Old 12-03-2018, 08:40 PM   #1
dmitrysgarage
dmitrysgarage's Avatar
dmitrysgarage is making a name for him/her selfdmitrysgarage is making a name for him/her selfdmitrysgarage is making a name for him/her self
Damaged S15 HLSD Half Shaft
Hey guys, decided that the 240 needs an LSD and chose a HLSD from an S15 as the upgrade. Picked one up from an ebay vendor from Japan and the HLSD with half shafts got here real quick. Unfortunately it wasn't packaged well and one of the half shafts has damage. I've never worked on one of these, but looking at it I get the impression that this isn't going to work with the oil seal.
What do you guys think?
https://imgur.com/CJiMin2
dmitrysgarage is offline   Reply With Quote
Old 12-03-2018, 09:52 PM   #2
derass
I think that's just a dust cover. The seal seals against the shaft, not that. Just bend it back.
Old 12-03-2018, 10:34 PM   #3
slider2828
slider2828's Avatar
Yeah no worries... its fine. just bend it back
Turn and Burn!
Old 12-04-2018, 03:21 AM   #4
dmitrysgarage
Thanks guys, really appreciate the help. Was going to bend it back like you said, but just checked my eBay messages; I had asked the seller what he thought about running em same time I made this forum post. He wrote back saying he'd rather take care of it for me. So I'm kinda torn on that, don't wanna waste either of our time if it's not going to hurt anything.
Also I've been reviewing this install for a while and I think I got it mostly figured out, but I'd appreciate a second set of eyes. Tool wise I know i have shim drivers, feeler gauges, a dial test indicator, digital torque wrench, and a spring gauge. I've got some gear marking compound too. All that stuff should let me validate everything is dialed in. The suggested gear oil seems to be either 80W90 or 85W140 and I was thinking of using Valvoline High Performance non-synthetic stuff. I recall torsen style LSDs not liking synthetic or lsd additives, am I wrong there?
I also ordered some new oil seals, just in case they're dry rotted and I hit up enjuku for some aftermarket bushings.
Old 12-04-2018, 09:17 AM   #5
jumpman2334
jumpman2334's Avatar
jumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud ofjumpman2334 has much to be proud of
torsen style LSDs do not need any sort of additive in the oil. i dont recall hearing it would hurt the torsen if you had fluid that had additives though.
jumpman2334 is offline   Reply With Quote
Old 12-04-2018, 12:53 PM   #6
dmitrysgarage
Thanks! That's what I recalled with these type of diffs. Any idea on which oil is the right one out of the two viscosities?
Old 12-04-2018, 03:10 PM   #7
jumpman2334
no idea. dont own these cars.
if you dont get your answer here, search i can guarantee you its been covered before.
edit:
this looks like it may have your answer:
http://www.nissansilvia.com/forums/t...il-is-correct/
Old 12-04-2018, 03:46 PM   #8
dmitrysgarage
edit:
Yea I was browsing lots of posts about it and had some conflicting info hence why I wasn't sure which viscosity was right. I think the link within that link (http://www.nissansilvia.com/forums/t...es-quantities/) is probably the most comprehensive yet, so thanks again. I guess 80w90 it is then.
Old 12-04-2018, 03:53 PM   #9
slider2828
slider2828's Avatar
You need special S15 bolts to bolt the HLSD to a standard ring gear.
Did he send you those bolts? Different from S13 and S14's. That have a visible hump on them.
https://frsport.com/nismo-38102-rs50...saAq5ZEALw_wcB
Also would change your input and output shaft bearings while you at it.
Turn and Burn!
Old 12-04-2018, 04:14 PM   #10
dmitrysgarage
Good call, just ordered the bolts as they weren't included. The output shaft bearings are a good idea too. Guy says its low miles, but who really knows. Thanks for the tip!
Bolts same torque rating wise? I'm just following Nissan's FSM.
Old 12-04-2018, 10:47 PM   #11
slider2828
slider2828's Avatar
Torque is the same.
Turn and Burn!
Old 12-04-2018, 11:05 PM   #12
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
You better have a huge table vice to torque the bolts down. You meet to hold the diff with something.
Ilya is offline   Reply With Quote
Old 12-05-2018, 01:23 PM   #13
dmitrysgarage
Torque is the same.
Thanks guys!
Ilya, I do have a big table vice attached to my work bench. I figure impact to remove from from old diff and the new ones I'll use a power ratchet to get em close and then just hand torque with a torque wrench.
