Old 11-19-2011, 11:13 AM   #1
Drift Nation
Drift Nation's Avatar
Drift Nation is an unknown quantity at this point
Solid Avid Mount/Xcessive Solid Tranny Mount
So I've got these^ but the Xcessive is a defect and needs to be re-drilled. I don't have the time today to drill em but my stock engine mounts are pretty bad and it's my only day off for a week and wanna throw em on. Bad idea with the stock tranny mount for a week or so?
YES it's a daily, idgaf about pussy-ass vibrations. YES I understand I have to locktite all my small bolts and re-torque everything to be safe. NO there isn't any plastic pieces in the interior, or carpet, or heat (I scrape frost off the INSIDE of the windshield daily), or a/c (obv), it's a daily/drifter in the making for next season.
Drift Nation is offline   Reply With Quote
Old 11-19-2011, 03:03 PM   #2
Drift Nation
nobody at all?
Old 11-19-2011, 03:37 PM   #3
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Originally Posted by Drift Nation View Post
nobody at all?
Patience man, the site is pretty dead on the weekends.
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 11-19-2011, 03:47 PM   #4
Drift Nation
Ahh, yes patience is a virtue. I have no life besides work and working on the whip haha.
Old 11-24-2011, 10:15 AM   #5
Drift Nation
Got both installed the other day, I love em! Zip tied front end ain't cuttin' it though
Old 11-24-2011, 02:09 PM   #6
TheRealSy90
TheRealSy90's Avatar
Wow, my Xcessive trans mount had to be re drilled also, I called them and they said they would have it fixed. So much for that.
It also lowered my transmission so I can't run a shift boot anymore, not to pleased with that...
Such a good signature.
Old 11-24-2011, 02:59 PM   #7
pincheturbo
pincheturbo's Avatar
Trader Rating: (24)
pincheturbo is an unknown quantity at this point
Feedback Score: 24 reviews
you guys might be doing it wrong. i thought the same thing also, but in fact i was installing it the wrong way. there is a specific order to installing it but i cant remember exactly what that was off the top of my head.
but yes everything rattles like a BITCH and it lowers the transmission a good couple inches. nothing a "JDM" Knob from 9K cant fix. i'll go run out right now and snap pics for you bros
my for sale thread:
http://zilvia.net/f/sale-items/53975...e-30-less.html
NISMO, NRG, JDM turn signals, misc engine parts
pincheturbo is offline   Reply With Quote
Old 11-24-2011, 05:34 PM   #8
pincheturbo
Trader Rating: (24)
my for sale thread:
Old 11-24-2011, 08:56 PM   #9
TheRealSy90
It's not an issue with the shiftknob. My shifter hits the hole in the sheetmetal where it comes through the bottom of the car. Thus I can't run the rubber boot there because it binds up and won't go into 2nd 4th and reverse. Also due to the new angle of the motor and transmission, I blew up the rubber bushing between the stock two piece driveshaft twice. I had to purchase a Driveshaft shop one piece after that to avoid it.
Old 11-24-2011, 09:15 PM   #10
TheRealSy90
Found my pictures.
You can see here the holes that were pre drilled, and where I had to drill new ones. I actually didn't get the second hole lined up correctly still and only used one bolt
So this was the resulting angle of my stock driveshaft.
And after a week of driving, this happened.
Replaced the bushing and it broke again after about another week.
And this fixed my problem from there on. Sorry about the blackberry pictures :$
Old 11-24-2011, 09:23 PM   #11
twinspool
twinspool is on the path to ruintwinspool is on the path to ruin
Couldn't buy the metal bend it/drill it to make your own and most likely fit better?
twinspool is offline   Reply With Quote
Old 11-24-2011, 09:29 PM   #12
TheRealSy90
The point is the parts have been shipped out defective multiple times and they are yet to fix it.
Old 11-24-2011, 09:49 PM   #13
sidewayz240
sidewayz240's Avatar
sidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nicesidewayz240 is just really nice
Plus it's a just a horrbile design.. Amount of thought and testing into that mount? Zero.
-Trevor
sidewayz240 is offline   Reply With Quote
Old 11-24-2011, 09:53 PM   #14
twinspool
Hence my comment about making it yourself instead of buying a simple formed and slotted plate.
Old 11-24-2011, 10:16 PM   #15
TheRealSy90
This is what I meant about the shifter clearance issue.
3rd gear.
Neutral.
4th gear. Touching the sheet metal.
Old 11-24-2011, 10:18 PM   #16
TheRealSy90
At the time of purchasing these mounts, I was under the impression of "plug and play" installation. I did not have the time to make my own mount. Of course if i would have known of the issues I eventually had, I would have made my own mount.
Old 11-25-2011, 12:48 AM   #17
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
Forget the whole doesn't line up hole crap. WHY would you not put spacers to bring up the tranny to the correct position??
Hashiriya415 is offline   Reply With Quote
Old 11-25-2011, 04:44 AM   #18
@(O_o)@
@(O_o)@'s Avatar
@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light@(O_o)@ is a glorious beacon of light
It seems as though you could flip it and it should fix the height problem.
@(O_o)@ is offline   Reply With Quote
Old 11-25-2011, 05:04 AM   #19
essforteen
essforteen's Avatar
Trader Rating: (50)
essforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant futureessforteen has a brilliant future
Feedback Score: 50 reviews
Exactly i think they put it on the wrong way! flip it around and see if it works! If you
tried this then they made some messed up shit! who would want their transmission
lower than the frame rails??
essforteen is offline   Reply With Quote
Old 11-25-2011, 09:10 AM   #20
n240sx
n240sx is an unknown quantity at this point
Yep I did the same thing when i had a set of xcessive mounts. I originally installed the tranny mount wrong and had similar issues. I flipped it around and it worked great. Unfortunately, I don't have pics of it correctly installed and it's no longer installed on the car.
1993 KA24DE-T
n240sx is offline   Reply With Quote
Old 11-25-2011, 09:20 AM   #21
KrazyS13
Trader Rating: (28)
KrazyS13 is an unknown quantity at this point
Feedback Score: 28 reviews
You can clearly see that mount is suppose to be mounted the opposite way.. I can't believe so many people can get it wrong and think it's right...lol
Use some ingenuity once in awhile.. If something seems that far off with what should be a quality product from a reputable company then something probably isn't installed correctly.. Would've taken 5 minutes to flip it and try it the other way...
Or you could've just called them and explain the situation.. They probably would've just said "flip it dummy"...
KrazyS13 is offline   Reply With Quote
Old 11-25-2011, 09:29 AM   #22
MrFairlady
MrFairlady's Avatar
Trader Rating: (31)
MrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant futureMrFairlady has a brilliant future
Feedback Score: 31 reviews
Send a message via AIM to MrFairlady
JESUS....I really hope you all have only paid $10 for this thing or got them for Free.
WTF is the point? Just bend a Metal bar and drill some holes - Done & Done. Its a wonder its not fitting correctly.
Is Seriously a $60 solid poly mount just Drowning the wallet? Is this some New JDM tyte hype I'm missing out on?
Sorry just had to chime in on this one because of how retarded that thing looks and the problems your having from it.
/End thread.
z-tERty-2
MrFairlady is offline   Reply With Quote
Old 11-25-2011, 12:26 PM   #23
Hashiriya415
Trader Rating: (22)
^^^ feel the exact way. Was just about to post after seeing the price.
Old 11-25-2011, 01:06 PM   #24
Drift Nation
I did not have a problem with any height change in the tranny. Picked up the mount for 20 bucks knowning of the defect and after drilling the plate and installing the avid solid motor mounts there was only one possible way the xcessive plate would line up. I'll grab a couple pics to compare during lunch break.
Old 11-25-2011, 01:32 PM   #25
Enna
Enna will become famous soon enoughEnna will become famous soon enoughEnna will become famous soon enough
Send a message via AIM to Enna Send a message via MSN to Enna
Lmao "this shit doesn't fit right, oh they fucked up in making it."
Originally Posted by soreballz View Post
I hoped the candy would make it delicious, but I was incorrect.
Enna is offline   Reply With Quote
Old 11-25-2011, 01:51 PM   #26
Drift Nation
Neutral
4rth
Neutral
4rth
Old 11-25-2011, 04:22 PM   #27
TheRealSy90
I forgot to mention I don't have a short shifter lol.
Old 11-26-2011, 05:50 AM   #28
Drift Nation
Thought about that but after comparing pictures, looks like yours should be flipped and spun 180 degrees, that should fix your height problem.
Old 11-26-2011, 06:21 AM   #29
G5SR20240
G5SR20240 is an unknown quantity at this point
Lol no one thought about flipping their mount? Haha
G5SR20240 is offline   Reply With Quote
Old 11-26-2011, 01:46 PM   #30
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
after you flip it...you should also put back that t-mount brace with it like driftnaton did.
BOROSUN is offline   Reply With Quote
