Old 11-09-2011, 06:04 PM   #1
mantas
mantas's Avatar
mantas is an unknown quantity at this point
RB
Originally Posted by Slo_240sx View Post
Thanks Fred! I think an inline fill tube and cap on the upper hose should suffice.
Here is info for the AFC-80107N Radiator:
Afco #80107N Scirocco-Style Radiator...$256.95
Overall Height...13-1/4"
Tank Height...12-1/2"
Tank Width (Top)...21-1/2"
Tank Width (Bottom)...21-1/2"
Width With Flanges...25-1/2"
Tank Thickness...3"
Filler Location...None
Inlet Size and Location...1-1/4"...Right Side
Outlet Size and Location...1-1/4"...Right Side
Dry Weight...8.1 pounds
Moroso 63745 Radiator Hose Filler Inline 1 1/4"
Winning!
I'm going to slang my Altima fans and radiator to swap in this radiator + r33 clutch fan.....
mantas is offline   Reply With Quote
Old 04-05-2012, 04:34 PM   #2
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Bought this same filler as well, however, while the outer diameter may be 1.25" on everything, the thickness of the walls on the stock radiator, 16V/Scirocco radiator, and the filler all vary, thus resulting in different inner diameters.
The inner diameter of the inlet and outlet on the stock radiator is 31mm, while the 16V radiator is 28mm, and the walls on the inline filler are really thick, and so the inner diameter is only 26mm. Will it be safe to use?
Old 02-11-2012, 10:46 AM   #3
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
Originally Posted by Fred Allen Burge View Post
Here ya go, AFC-80107N from Summit. I think I'll have to run a surge tank to get it to bleed right, might get away with just putting a rad cap in the upper rad pipe but it's iffy.
Thank you!!!! This is exactly what iv'e been looking for. And its not a $400 dollar price tag like chase bays
s13_maJiK is offline   Reply With Quote
Old 11-09-2011, 01:06 AM   #4
Slo_240sx
Slo_240sx is an unknown quantity at this point
Gotta move this guy forward to fit some puller fans. Pushers aren't cutting it with a 4" intercooler and a 2.5 hot pipe behind it.
Slo_240sx is offline   Reply With Quote
Old 11-09-2011, 02:29 AM   #5
F20cS13
F20cS13's Avatar
F20cS13 is an unknown quantity at this point
Holy shittttt.....
X2 on the "civic style radiator"
RB s13 out here making 500+ ran one
Honda powered s13
F20cS13 is offline   Reply With Quote
Old 11-09-2011, 01:54 AM   #6
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
use a civic radiator
240sxvaj is offline   Reply With Quote
Old 11-09-2011, 07:21 AM   #7
EnemyS15
EnemyS15 is an unknown quantity at this point
For those who have the radiator tucked under the rad support and in front of the condenser... Does it effect the condenser at all, cooling difference since you have a thick core in front of it now? I am considering buying the chase bays rad for my RB25 in Jan.
Ps unrelated to the rad, but Cavitation is also used in terms of "air" when talking about ballistics. The formation of a cavity cause by pressure around the bullet when it penetrates the body. Had to learn that during my Paramedic course.. Just my shining moment to be that guy lol
EnemyS15 is offline   Reply With Quote
Old 11-09-2011, 06:14 PM   #8
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
No problem, glad to help out.
First person to get the Afco rad set up and running please post up with pics!
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 02-02-2012, 11:35 PM   #9
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
It will be enough to cool the motor. This rad is a dual pass and cools much better. I bought this same radiator, with your help Fred, and thought it might be small. I filled my koyo with water and emptied it into a bucket then I did the same with the Afco and the afco held maybe 4 cups less.
I am going to be using a remote fill/reservoir and should have my car running and on a dyno in the next two weeks. I have an ls1 and a greddy water temp gauge for accuracy. I will post up more info when I find out.
C. Anderson is offline   Reply With Quote
Old 11-09-2011, 06:29 PM   #10
pandaroo
pandaroo's Avatar
pandaroo is an unknown quantity at this point
has anyone on here done a rear mounted rad to move some weight back?
89 2tone coupe
2jzgte swap in progress
pandaroo is offline   Reply With Quote
Old 11-10-2011, 05:34 PM   #11
mantas
mantas's Avatar
OMFG, I think i've seen that!!!! It was on a track car in the classifieds section. The car was done like no other 240 i've seen. Can't find the thread now....
Old 11-10-2011, 07:53 PM   #12
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
I have an RB20 and I was running into cooling issues. I wanted to run the Taurus fan, but there was no way it was going to fit behind the radiator. I've been into a few accidents so I ghetto fabbed a "tube" front end.
DON'T HATE!!! LOL
karl wasabi is offline   Reply With Quote
Old 11-11-2011, 08:28 AM   #13
Fred Allen Burge
That doesn't look bad dude! Might cap off the ends of the tubes with some squares and maybe gusset the 90 degree spots for a more pro look but overall I think you pulled it off just fine.
Old 11-11-2011, 09:54 AM   #14
mantas
mantas's Avatar
Yeah i kinda dig this tube look,its got a bit of ugly and beautiful, dont know how to explain, but im sure its practical. Lol
Are you running a stock clutch fan, or is that some big electric fan?
Old 11-14-2011, 07:04 PM   #15
karl wasabi
Trader Rating: (41)
Thanks, Bardabe (from this forum) helped me out a lot with it. We literally did this the night before a ASB, so it's kind of a hack job. haha.
Mostly ugly! haha. It's a Ford Taurus fan. It's supposed to have one of the highest CFM ratings of any electric fan out there. They are running the same fan in Fredric Aasbo's TC.
Old 11-17-2011, 09:59 PM   #16
bardabe
bardabe's Avatar
Originally Posted by karl wasabi View Post
Thanks, Bardabe (from this forum) helped me out a lot with it. We literally did this the night before a ASB, so it's kind of a hack job. haha. .
it took us little over 30 minutes from start to finish it works lol
Review Thread
bardabe is offline   Reply With Quote
Old 01-18-2012, 01:18 PM   #17
mantas
mantas's Avatar
No chase bays for me
Well i've decided to cut my radiator support and try and squeeze in the clutch fan with the stock r33 radiator and shroud. I want to go this route so i can get rid of a lot of extra wires. I'm hoping to get this done this weekend or the following. When I do i'll try and keep my iPhone handy for some kind of a write up, it's overdue for us RB guys. If the stock radiator does not workout i'll make more room and squeeze in my alluminum radiator. Wish me luck! HAHA.
Old 01-23-2012, 01:15 AM   #18
mantas
mantas's Avatar
Well i cut my radiator support shoved the clutch fan in - pics tomorrow. And my problem nowis the stupid thing wont get to normal operating temperature. Went for a canyon run and nothing.....im thinking may be my car does not have a thermostat? Anyone have any ideas?
Old 01-23-2012, 12:04 PM   #19
mantas
mantas's Avatar
Probably no thermostat lol
Here she is....hack job but my next project is to clean up the engine bay (wire tuck, paint, powder coat valves etc) and then go for a tune - long overdue for that.
Old 02-05-2012, 12:15 PM   #20
mantas
mantas's Avatar
By the way guys, car runs like a champ with a z32 thermostat. Someone suggested to run a single pusher but that would be overkill. It takes me a long time to get it to normal temps. In the canyons it it took a 3hr beating and not a single problem. I just wish I would have done this mod sooner.
Old 02-11-2012, 09:37 AM   #21
C. Anderson
Its nearly done.
Old 02-02-2012, 03:12 PM   #22
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
For those who have the "tucked" radiator under the radiator support how is it working on your RB/JZ/LS car's?
I've been having some cooling issues with the 2J swap and have been considering the Chasebays or the AFCO one that was posted in this thread, but just wondering how well its working.
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 03-27-2012, 09:57 AM   #23
cole d
cole d is an unknown quantity at this point
Look up (all in fabrication) on facebook.........he's one of the original innovators of the tucked radiator craze at least in the honda world. His prices are spendy but the work is amazing. He offers a tucked radiator, ac condensor, and backdoor intercooler all packaged together be warned its pricey but the quality and workmanship are there.
cole d is offline   Reply With Quote
Old 03-12-2012, 09:28 AM   #24
Matej
Trader Rating: (39)
Sorry to bump this thread, but those of you with the Scirocco radiator, would you happen to know what thread size and pattern this plug on the bottom happens to be?
I own a different brand, and unfortunately it did not come with a plug for the temperature sensor hole.
Would it be beneficial to use a magnetic plug?
Old 03-12-2012, 12:53 PM   #25
Jus Skott
Jus Skott's Avatar
Jus Skott can only hope to improveJus Skott can only hope to improve
Send a message via AIM to Jus Skott
I'm just a cheap jew and shimmed my hood.
allows air to be thrown out over the windshield so it just stay in the bay.
Looking for yard parts, PM me.
Jus Skott is offline   Reply With Quote
Old 03-12-2012, 09:08 PM   #26
C. Anderson
My Afco was NPT. Don't know what size exactly. BTW I've been dailying the car for a couple weeks and this setup cools very well.
Old 03-27-2012, 10:06 AM   #27
cole d
Did you build the shroud for that? I installed spal pushers on my car and really wish I would have went with pullers and a tucked radiator.
Old 03-13-2012, 12:38 PM   #28
Matej
Trader Rating: (39)
Thank you, but luckily I found the plug. I almost threw it out with the packing material.
Old 03-13-2012, 03:32 PM   #29
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
Skip the fans and run a electric water pump.. You wont ever have to worry about air flow to your radiator. Its less work then having to fabricate a bracket to relocate your radiator.
PeaceOnesxWai is offline   Reply With Quote
Old 03-13-2012, 06:39 PM   #30
Sileighty_85
Sileighty_85's Avatar
Just to show ya'll You can install Fan's, Condenser and Radiator without modification to the upper core support
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
