Old 10-05-2008, 12:54 PM   #1
devonkyle77
devonkyle77's Avatar
devonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfectiondevonkyle77 is close to perfection
Send a message via AIM to devonkyle77
s14 no power to dash, windows, locks, etc HELP
so i have all but completed my s14 sr swap and i went to turn the key to the on position to check and see if lights, windows, locks, etc work and they dont.
when i turn the key back off i hear a PSSSSSSSSSSSSSSSSSS noise from the gas tank area, so i assume its pressure being released or the fuel pump. so i would assume thats getting power?
the battery is brand new, i cant figure this out, ughhhhhhhhhhh
please help guys, and as always, thanks in advance.
WTB-NARDI wheel & NRG 2.8 QR
devonkyle77 is offline   Reply With Quote
Old 10-05-2008, 01:07 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Check the main chassis fuse under the hood...
CLICK HERE!!!
Old 10-05-2008, 01:10 PM   #3
R@ddy
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
same shit happened to me!
its the fusible link...yepp
umm 18 bucks at nissan or you can get it a a junk yard wayy cheaper
R@ddy is offline   Reply With Quote
Old 10-05-2008, 01:15 PM   #4
renegade_ewok
renegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to beholdrenegade_ewok is a splendid one to behold
Check all relays/fuses - something probably popped.
Whenever I would play with wiring I ended up popping something out of stupidity (ignition fuse always got me...)
renegade_ewok is offline   Reply With Quote
Old 10-05-2008, 01:36 PM   #5
devonkyle77
sure enough, it was the 100A FL.
the only one that doesnt have a tab to push to pull it out. how the hell do i get this thing out?
Old 10-05-2008, 02:18 PM   #6
projectRDM
projectRDM's Avatar
Unbolt it, there's an M6 bolt on either side of the box inside. You can buy new fusible links that are slotted so you just have to loosen the bolts instead of removing them.
FORMERLY R240NA
Old 10-05-2008, 02:48 PM   #7
R@ddy
Trader Rating: (32)
no WTF?
i pulled mine out with my hands...hmm weird
pull harder..haha
Old 10-05-2008, 02:58 PM   #8
devonkyle77
i got it out, what a bitch that was. now if only nissan dealership parts department was open on sunday, ugh
Old 10-05-2008, 03:05 PM   #9
R@ddy
Trader Rating: (32)
you say you have a 100a fuse?
mine came with a 75a fuse...and that was $18 at nissan
im pretty sure you can start your car right?
Old 10-05-2008, 07:12 PM   #10
projectRDM
projectRDM's Avatar
S13s have a 75A main, for S14s it's 100A. Different car kid, pay attention.
FORMERLY R240NA
Old 10-05-2008, 07:18 PM   #11
fliprayzin240sx
Haha, Russ beat me to it. Anyways Devon, just in case it pops again, that usually means your alternator is fried or your wiring is fubar'd.
CLICK HERE!!!
Old 10-05-2008, 07:21 PM   #12
projectRDM
projectRDM's Avatar
True. Check for correct alternator connections, like the plastic insulator being in place on the charge lead and the charge lead/ground lead not being mixed up. Seems someone does one of those two things once a day on here.
FORMERLY R240NA
Old 10-06-2008, 03:59 PM   #13
devonkyle77
everything looks legit, but sure enough, it popped again as soon as i put the negative terminal back on the battery.
i swear i am running out of patience with this car.
Old 10-06-2008, 04:36 PM   #14
NemeGuero
No more nissan.
NemeGuero's Avatar
You're overdrawing somewhere, meaning you have a bad connection. Bust out a multimeter and the FSM and check resistances across terminals.
Its probably easier then that but I don't have much experience with it. Just be systematic in how you test.
Or you could just unplug things one at a time and keep replacing the fuse till it doesn't pop anymore. Once it stops blowing you've found what is wired improperly..
except you might run through a few fuses.
Old 10-06-2008, 04:41 PM   #15
devonkyle77
that sounds like a lot of fuses.
Old 10-06-2008, 05:07 PM   #16
projectRDM
projectRDM's Avatar
Disconnect the alternator lead and try again.
FORMERLY R240NA
Old 10-06-2008, 05:52 PM   #17
devonkyle77
i took some pics, not sure if this shows you anything
Old 10-06-2008, 07:29 PM   #18
Deftec
Deftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-knownDeftec is making his/her stupidity well-known
put the 3rd to last pic wire on a better ground.
Deftec is offline   Reply With Quote
Old 10-06-2008, 07:32 PM   #19
devonkyle77
the ground for the maf?
you really think thats the issue?
Old 10-06-2008, 08:18 PM   #20
fliprayzin240sx
I cant see pix but i'd try what russ said first. Take the alternator out of the loop since thats more than likely whats causing it to pop. Either the ground on it is fucked up or the alternator is just shorted out. Nothing on your system should be able to pop that fuse but the alternator.
CLICK HERE!!!
Old 10-06-2008, 09:20 PM   #21
projectRDM
projectRDM's Avatar
True. Anything else will just blow the smaller 75A, or lesser. Do this though before you go any further, unplug the ECU. It's highly unlikely the short will go through anything but you don't want to risk the ECU.
Disconnect the lead on the alternator, either on the charging stud or in the fusebox, it's the lead that bolts to the stud right beside the 100A fuse. Try another fuse, if it does not blow that's the culprit, the charging lead itself or the alternator.
The MAF ground has nothing to do with your problem.
FORMERLY R240NA
Old 10-07-2008, 04:02 PM   #22
devonkyle77
ok russ i think i follow
exactly what u said would happen, correct?
Old 10-07-2008, 05:41 PM   #23
projectRDM
projectRDM's Avatar
Bingo. Problem is either the charging lead is grounded to the case of the alternator or the alternator is bad.
FORMERLY R240NA
Old 10-07-2008, 05:49 PM   #24
devonkyle77
ok great. so obviously i check the charging lead first.
problem is, i dont even know what the hell a charging lead is, what it looks like, or what to do with it.
i suck.
Old 10-07-2008, 06:15 PM   #25
NemeGuero
No more nissan.
NemeGuero's Avatar
Trace that wiring. Make sure its only connecting in the 2 places it should be. Make sure your alternator has a proper ground wire on it.
DONE.
Old 10-08-2008, 01:08 AM   #26
projectRDM
projectRDM's Avatar
i suck.
You piss ass fuck. The wire that bolted to that stud goes straight to the stud on the alternator. That's the charging lead. Dammit you making me post when I'm drunk.
FORMERLY R240NA
Old 10-08-2008, 01:23 AM   #27
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
Its ok Rdm i post drunk all the time. Its just your more right then me about 100% of the time. For now.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 10-08-2008, 01:32 AM   #28
Tearlessj
Tearlessj's Avatar
I dont know if this is your problem, but it solved my issue. The big wire that goes to the alternator with the red cap on it should not be touching the alternator housing. There should be a piece of plastic in between, mine broke off during the swap and I figured it out after 3 fuses.
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 10-08-2008, 08:06 AM   #29
devonkyle77
the wire that bolted to that stud looks like it just goes to the negative terminal though...
Old 10-08-2008, 09:12 AM   #30
projectRDM
projectRDM's Avatar
Well shit man, think about what you just said. A wire coming off the positive battery lead, fused at 100A, is going to the negative terminal of the battery. How would that NOT blow?
That lead, the charging lead, the one bolted to the fusebox stud, goes directly to the plastic insulated stud on the alternator. It does not go to ground. There's a ground lead also on the alternator, it bolts behind the fusebox on the shock tower and comes off the alternator case, on the backside of it. If you have those reversed like I suggested earlier you're sending the entire 100A of current directly to ground.
FORMERLY R240NA
