03-23-2013, 02:13 AM | #1 |
PBM Comps NOT LOW AT ALL WTF?!
UPDATE: i removed BOTH collars and added about 1 turn of preload this morning on each front coilover and i am no where near how i was with my stance gr+ pro (pictured below on my red coupe) im at 0 camber and i dont even rub. yes, no rubbing at all. i thought PBMs had "FAMOUS Super low ride height ability" as quoted straight off their site.
tons of preload to where i need frim grip with 2 hands and the wheel off to turn the spring both collars removed completely maxed out 0 fucking camber not even covering or touching tire. and i can drive with no rubbing issues. my sidewalls should be demolished by now Before it settled: After it settled: when i had both collars on, 0 preload, maxed out low. nasty gap: ------------------------------------------------------------------------------------------------------------------------------------------------------------------------- i have pbm comp coils, maxed out fronts, collars still there, and im not even touching tire. theres at least half an inch of wheel gap still. i thought PBMs were supposed to go suuuuper low without removing collars. specs: pbm comp coils. 10k front spring rate. 0 preload. maxed out. 2 collars on. 17x9.5 +15 battles on 205/40R17. 0 camber & 0.9 toe from running stock wheels wtf is going on? i had stance gr+ pro with 1 collar removed, same wheel and tire size, except +12 offset and they went alot lower: Last edited by jeremyuhh; 03-25-2013 at 02:25 AM.. |
03-23-2013, 02:16 AM | #3 |
03-23-2013, 03:02 AM | #9 | |
Already stated. 0 preload. ? I don't feel that will compensate for almost over a half inch of gap. |
03-23-2013, 03:23 AM | #10 |
Ill take pics tomorrow if you don't believe me and I just realized you don't have camber
Camber makes it LOOK like your cars lower because it brings the top of the wheels in torwards the fender but idk |
03-23-2013, 03:39 AM | #11 | |
I know both those guys^^
"it brings the top of the wheels in torwards the fender but idk" Do you know what direction is in and what is out? and what a fender is? and what camber is?
S.P.P.S. Member #00 **CoUpe LOve** Member #00 |
03-23-2013, 07:34 AM | #14 | |
Sorry but FA is terrible at going low specially in the front.
03-23-2013, 08:57 AM | #15 |
your doing something wrong , im on tein winding masters and have 18's ,im tucking rim in the front,preload is your friend
i messed up trying to post this so sorry guys if it shows up 3 times |
03-23-2013, 09:03 AM | #16 |
and by looking at those pbm pics it looks even if you do flip the brackets it will be the same, aside from the camber obviously ,but the bracket is flat top and bottom.
03-23-2013, 09:09 AM | #17 |
and lastly why wouldnt you have just removed the other two collars when they were off the car? even if your not slamming it you dont need them ...... but why buy pbm coilovers if your not gonna slam it .you bought "high end" coilovers for there performance asspects?
03-23-2013, 09:12 AM | #18 | ||
i guess im gonna have to remove collars but i dont think that will get me THAT low. both collars combined will give me a 1" drop at the most. |
03-23-2013, 09:15 AM | #19 | |
and yes i bought these coils for the its height capabilities and for drift. |
03-23-2013, 11:07 AM | #21 |
03-23-2013, 12:32 PM | #23 |
03-23-2013, 12:41 PM | #24 |
i have even the regulars and the fronts are maxed out with collars removed and preload up just a tad. and rear i have about an inch left. im tucking alot of 35series tire my cars super low. 10k front 8k rear. somethings wrong
03-23-2013, 12:55 PM | #27 |
Trader Rating: (38)
Feedback Score: 38 reviews
If they sent him a set of S14 coilovers, the rears would have been high as well. Also, the top hat would not have lined up with the strut towers of the S13.
03-23-2013, 01:01 PM | #28 |
First of all, your tires are tiny. Switch to 205/45.
After that, contact MAX and confirm that you have the correct part numbers. If so and if you want to keep the coilovers, your only option will be shorter springs. Maybe they will be willing to give you some sort of a deal, since you are dissatisfied. If not, get Swift Springs. |
03-23-2013, 01:06 PM | #29 | |
What in the fucks are you talking about man.
