Old 01-07-2016, 04:58 PM   #1
fityamaha
fityamaha is on the path to ruinfityamaha is on the path to ruinfityamaha is on the path to ruin
Fully built S14 Partout (GTX3076, KA-T, SPHERICALS)
It’s come time to move on from my car so it is being parted out and every single 240 part I own is being sold. This car is extremely well built and the only negative is the body (bad passenger ΒΌ panel, bad front right corner, bad paint, no rust though). If I could afford to keep this car as a track day special, while maintaining my other hobbies, I’d love to do so.
Regardless, the entire setup is listed below. I have tons of spare parts, aftermarket and oem) see here: http://zilvia.net/f/showthread.php?t=621602
I have some pictures and can take many more on request. I can provide receipts for most everything.
The car is located in SE Pennsylvania (about an hour north of Philadelphia) I will ship, deliver, and would love for parties interested in the motor to get to drive it before it gets pulled for sale.
For outright sale, I’d start at $8,000. I didn’t want to list prices for each individual item as many things can be sold in packages. Just ask for any specific items’ asking price.
Old Motor (all stock except rods, pistons, & headstuds) put down 413whp/360wtq @ 19psi
Motor listed below was completed ~2 months ago and has ~3k miles on it.
This motor is showing impressive gains ~450whp/370wtq @ 17.5psi
pictures posted here ---> http://s1248.photobucket.com/user/fityamaha/library/
Built KA-T:
S13 Head
Hot tanked
New freeze plugs
Decked .006”
Brian crower titanium valve kit - BC0210
New valve guide seals
New valve guides
New OEM valves
Gasket matched and slight porting to exhaust ports
Gasket matched and slight porting to intake ports
248/248 cams w/ adjustable cam gears
Intake cam degreed to 121* centerline (no loss of low-end while retaining good high rpm)
All new timing components
New front cover with oil pump
Arp headstuds
New OEM headgasket
Block decked .006”
Block bored .020”
Cp 9:1 pistons clearanced to .0035”
Eagle rods
Polished crank
ARP main studs
Mishimoto 160* thermostat
Excessive Intake manifold
JGS motor and trans mounts
2” Aluminum radiator w/ shrouded dual 10” fans
Greddy catch can
Turbo kit:
Peakboost exhaust manifold
- Gasket matched and flange ported to transition from head to runners
- Swaintech coated
- Professionally re-welded in select areas
- Head-flange milled flat
- Turbo-flange milled flat
GTX3076r
- T3 .86ar 3”vband out
- Normal (healthy) shaft play .006”-.008”. Necessary for Garrett ball bearing CHRAs
- Always run with coolant (AN-6 lines)
- Turbine housing Swaintech coated
- T3 flange milled flat (coupled with milled manifold flange = no gasket, no leaks. Ever.
- 90* 2.5” elbow welded to output
- 7/8" SS drain tube
- Can come with boost leak testing tool
4” intake tube anodized black
Custom 3” SS down pipe with wastegate recirculation. (3” vband to 3” vband)
Custom 3” SS mid pipe w/ flex section (3” vband to 3” 2bolt flange)
Espelir jgt500 3” exhaust
Turbosmart hypergate 45mm
- New diaphragm
- New 9psi spring installed
AEM boost solenoid
Custom 1pc charge pipes from turbo to IC inlet and IC outlet to throttle body
- Sprayed black
- Hotside fits through factory hole
Treadstone TR8 intercooler
Synapse Synchronic BOV
- I also have the anti-stall kit also but don’t run it on my setup.
Fuel and Ignition:
ID1000 injectors
Walbro 400lph fuel pump
Aeromotive FPR
Top mount fuel rail w/AN-6 fuel line
Fuel filter AN-6
LS2 truck coil setup
- In mounting bracket
- OEM wire harness w/ female connector side wired for megasquirt
- Custom order Magnecore wires (LS2 to KA)
Drivetrain:
Mint Competition clutch “white bunny” upgrade
- Only just broken in
Stock 5spd
- Ebay short throw shifter
Welded j30 diff (3.916)
Steering and Suspension:
Steering rack spacer
Polyurethane steering rack bushings
35mm front sway bar
KTS coilovers
Tension rods
Wicked tuning Traction rods
ISR(isis) PRO RUCAs(brand new)
Isis rear toe arms
300zx rear uprights w/ full defsport sphericals and aluminum ball joint cone.
Energy suspension poly subframe bushings
Solid aluminum differential bushings front and rear
Brakes:
15/16 z31 master cylinder
Miata brake booster
- Over 2” smaller in diameter for more space and cleaner install
- Comes with custom hardware to bolt to 240sx firewall
Custom master cylinder heat shield
300zx front kit
- Quality SS braided lines
- Hawk DTC-60 race pads
Rear calipers have Hawk HT-10 pads
Interior:
AEM tru-boost gauge and controller
- Can control boost electronically
- Currently used as simply a boost gauge as boost is controlled by megasquirt
Innovate MTX-l AFR gauge
- New O2 sensor <1yr
MSPNP2
- Fully functional preassembled unit, very capable
- Plugs into stock harness
- Uses 50mm optical trigger wheel
- GM open element IAT sensor
- Runs all boost control.
- Controls radiator fans
- - using the low pressure wastegate spring allows the tuner to have a very large boost level window
- Tunes conveniently through Bluetooth from dell venue 8 pro tablet
- Or hardwire to same tablet or any computer
- Tablet included with sale with all archived datalogs, tunes, virtual dyno graphs, etc.
- Comes with a paid version of tunerstudio
Full OEM interior in great shape
Fueltech 1pc composite seats (from Harry’s race parts/SMAX) mounted on corbeau seat rails
These are only the parts currently on my car. I have another parts car that is being parted and all my spare parts (aftermarket and OEM) thread for these parts to come.
more pictures posted here ---> http://s1248.photobucket.com/user/fityamaha/library/
fityamaha is offline   Reply With Quote
Old 01-07-2016, 06:44 PM   #2
punn303
punn303's Avatar
Trader Rating: (82)
punn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymore
Feedback Score: 82 reviews
Pm sent for injectors and fpr
punn303 is offline   Reply With Quote
Old 01-07-2016, 06:48 PM   #3
dave123thomas
dave123thomas is an unknown quantity at this point
willing to sell the block?
dave123thomas is offline   Reply With Quote
Old 01-07-2016, 07:02 PM   #4
fityamaha
If by block you mean everything from oil pan to valve cover together, yes.
I don't want to split the block from the head.
Old 01-07-2016, 07:44 PM   #5
DJTTon
DJTTon's Avatar
DJTTon is on the path to ruinDJTTon is on the path to ruin
Are you parting interior?
What other OEM parts do you have?
DJTTon is offline   Reply With Quote
Old 01-07-2016, 07:49 PM   #6
NM_240sx
NM_240sx is an unknown quantity at this point
How much for the transmission backing plate and all bellhousing bolts shipped to 87114?
NM_240sx is offline   Reply With Quote
Old 01-07-2016, 08:26 PM   #7
Paradoxx123
Paradoxx123 is an unknown quantity at this point
How much for the turnkey swap. Motorset trans harness acc and ecu.
Sent from my Nexus 6P using Tapatalk
Paradoxx123 is offline   Reply With Quote
Old 01-07-2016, 08:40 PM   #8
fityamaha
Yes, I am parting out the whole interior.
I have a separate parts car and lots of spare oem parts on the shelves. Whatever you're looking for, just ask.
Old 01-07-2016, 09:33 PM   #9
S-Verteen
S-Verteen is an unknown quantity at this point
Free bump for ka-t
S-Verteen is offline   Reply With Quote
Old 01-07-2016, 10:07 PM   #10
drift96
drift96 is an unknown quantity at this point
How much for headlights turn signal bumper lights hood latch cable and lever and power steering loop shipped to 77511 paypal ready
drift96 is offline   Reply With Quote
Old 01-07-2016, 10:09 PM   #11
ProjectPanda13
ProjectPanda13 is an unknown quantity at this point
Send a message via AIM to ProjectPanda13
How much for the Z32 knuckle with spherical bushings?
Latez
ProjectPanda13 is offline   Reply With Quote
Old 01-07-2016, 10:10 PM   #12
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
How much do you want for the tru boost and ss brake lines?
Javi802 is offline   Reply With Quote
Old 01-08-2016, 11:36 AM   #13
2.5T_/<ouki
2.5T_/<ouki's Avatar
2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice2.5T_/<ouki is just really nice
PM on manifold.
2.5T_/<ouki is offline   Reply With Quote
Old 01-08-2016, 01:33 PM   #14
G3N3R41
G3N3R41 is an unknown quantity at this point
PM on GTX and FPR if not sold.
G3N3R41 is offline   Reply With Quote
Old 01-08-2016, 03:52 PM   #15
SoundEfx
SoundEfx's Avatar
SoundEfx is an unknown quantity at this point
How much for the following items shipped to 98052:
Bezels around the a/c control unit and radio
Driver and passenger window switch
Driver and passenger interior door opening levers ( the lever you pull to open the door from the inside.)
Trunk locking mechanism/latch (the part on the trunk door itself)
Thanks.
SoundEfx is offline   Reply With Quote
Old 01-08-2016, 04:08 PM   #16
fityamaha
Everyone has been PM'd
Thanks
Old 01-08-2016, 06:46 PM   #17
CurleyMerkin14
CurleyMerkin14's Avatar
CurleyMerkin14 is an unknown quantity at this point
What is the price on the GTX?
CurleyMerkin14 is offline   Reply With Quote
Old 01-08-2016, 07:42 PM   #18
alwaysnboost
alwaysnboost's Avatar
alwaysnboost is an unknown quantity at this point
Price on interior door hand cups
Left front inner door panel
alwaysnboost is offline   Reply With Quote
Old 01-08-2016, 10:20 PM   #19
fityamaha
$1200
I'll check to make sure my trim pieces are unbroken.
Which panel are you referring to on the drivers door?
Old 01-08-2016, 10:21 PM   #20
alwaysnboost
The interior door panel.
Old 01-08-2016, 10:32 PM   #21
street240sx
street240sx's Avatar
Trader Rating: (22)
street240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enoughstreet240sx will become famous soon enough
Feedback Score: 22 reviews
Awesome build, sucks that youre parting it. I cant wait til i build my ka, very similar to my setup but my engine is stock internals still
street240sx is offline   Reply With Quote
Old 01-08-2016, 11:22 PM   #22
fityamaha
Got it. $50. I'll let you know about the trim pieces.
Thank you. It is a real shame. This car is so dialed and I'm going to miss it.
Old 01-09-2016, 07:54 PM   #23
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Sending a PM
RalliartRsX is offline   Reply With Quote
Old 01-10-2016, 01:25 AM   #24
lonewanderer
lonewanderer is making a name for him/her selflonewanderer is making a name for him/her self
Price on intake manifold and fuel rail?
lonewanderer is offline   Reply With Quote
Old 01-11-2016, 03:03 PM   #25
fityamaha
PM'd
lets keep the requests rolling.
Old 01-11-2016, 03:15 PM   #26
Agent S14
Agent S14 is making a name for him/her selfAgent S14 is making a name for him/her self
how much for the ls coil setup and aeromotive fpr. would I need anything else to run it? do I need standalone?
Agent S14 is offline   Reply With Quote
Old 01-11-2016, 03:54 PM   #27
1993fdrx7
Trader Rating: (32)
1993fdrx7 is an unknown quantity at this point
id like to get those traction rods please
1993fdrx7 is offline   Reply With Quote
Old 01-11-2016, 05:33 PM   #28
1993fdrx7
Trader Rating: (32)
and maybe the brake booster. I am local and can pick up...just need more info on this miata booster mod
Old 01-11-2016, 05:45 PM   #29
dcreech0
dcreech0 is an unknown quantity at this point
Pm me price on wastegate
dcreech0 is offline   Reply With Quote
Old 01-11-2016, 06:48 PM   #30
damebash
damebash is an unknown quantity at this point
Price on radio trim, z brakes, and shifter plastic shipped to 33616? Separate price for each one to have an idea and then a combo price, please and thank you. Paypal ready. PM me
damebash is offline   Reply With Quote
