#123 | |
![]() Join Date: Dec 2010
Trader Rating: (39)
![]() Feedback Score: 39 reviews
he was implying he'd rather trade his megans(form) for OP's PBM's(function)...
![]() Quote:
IG - allen.kerose |
#124 |
Wow have you not read anything ? I already did that. I've known to do that if coils don't go as low as you want them. These aren't my first set of coils. I've already removed both collars and added a good amount of preload. Added some camber and its still not as low my old coupe
#125 |
Im kinda with the op, not sure where this whole super low thing comes from. 1 collar removed no preload, 17's. Dosnt bother me too much since texas roads are shit and going lower makes the car almost undriveable.
#126 |
Trader Rating: (39)
ohhh i dont know, maybe..
![]() hopefully all goes well tomorrow and OP gets ahold of pbm, chime in and let us know afterwards op ![]()
IG - allen.kerose |
#127 |
#128 | |
![]() Join Date: Jan 2010
![]() Once again with all collars in tact..
#129 | |
Super Moderator
![]() Join Date: Jun 2004
Trader Rating: (73)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 73 reviews
#130 | |
#133 |
![]() Join Date: Jun 2011
i know its not the same, but heres mine. pbm pro's maxed out in the front, can still drop a bit more in the rear, but still have all the collars in place up front. tires are 215/45/17 and 225/45/17
BustedS13: anything you can hide on your person is free. junkyard law. |
#135 | |
Martin from PBM and alexisthemovie told me add camber. added camber and still not where i want it to be.: ![]() ![]() ![]() ![]() |
#136 |
#138 |
measure the distance from spring seat to the top of threads, subtract that from the length of your spring, order that size spring...... no change in preload and you'll have extra ~2" of drop possible.... /endthread
#139 |
![]() Join Date: Jan 2006
Your coilovers look to have an unusual amount of space between the camber plate/pillow ball mount and the upper spring perch. Post a close up photo of that area?
#140 |
#142 |
they never gave me a real solution. they said to add camber. i did and its still not as low and where i want it to be. theyre waiting on Dan to return from japan but they at least forwarded the emails i sent them to him. they said they would get me shorter springs if its still not going low enough.
#143 |
It does look normal, perhaps it was just the angle.
Several years ago, before we had options such as PBM, KTS super lows, D Max etc. I used to shave down the lower insert/spacer that goes between the pillowball and upper perch for an additional 5-10mm of low. If going with a smaller spring is not enough, that may be an option for you. |
#144 | |
i think the smaller spring should do it, but i shouldnt i be able to go low even with both collars on? Last edited by jeremyuhh; 03-26-2013 at 04:31 PM.. |
#147 | |
1 collar removed, 0 preload, -2.8 camber, same tire and wheel size: ![]() 2 collars removed, a lot of preload, ~-3 camber: ![]() |
#148 |
Back from Japan today
Lots of good suggestions here. dont preload springs do settle over time Photoshopped ride height is not really drivable 45 series tire on 17 is correct, better for traction and ride and tucking In the first post you said 0 camber, and the last post said -3 camber? Having 0 camber certainly makes the car higher, and negitive camber makes the car lower. the standard for any drift car is maximum front camber and add wheel spacers to get the fitment back many people increase camber with the aftermarket FLCA which adds track width which is also good When the car is cambered in the cars weight focuses on the inside of the tire, and it can compress it more. For tire wear its not good but for drift traction at lock its great because the caster adds too much positive camber when you camber in and change offset with spacers the car also gets lower because wheels are going out and up due to the camber. Anyhow I have ordered 135mm springs.. only $60 plus shipping but air freight will cost you if you are in a hurry
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate. Order Inquiry: IM me your real name and paypal address. Thanks for your business! |
#150 | |
Never though camber would change the ride height that dramatically. on my first coupe, i also maxed out my coils after installing wheels and my fenders were already jammed up against the tire at 0 camber, thats why i was wondering why these coils didnt do that and thats why i thought camber didnt affect ride height. but now i know. and lastly, Thank you for ordering the springs. im not in a hurry. what are the springs rates ? 10kg/mm ?do i pay now or wait until they have arrived? |
