Old 01-28-2014, 10:20 AM   #1
signals13
signals13's Avatar
signals13 is an unknown quantity at this point
Updated parts coilovers and turbo!! 4/23/14
Have a bunch of parts for sale:
s13 KA24DE Cometic Head Gasket Used but never leaked- SOLD!!!
Intercooler 8"H x 22"L x 2 3/4W, 2" inlets- $40
JDM sport Oil Pressure gauge- $30
Blitz BOV w/flange- $40 (Sold)
Pipe w/BOV flange (maybe Greddy?)- $30
SOHC KA Maf- $30
KA24DE Injectors w/rail unknown condition- $20
ISIS Short throw shifter with copper bushing- $100 (Rubber boot has been Sold)
Ebay T04E turbo very little shaft play with SS braided feed and drain lines with 5 bolt to V-band flange- $150
RB20 ECCS Turbo very little shaft play, comes w/j-pipe and gasket- $150
S13 Differential still good with J30 cover- $40
S13 KA24DE Stock intake piping- SOLD
S13 Transmission and Right side motor mounts- $10 each
S13 SOHC KA A/C compressor comes with bracket if wanted- $40
S13 KA downpipe- SOLD
GTI-R SR20 Turbo Manifold- $60
S13 DOHC KA Exhaust Manifold- SOLD
S13 Stock Tension Rods w/good bushings- Sold
Universal intake filter- $10
x2 S13 Power window amp- $10
S13 SOHC KA gauge cluster- $20
x2 S13 Silvia Brick Headlight Glass LHD- $20 each
SR20DE Exhaust gasket- $10
T2, T3, T2 (make your own), & wastegate gaskets- $10 each
1 speed sensor harness is cut- $20 (Sold the one with the harness)
S13 KA clutch throw out bearing- $10
Aftermarket Oil Pressure sensor- $5
x5 Good condition KA DOHC injectors- $20 each
SR20 Rear main seal (still good)- $10
Oil pan bung fitting- $5
Miscellaneous Gaskets- $1 each
Miscellaneous Seals/O-rings- $1 Each
S13 passenger seat good condition- SOLD!!!
A KA24DE HUD working Gauge cluster with harness- Sold
Also have a Stock S13 ExhaustSOLD and KA DOHC Oil Pan.
All Prices are O.B.O. let me know what you need if anymore info thanks for looking.
signals13 is offline   Reply With Quote
Old 01-28-2014, 01:13 PM   #2
ada180sx
ada180sx's Avatar
ada180sx is an unknown quantity at this point
How thick is cometic HG? Bore size?
Sent from my iPad using Tapatalk - now Free
ada180sx is offline   Reply With Quote
Old 01-28-2014, 05:09 PM   #3
signals13
signals13's Avatar
1.1mm thick and 90mm bore.
Old 01-30-2014, 04:27 PM   #4
That1Coupe
That1Coupe is an unknown quantity at this point
FOUND THIS THREAD! Is the kad cluster for an s13 and is it fully functional?? If everything is good Ill be getting it friday.. ship quote to 79927.
That1Coupe is offline   Reply With Quote
Old 01-30-2014, 06:16 PM   #5
signals13
signals13's Avatar
S13 DOHC Digital Speed Gauge does work.
Old 01-30-2014, 06:26 PM   #6
signals13
signals13's Avatar
It will be about $112 shipped through ups ground.
Old 01-30-2014, 07:49 PM   #7
signals13
signals13's Avatar
HUD cluster and shifter boot pending sale!!
Old 02-02-2014, 10:04 AM   #8
signals13
signals13's Avatar
HUD cluster and shifter rubber boot sold.
Silvia Glass pending....
Old 02-02-2014, 12:37 PM   #9
s13mikesr20
s13mikesr20 is an unknown quantity at this point
bymp for de local
s13mikesr20 is offline   Reply With Quote
Old 02-02-2014, 05:39 PM   #10
SleeperTT
SleeperTT is an unknown quantity at this point
Send a message via MSN to SleeperTT Send a message via Yahoo to SleeperTT
Hey I need a speed sensor and an ecu. I know you have to speed sensor but my ECU went out today along with the 25A brown fuse. I have a short somewhere but I know for sure the ecu and two of the 25Amp brown fuses are cooked. Let me know what you have and how much shipped to 42330. Also I'm parting out a S14 if you have anything you need.
SleeperTT is offline   Reply With Quote
Old 02-08-2014, 07:56 PM   #11
signals13
signals13's Avatar
I pm'd you SleeperTT.
Old 02-10-2014, 10:48 AM   #12
signals13
signals13's Avatar
1 speed sensor has been sold, come on I know people need some of these parts give me you're best offer worst I can say is No.
Old 02-10-2014, 11:56 AM   #13
bikrman2
bikrman2's Avatar
bikrman2 is an unknown quantity at this point
Send a message via AIM to bikrman2
What could you do on the eBay turbo setup shipped to 12206?
Originally Posted by wangan_cruiser View Post
if you dont have any valuable information GTFO.
bikrman2 is offline   Reply With Quote
Old 02-10-2014, 05:20 PM   #14
signals13
signals13's Avatar
Its just the T04e turbo no actual kit. Whats you're zip to get you a quote?
Old 02-10-2014, 05:26 PM   #15
bikrman2
bikrman2's Avatar
Sending you a pm
Old 02-10-2014, 05:53 PM   #16
signals13
signals13's Avatar
Pm replied bro.
Old 02-10-2014, 06:39 PM   #17
signals13
signals13's Avatar
Blitz BOV is sold thanks guys keep it coming.
Old 02-11-2014, 02:48 AM   #18
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
interested in both those window amps if they are in working condition
808 2213861 text me
supreme_1 is offline   Reply With Quote
Old 02-12-2014, 05:44 PM   #19
signals13
signals13's Avatar
supreme 1 you have been messaged thanks.
Old 02-12-2014, 06:45 PM   #20
Meeekzz
Meeekzz is an unknown quantity at this point
interested in the cut speed sensor PM me about the condition
Meeekzz is offline   Reply With Quote
Old 02-16-2014, 09:27 AM   #21
signals13
signals13's Avatar
Meeekzz you sir have been pm'd.
Old 03-09-2014, 11:53 PM   #22
signals13
signals13's Avatar
Bump Tension Rods Sold thanks.
Old 03-10-2014, 12:50 AM   #23
jkfdhklfchil
jkfdhklfchil is an unknown quantity at this point
jkfdhklfchil is offline   Reply With Quote
Old 03-11-2014, 12:40 AM   #24
signals13
signals13's Avatar
90mm bore 1.1mm thick.
Old 03-11-2014, 01:03 AM   #25
Hooleeoh69
Hooleeoh69 is an unknown quantity at this point
How much is oil pressure gauge shipped to 92591?
Hooleeoh69 is offline   Reply With Quote
Old 03-11-2014, 04:47 PM   #26
signals13
signals13's Avatar
I'll do $40 shipped.
Old 03-23-2014, 10:20 AM   #27
signals13
signals13's Avatar
Bump I still have this stuff waiting for a new owner.
Old 04-15-2014, 01:27 PM   #28
signals13
signals13's Avatar
Cometic HG sold.
Also have an Ebay t28 turbo still runs good, no leaks, no smoke, with ceramic coated exhaust housing but I upgraded turbo $150 shipped
Circuit Sports one piece down pipe SOLD plus shipping.
Old 04-23-2014, 06:05 PM   #29
signals13
signals13's Avatar
Update added some new stuff!!!!
Update: I am adding HKS Special edition ATTKD (Time Attack Edition) coil overs from my S13 for sale.
I am not sure on the spring rates if I had to guess they should be 8kg/6kg, they are dampening adjustable. No leaks that I have ever seen or noticed just a bit dirty, I would suggest the buyer get a nitrogen refill.
These coil overs have served good on my daily, but I got a great deal on other suspension so these have to go. I'm looking for $850 o.b.o. plus shipping and paypal fees thanks.
The last picture is how low I had my car setup and it can still go lower.
Also S13 passenger seat has been sold.
Old 04-25-2014, 11:27 AM   #30
signals13
signals13's Avatar
Bump have to clear my garage of these parts give an offer we can work out.
