Old 07-14-2014, 06:16 PM   #1291
Willie fisterbottom
Willie fisterbottom is an unknown quantity at this point
Do an rb25 and 26 have the same bolt pattern and will transmissions swap back and forth? Asking because of this kit http://www.atiracing.com/products/adapterk/akit.htm
It says rb26 but doesn't say rb25, which is what I have.....
Willie fisterbottom is offline   Reply With Quote
Old 07-20-2014, 10:05 PM   #1292
Sforteen
Sforteen is an unknown quantity at this point
yes they are the same
Sforteen is offline   Reply With Quote
Old 07-25-2014, 06:04 PM   #1293
Silvia479whp
Silvia479whp's Avatar
Silvia479whp is a well-known jackass
For all the drag forks out there
I have rear drag kits for s13/14/15
cars with this kits has been in the 1.18 .60 ft
Come with Afco 2 way adjustable coilvers
All of the bracket to bolt together
Text me for more info 559-210-4964
Silvia479whp is offline   Reply With Quote
Old 07-25-2014, 06:11 PM   #1294
Tom N
Tom N is an unknown quantity at this point
Can you just post up more info. May be interested for a S14
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 07-25-2014, 06:27 PM   #1295
jr_ss
Agreed. I'd like more info and installed pictures. Anything needed to be modified?
Old 07-25-2014, 06:29 PM   #1296
Silvia479whp
all of the coilvers are custom order
comes with
-Afco coilvers
-springs
-mounting brackets
Shock mounting bracket allows the shocks to moved two inches out and it allows more Tire clearence
no modification is needed it
Pm spec of ur car
power
weight
Rear end
Tire
price for kit is 1450 shipped to your doors
Old 07-25-2014, 06:36 PM   #1297
Silvia479whp
Old 07-25-2014, 06:43 PM   #1298
Tom N
Don't see anything.
Old 07-25-2014, 06:59 PM   #1299
Silvia479whp
Don't see anything.
Old 07-26-2014, 11:46 AM   #1300
unreal-
unreal- is an unknown quantity at this point
Unreal's S14 - 7/25/14 @ Atco 14.3@103
Last run of the night.
- yes i was sleeping at the light. Wanted to make sure the launch was nice. Ended up being pretty good! Spun 1st a bit.
- Boost was at ~8psi
- car was sluggish all night as my first few runs struggled to hit 100mph, ended up needing to trim the fuel map a bunch while in the pits. Was getting 10.0 AFRs for some reason.
- 60ft was 2.304 (yes it was terrible)
- extracting the log data in 4th gear into Virtual dyno gives me 238whp/250tq on Mustang Dyno Setting, Smoothing - 6.
Vdyno sheet:
https://fbcdn-sphotos-h-a.akamaihd.n...62448128_o.jpg
unreal- is offline   Reply With Quote
Old 08-03-2014, 01:55 PM   #1301
turbo-2ns
turbo-2ns is an unknown quantity at this point
have some stuff listed in the FS section that should interest the drag racing crowd
Q45 swap, holeshot wheels, custom QA1 drag coilovers
http://zilvia.net/f/showthread.php?p...82#post5693682
turbo-2ns is offline   Reply With Quote
Old 08-03-2014, 08:51 PM   #1302
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
^^^dont tell me your parting out?
2muchboost is offline   Reply With Quote
Old 08-03-2014, 09:57 PM   #1303
turbo-2ns
No this is from another"race" car that me and a budy where working on, it's going straight axle so no need for this stuff, my personal"street" car still has the q45 setup in it
Old 08-04-2014, 01:29 AM   #1304
2muchboost
Trader Rating: (33)
Glad to hear....GL with sale I will try and spread the word up here.
Old 08-04-2014, 11:55 AM   #1305
2muchboost
Trader Rating: (33)
Well boyz....shameless plug if anyone needs some MT Bias Ply
http://zilvia.net/f/showthread.php?p...03#post5694203
Old 08-13-2014, 10:09 AM   #1306
turbo-2ns
^How did the rx7 wheels fit, I'm needing to pick up something cheep the trash in the dyno
Old 08-13-2014, 10:18 AM   #1307
2muchboost
Trader Rating: (33)
The reinforced ones fit well with no issues. I then mounted them on Z32 TT wheels but now unfortunately I am staying NA so no need for the tires.
Old 08-13-2014, 03:28 PM   #1308
Briou
Briou's Avatar
Briou is an unknown quantity at this point
Man it has been way too long since I have been on here...I've been running pretty consistently in the mid 12s, with a 1.8-2.0 60'. I got my line lock installed, which has helped with burn outs and traction, now I just need to figure out how to set up the anti lag, to get me out of the hole. I have it set up with the AEM V2 ecu to where I have about 15-18psi of boost when I launch, but as soon as I come off the clutch the car falls on it's face...and then right about the 60' the power comes back in and the car starts doing some work.
So any other guys running the AEM V2 system with anti lag setup, or any anti las setup for that matter, having any success?
Briou is offline   Reply With Quote
Old 08-31-2014, 10:10 PM   #1309
silviaNC
silviaNC's Avatar
silviaNC is an unknown quantity at this point
Hi guys. I'm new to drag racing. My project is on the dyno and will.be tuned this week. . Im estimating 600hp and plan to hit the strip soon. Ive read most of the posts. Does wheel specs 15x 8, 5.5 BS with 26 x 10.5 Drag radials will be a good setup for 600? I also have Stance pro coilovers( not sure how much will hurt the car on the strip). And for last I still have the stock VLSD with stock axles. How big is the chance to blow axles at this power level? Ive been searching for j30 rear end and axles but havent had any luck at yards. Thanks for your help
silviaNC is offline   Reply With Quote
Old 08-31-2014, 11:16 PM   #1310
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
Dude. You're car needs more attention to the rear diff than some old ass j30 LSD.
It's gorgeous BTW.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 08-31-2014, 11:42 PM   #1311
silviaNC
silviaNC's Avatar
It's gorgeous BTW.
Thanks, also Ive been looking for a 97+ q45 but no luck as well.
Old 09-01-2014, 07:21 AM   #1312
Tom N
If you want to preserve some of those drivetrain parts you should go with a bias ply tire not a radial for the track.
Old 09-01-2014, 02:31 PM   #1313
silviaNC
silviaNC's Avatar
Today i hit the lottery. Local LKQ yard had a 50% disc. And happened to have a 93 q45. I snapped the diff, driver side axle and hubs for $62.
Old 09-01-2014, 04:09 PM   #1314
turbo-2ns
Good job now good luck finding the 300zx axle lol
Old 09-02-2014, 05:16 PM   #1315
silviaNC
silviaNC's Avatar
Couldnt I just use the CV joints from the q45 and transfer them to a NA z32 driver side axle? Already found a tt axle just didnt like the price lol
Old 09-02-2014, 07:45 PM   #1316
turbo-2ns
Na axles are different length from my understanding, but IV never personally tried it
Old 09-02-2014, 11:51 PM   #1317
slow92
slow92's Avatar
slow92 is an unknown quantity at this point
Ya the price for the tt axle is not going to be cheap. They are pretty rare and most aftermarket manufactures have stopped making the axles. So if you found one you should probably jump on it. Otherwise it might take you another six months to find one. I paid $230 shipped for mine.
Sr22 in the works
slow92 is offline   Reply With Quote
Old 09-03-2014, 07:29 AM   #1318
2muchboost
Trader Rating: (33)
Check out the SoCal junkyards. For some reason its like the tribal graveyard for the TT axles. I reached out to a buddy that was working down there and he found 3 for me in about a months time. They are becoming more rare so act quickly.
Old 09-03-2014, 07:36 AM   #1319
silviaNC
silviaNC's Avatar
Thanks for the info. Just bought one for $150 shipped. if its so rare couldnt let it go
Old 09-03-2014, 08:53 AM   #1320
turbo-2ns
$150 is a hell of a deal where did you find it
