Height...12-1/2"
Tank Width (Top)...21-1/2"
Tank Width (Bottom)...21-1/2"
Width With Flanges...25-1/2"
Tank Thickness...3"
Filler Location...None
Inlet Size and Location...1-1/4"...Right Side
Outlet Size and Location...1-1/4"...Right Side
Dry Weight...8.1 pounds
Moroso 63745 Radiator Hose Filler Inline 1 1/4"
Slo_240sx is offline   Reply With Quote
Old 11-09-2011, 06:04 PM   #3
mantas
mantas's Avatar
mantas is an unknown quantity at this point
RB
Tank Thickness...3"
Winning!
I'm going to slang my Altima fans and radiator to swap in this radiator + r33 clutch fan.....
mantas is offline   Reply With Quote
Old 04-05-2012, 04:34 PM   #4
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Bought this same filler as well, however, while the outer diameter may be 1.25" on everything, the thickness of the walls on the stock radiator, 16V/Scirocco radiator, and the filler all vary, thus resulting in different inner diameters.
The inner diameter of the inlet and outlet on the stock radiator is 31mm, while the 16V radiator is 28mm, and the walls on the inline filler are really thick, and so the inner diameter is only 26mm. Will it be safe to use?
Old 02-11-2012, 10:46 AM   #5
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
Thank you!!!! This is exactly what iv'e been looking for. And its not a $400 dollar price tag like chase bays
s13_maJiK is offline   Reply With Quote
