Old 01-12-2014, 03:15 PM   #1
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
s13 school me on engine bay painting??
is the process the same as on a exterior of a car in terms of sanding, primer, paint, clear?
I know I could just rattle can it. but I actually plan on getting a good exterior paint job this year and I want the engine bay to look good as well. I want oem color. cherry red pearl (ah3) if iam not mistaken. This image has been resized. Click this bar to view the full image. Report this image
supersayianjim is offline   Reply With Quote
Old 01-12-2014, 04:43 PM   #2
Krusty_s13
Krusty_s13's Avatar
Krusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud ofKrusty_s13 has much to be proud of
I sanded mine down good. filled the holes i didnt need, cleaned it all, hit it with a sealer primer, sanded it again and shot it with a couple of coats of base and a couple of coats of clear. first time painting too. turned out pretty good.
only pic i have of the bay:
do it right and take everything out. painted brake lines and wiper motors are gross.
Krusty_s13 is offline   Reply With Quote
Old 01-12-2014, 05:50 PM   #3
Kingtal0n
Kingtal0n's Avatar
I am not an expert, but when I did mine I just treated it the same as the body, yes. Keep in mind it will be exposed to more dirt, oil, fluids and things that will try to eat it up so part of having a nice engine bay is keeping it wiped clean all the time. I used really expensive paint though so your mileage may vary
tinyurl.com/4l80er
Old 01-12-2014, 05:54 PM   #4
240boi115
240boi115's Avatar
240boi115 is an unknown quantity at this point
i hate to thread jack but where did you get that front bumper/lip? is it an oem bumper with an aftermarket lip? it flows sooo nice! also props on the color my hatch is a 90 and the same color!
Originally Posted by 13esim View Post
I'll trade you my 300ZX and my older sister
my 240 broke down..again
240boi115 is offline   Reply With Quote
Old 01-12-2014, 06:50 PM   #5
Def
Pretty sure that's a stock pignose bumper without a stock lip like most people run.
DEFSPORT
Old 01-12-2014, 08:26 PM   #6
supersayianjim
moar pics people. how much in supplies did you 2 guys spend?? and how long did it take approx.?
Old 01-16-2014, 06:37 PM   #7
Kingtal0n
Kingtal0n's Avatar
two days, $2800 in supplies for the entire car, including all the tape, sand paper, and time in the booth etc... First day was pulling everything out and taping it up, then straight to the booth. Gave it 14~ hours to dry and slapped the engine in.
tinyurl.com/4l80er
Old 01-16-2014, 06:45 PM   #8
supersayianjim
iam guessing the labor charge was yourself?? and did you replace the windshield also??
Old 01-16-2014, 06:47 PM   #9
Kingtal0n
Kingtal0n's Avatar
My friend Jason painted the car for me and did the body work. I am not skilled enough to do that- it takes years of experience. I pulled the trigger a few times for fun while holding my breath but he layed down the final coat. Yes I always get a new windshield when the car gets painted, thats just common sense. They are so cheap and you want that fresh seal and to get the paint in all the tight places the glass should all be removed. One of the tricks is to install the universal windshield strip upside down, it looks more pleasing to the eye.
tinyurl.com/4l80er
Old 01-16-2014, 06:56 PM   #10
blackrms13
blackrms13's Avatar
looks like a xenon lip to me
91' 240sx Fastback LE
blackrms13 is offline   Reply With Quote
Old 01-17-2014, 09:02 AM   #11
Mikester
Mikester's Avatar
Andy and I did all of the prep in my engine bay... Clean, scuff, sand, fill etc... Then primer, then scuff, sand etc and another 2-3 coats of primer.... Total cost was about $150-200 for everything IIRC. Had the bay shot at Schaeffer's N. Lindbergh location with S14 Ultra Red (AJ4) & clear for another $250.
Result is very nice:
Coat #1 finished:
If you want good results, DO NOT use rattle can. Either source out a compressor and airbrush or have it professionally done. Don't forget to let it sit a few days, then put a good coat of wax on it before putting everything back together.
Get with Andy- For the right price, he may help you with the prep.
P.S. Next time, post in the right section... jackass
Mike
Old 01-17-2014, 10:03 AM   #12
Purestock240
Purestock240 is an unknown quantity at this point
no matter what, just please dont be the numb skull who paints all the brake lines and half the hoses or the guy who uses house paint and a brush.
Purestock240 is offline   Reply With Quote
Old 01-17-2014, 10:41 AM   #13
supersayianjim
Coat #1 finished:
Mike
HOLY SHIT! that looks great. did you paint the engine bay before or after you sprayed the rest of the car??
Old 01-17-2014, 11:38 AM   #14
blackej7
blackej7's Avatar
blackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really niceblackej7 is just really nice
I used rattle cans:
I spent a lot of time prepping. This is the kind of result you can get. I did not use any clear coat. I would not recommend rattle cans. If I could go back and do it again, definitely spend the money and take the time to have it painted the right way.
blackej7 is offline   Reply With Quote
Old 01-17-2014, 12:20 PM   #15
Mikester
Mikester's Avatar
Thanks dude! Rest of the car still needs to be done... so BEFORE lol
Originally Posted by blackej7 View Post
I used rattle cans:
^^This^^
Old 01-17-2014, 05:52 PM   #16
supersayianjim
Thumbs up
I used rattle cans:
for rattle cans, that actually doesn't look bad at all.
Old 01-17-2014, 07:02 PM   #17
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
Remove parts, paint. The end
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
