#97 |
![]() Join Date: Sep 2008
![]() Feedback Score: 20 reviews
I know i havent update since feb 2014! i still busy with school and family but finally this time i have time work on racecar build project. I have bad news i found out CPR engine didnt good job rebuild my engine while i wanna check what inside engine then found valve hit on top piston so i have to start over buy new engine parts. One of most happy with CBM motorsport took care of everything!
Also i did disassembly and re-assembly engine but most new parts from CBM Motorsports, let start with engine issue. I went to Pierce College Summer Performance Engine class. ![]() ![]() ![]() ![]() I told to CPR Engine i want to refund money for damage but CPR Engine owner said you will happy with engine and valve hit on piston is nothing and no big deal. i still dont trust it for beat engine up at drift track sound like bad idea then i was move on and keep going build project to be continue. engine got new forged connecting rod, bore over .030 forged pistons low compression, valve job, and more. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() more coming update picture
#103 | |
I plan to order VooDoo13’s S13 Front Adjustable Tension Rods, i hope my front suspension are great increased steering angle. Front Lower Control Arm modded extended 25mm and gussted. The ball joint replaced Moog ball joint but it isn't tight as sitting on it im not sure how to explain like you know when you installed ball joint but it still loose around 2-3mm gap, is that ok? I will add mod adjustable lock stop next week. i still not sure about mod scalloped lower arm for allow knuckle to more travel because of PBM knuckle 45 of correction. I think about keep tein tie rod inner/outer and i already put GKtechs spacing the tie rods farther forward on it. You can see my front suspension setup kind of issue with SIkky sway bar clearance between rim but i haven't install sway bar so i believe do i need mod sway bar cut more short and weld it? I hope you guys can help or correct me whatever i doing wrong.
#104 |
small update picture nothing special
pick up new front bumper and skirt sides ![]() ![]() custom make 3" straight y-pipe to turn down tip before rear subframe with v-band clamp ![]() ![]() that it for now
#106 |
New ls3 valve cover instead ls1 valve cover because of rocket arm trunion upgraded hit baffle on the d/s valve cover also new color purple and red flakes. New LS2 CTSV power steering pump bracket, i will order turn one pulley next month. New oil catch can from CBM Motorsports with fitting and SS hose to -8an male on valve covers. Also i think about new water pump because i dont know used water pump miles but wait till next month.
![]() ![]() ![]() ![]() today, i will work on radiator and oil cooler mount and custom make ducting front end.
#108 |
dont much comment on here? last post and im done with zilvia build thread
I still use f-body power steering pump with ls2 bracket so i did drill, tap, and die made a fit. i still use s14 psp reservoir with sikky power steering lines kit. ![]() i have to cut radiator inlet tubing because try make fit hose. ![]() done! ![]() oil catch can completed ![]() ![]() i dont really like autozone upper hose, i still look for silicone hose 1 1/4 to end 1 1/2. ![]() ![]() i love custom make ducting ![]() ![]() ![]() im not done with ducting because i have to test with air flow make sure it though all of cooling system. i havent buy electric fan because im not sure which better. i still figure out where oil cooler mount at.
#109 |
The build looks awesome man, youve been working on it for quite a while and you can tell everything is being done right. Don't give up on it whatever you do cause that car is gonna be badass. wish i had some power steering stuff to give you
#110 |
small update
Thanks to Zerek Fewell done great job custom make front bash car fit into bunny rocket bumper ![]() ![]() custom make coolant surge tank and overflow tank ![]() beautiful color? ![]() right now, car is almost finish but need re do engine harness, new haltech ecu, fuel lines, get new windshield, need new tires, need new painless wiring, and few parts. that long to go and been almost 3 years now
