Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > General > Motorsports and Skilled Driving
Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver.
Old 02-01-2013, 10:44 PM   #1501
90240sx07
90240sx07 is an unknown quantity at this point
ya its toe'd out in that setup id fix camber and see if they can get the rest closer to everything else
90240sx07 is offline   Reply With Quote
Old 02-01-2013, 10:59 PM   #1502
KA240SX808
KA240SX808's Avatar
KA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enoughKA240SX808 will become famous soon enough
Send a message via AIM to KA240SX808 Send a message via MSN to KA240SX808
They can do better than that.
Like stated earlier Front cambers almost a full degree off from each other.
What suspension mods do you have?
Cause if you have all the arms they should have no problem zeroing those things out.
I personally would not be happy with that alignment. But I'm picky so I suppose to each his own.
I would also add a touch more camber in the rear and bring it up to -1*
Front I would bring them both down to -3*
Toe because you have a decent amount of power maybe .20* in both sides in the rear. Front I like zero.
Oh, It's just that Hawaiian Kid......
- Looking for some parts:
* PigNose SMIC Grille/Vent P# 62697-44F00 *
LMK What you guys got
KA240SX808 is offline   Reply With Quote
Old 02-02-2013, 10:28 AM   #1503
240dream
240dream's Avatar
240dream is an unknown quantity at this point
I have full Spl rear arms stock everything up front. I thought s tiny bit of toe iout was good in the rear also they mess with my camber plates ill have to visually change them to match. But the alignment was free from my friend . So what should I go tell him zero front toe and add camber like 1*
All I read was "I'm a little bitch and don't belong in this thread".
240dream is offline   Reply With Quote
Old 02-02-2013, 12:52 PM   #1504
di-devol
di-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enoughdi-devol will become famous soon enough
I think toe out in the rear is wonky, feels like the back is steering haha. Whatever you decide to do, just try to make sure everything is close side to side.
di-devol is offline   Reply With Quote
Old 02-02-2013, 03:25 PM   #1505
KA240SX808
KA240SX808's Avatar
Toe out in the Rear is Bad and very scary lmao.
Your gonna constantly be fighting to keep the rear end in check.
Toe out in the back is never good, atleast from my personal exp and what I see.
But I mean alignments are all personal pref. It's just after reading that you have ALL SPL arms with the exception of LCA's your Alignment should have no reason NOT to be spot on.
I would atleast ask him to Zero out both Toe's, go toe in in the rear if you pls but most def not out.
And play with the camber if they want. It's not too bad but not something I would be pls'd with. Everyone has there own way of setting up there cars. I can tell you how to setup your car all day long. That doesn't mean it's gonna work for you or you'll like it. But you could use it as a starting point if you pls.
Old 02-18-2013, 03:09 AM   #1506
VinceDude
VinceDude's Avatar
VinceDude is an unknown quantity at this point
Is it normal to have to clutch kick a lot on a stock s13 sr20 with a t28 turbo? I tried doing little donuts today and I had to reduce throttle to about half way in order to avoid from oversteering too much but as soon as i get back on it after correcting my line I won't have enough power in time to keep the wheels spinning. Is this turbo lag or am I letting out too much on the gas? I just got this motor in and i learned on a n/a ka and I'm not use to turbos yet.
VinceDude is offline   Reply With Quote
Old 02-18-2013, 04:09 AM   #1507
KA240SX808
KA240SX808's Avatar
Depends how small the donuts your doing.
What gear are you in?
Old 02-18-2013, 10:36 PM   #1508
Black_Demon
Black_Demon is an unknown quantity at this point
Just flat out on the gas pedal and scream "POWERRR!!!" Hahaha
Black_Demon is offline   Reply With Quote
Old 02-18-2013, 11:16 PM   #1509
VinceDude
VinceDude's Avatar
Experimented with it more today and i realized that i was in too high of a gear. Donuts were pretty small so I had to keep it in first. She was a lot smoother then. This turbo biz is pretty funky.
LOL yeah I wish I could but I have to regulate my disturbance of peace to a certain extent.
Old 02-25-2013, 11:35 PM   #1510
DialedLife
DialedLife is an unknown quantity at this point
So far I my success rate is one out of three tries lol. All different corners. My succesful one was
aproach 90* corner from outside
start turning in +handbrake+clutch
the rest happened too fast lol.
But I didnt crash. Waiting for more rain to learn since I'd like to stay slow(er) for now. Plus open diff+nearly new tires is stupid.
DialedLife is offline   Reply With Quote
Old 02-26-2013, 09:52 AM   #1511
di-devol
Weld that thing up first. Sounds like you need to counter steer faster, but can't tell with an open diff.
Old 02-28-2013, 09:56 PM   #1512
iamtheyi
iamtheyi's Avatar
iamtheyi is an unknown quantity at this point
So, I've been considering dropping the wheel size down to 16's to help with the lack of power. Saving up for a KA-T is going to take awhile because I want to to do it right. In the mean time, I can drift my heart out. Consensus?
iamtheyi is offline   Reply With Quote
Old 02-28-2013, 10:16 PM   #1513
oni jake
oni jake is an unknown quantity at this point
Do it! Drive more now, get bigger stuff later.
oni jake is offline   Reply With Quote
Old 03-01-2013, 04:05 AM   #1514
KA240SX808
KA240SX808's Avatar
What size wheels and tires you running?
Old 03-01-2013, 10:27 AM   #1515
K_style
K_style's Avatar
Trader Rating: (63)
Feedback Score: 63 reviews
Doing it with open diff is hardly to call it drifting. It's more "Sliding" with un-even rear wheel spinning.
Open diff will get you BAD HABIT when you have LSD or locked diff later. because the car will act differently with proper LSD than open diff...
I suggest you to get the diff before do it again. so you can learn or have an experience with proper set up.
Old 03-02-2013, 05:20 AM   #1516
DialedLife
I see what youre saying. Ive been looking for another diff on craigslist.
I went out trying to drift tonight, i finally got one decent one, kind of. But the angle was weak. I had one where i had some crazy understeer and was still burning out. That felt pretty weird haha. Its stupidly annoying but its fun to try.
Old 03-02-2013, 06:15 AM   #1517
DialedLife
What stage/brand clutch would you recommend for a stock ka dualcam?
Old 03-02-2013, 09:58 AM   #1518
bataangpinoy
bataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymorebataangpinoy is not welcome here anymore
drive faster, crank up your rear tire pressure.
bataangpinoy is offline   Reply With Quote
Old 03-02-2013, 10:31 AM   #1519
iamtheyi
iamtheyi's Avatar
KA can only go so fast on the track I go to. It's maintaining it all the way that the car has an issue with. I ran 70psi in the rear.
Old 03-02-2013, 12:54 PM   #1520
SlideOrDie831
SlideOrDie831 is an unknown quantity at this point
some like toe out in the rear and some don't. little toe out in the front is fine and helps with turn in.
depends on the person.
SlideOrDie831 is offline   Reply With Quote
Old 03-02-2013, 03:51 PM   #1521
KA240SX808
KA240SX808's Avatar
So true
Then we try to justify it with a few more bolt on's till we realize it's not doing us much justice lol.
Luckily for me here is all short/med speed corners so 3rd gear entry is about the most I get.
Now to get that 4.375 R&P in there.
Old 03-03-2013, 12:02 AM   #1522
bataangpinoy
I drove one with all stock everything in a beater that me and two friends put together from spare shit lying around his home garage. The car was basically naked (no front body panels, bare interior etc.
Felt like it had alot more power than it should have(even at 28psi in the rear), and I was lucky to top out 2nd if I hit the longest straight properly. (very small track). Was still on stock SE wheels in the rear though. That probably helped out a TON.
I'll take your word on the situation, less rotational mass would help.
Or maybe you just have a tired KA24de?
Old 03-03-2013, 12:28 AM   #1523
KA240SX808
KA240SX808's Avatar
Most KA's out there are tired.
Rebuilt ones feel so nice.
Most KA's won't put more than 120-130 down with bolt ons.
Some lucky ones with healthy ones get to put down 140+.
Seen a rebuilt on with I/H/E put down 155.
Old 03-03-2013, 01:47 AM   #1524
iamtheyi
iamtheyi's Avatar
I'm going to try and do the 248/232 cam swap on the car. That with the z32 16's should help a bunch. I am probably going to go strip out the interior of the car soon too. For funsies and the experience lol
Old 03-03-2013, 03:13 AM   #1525
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
only thing really worth taking out from the interior's basically the air bags and spare tire.... anything else you're not going to shave too much off. carpet, all interior panels, rear seats you're looking at around 30-40 pounds tops.
Old 03-03-2013, 02:21 PM   #1526
e5s4y
e5s4y is an unknown quantity at this point
anyone here running the rear ebrake leverage extenders like the ones from gktech? I just ordered a set and will be installing them sometime next weekend.
for anyone with them, how do you feel about them?
BustedS13: anything you can hide on your person is free. junkyard law.
e5s4y is offline   Reply With Quote
Old 03-03-2013, 06:39 PM   #1527
KA240SX808
KA240SX808's Avatar
Much better than trying to tighten the cables beyond belief.
Old 03-06-2013, 12:03 AM   #1528
Tearlessj
Tearlessj's Avatar
I don't have the Gk-tech ones, but I did just modify my stock ones. It didn't cost me a cent. It works great, just remember now your locking point for your e-brake it a lot higher than it used to be. You'll get the hang of it super quick.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 03-06-2013, 12:17 AM   #1529
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Out here we have our events at an old airport and there's usually a 3rd gear 70+ mph sweeper in the courses. Last month my stock ka was keeping my car sideways with 225/45/17s on mb battles with 40 psi through the sweeper and I was entering at like 5k in 3rd whatever that translates to.
pacotaco345 is offline   Reply With Quote
Old 03-06-2013, 01:32 AM   #1530
KA240SX808
KA240SX808's Avatar
There's no doubt it can't be done. But I assure you our N/A KA angles are much shallower than that of a Stock SR.
Which I mean we all know but just throwing that out there.
I'm gonna see how far I can push my KA with knuckles until its not enough.
What kind of tires do you use in the back?
Last time I had 225 DZ101's and they seemed a bit grippy for my liking as far as sliding goes.
