Old 10-08-2008, 09:19 AM   #31
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
i am posting pics for u in a second russ.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 10-08-2008, 09:31 AM   #32
devonkyle77
here you go russ
Old 10-08-2008, 09:37 AM   #33
devonkyle77
Originally Posted by devonkyle77 View Post
the wire that bolted to that stud looks like it just goes to the negative terminal though...
when i said that, i meant the two things circled in magenta in this picture are on the same wire. i am not sure how the hell i could mess that up. there were no other wires i removed from the stud.
Old 10-08-2008, 10:28 AM   #34
projectRDM
projectRDM's Avatar
That's wrong, plain and simple.
The battery ground terminal bolts to the battery, then to the chassis anywhere you want, then to the intake manifold/head.
The positive battery terminal leaves the battery and the larger 4ga lead goes straight to the starter. The two smaller 10ga leads go inside to the fusebox, on one leg of the 100A fuse.
The stud in the fusebox goes straight to the alternator. You've got shit all mixed up. I should send you a bag of poo.
FORMERLY R240NA
Old 10-08-2008, 10:46 AM   #35
devonkyle77
ok, i think i follow.
so in the last picture, what i had circled in magenta should be bolted to the intake mani.
The positive battery terminal leaves the battery and the larger 4ga lead goes straight to the starter. The two smaller 10ga leads go inside to the fusebox, on one leg of the 100A fuse..
that part is impossible to mess up as i see it, unless the fusebox had been taken apart.
this is where i get lost. i dont see anything available that i could attach to the fusebox.
Old 10-08-2008, 10:46 AM   #36
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
How did you mixed those wires up?
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 10-08-2008, 11:06 AM   #37
devonkyle77
ok, wow. it looks like i had the wire for the fusebox on the intake mani, so i had the two backwards. so can u confirm that everything on the alternator side looks legit, so i dont have to waste another one of these damn fuses.
Old 10-08-2008, 11:35 AM   #38
projectRDM
projectRDM's Avatar
The lead coming off the alternator goes straight up to the fusebox stud. As long as you have that done right the ground doesn't matter, just bolt it to the chassis and engine somewhere, there's two lugs on it.
FORMERLY R240NA
Old 10-31-2008, 10:37 PM   #39
devonkyle77
i think this whole fiasco may have ruined my ecu. the car just cranks, no fuel or spark. seems as if everything is good, went to check ecu and it smells funny, kind of like a burnt match.
Old 01-06-2009, 10:41 PM   #40
an0therh22
an0therh22 is an unknown quantity at this point
im going through the same problem except i broke my plastic clip. i knew exactly what the problem was and fixed it but once i got back to start the car i dont hear the fuel pump turning on. have you figured it out?
an0therh22 is offline   Reply With Quote
Old 01-06-2009, 10:49 PM   #41
chelosx
chelosx's Avatar
chelosx is an unknown quantity at this point
its the fusible link!! get it from Nissan for like $20!! needs to be connected to the 100A fuse under the hood!!!
chelosx is offline   Reply With Quote
