#2821 |
![]() Join Date: Sep 2009
![]() Feedback Score: 23 reviews
Rebuilding some bbs rs's into track wheels.
They were 16x7.5 +30. They will be 16x9.5 +6 w/ 245/45 & 16x10 +0 w/255/50 Should have them done next month some time when the new lips come in. |
#2822 |
So… ive been going through this all and i haven't been able to find exactly what I'm looking for. I'm have a little trouble deciding on my rear tire set up…
1997, godspeed toe arms, (not sure which RUCA I'm gonna get) ive pulled my fenders in the rear and rolled them up front. i have a set of 18x9.5 RPF1 SBC +15 for all four corners. before ill be installing the wheels/tires and coilovers all at once (BS coilovers) i want to go with a 245/35 in the front, I'm pretty sure that'll fit fine and will look pretty good. out back I'm trying to decide between a 265/35 or a 275/35… i don't want to run a lot of camber, and since my rear fenders are pulled, i don't think ill have to, i also don't want bulging tires, either. if anything id like my rear to be square… |
#2823 | |
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#2824 |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Do you guys think 17x9.5 +17 with a 255/40 will be pushing it up front, on stock fenders? I am not low like some of the people on here, but I am pretty low. (about 3.5 inches from ground to frame rail)
#2825 |
![]() Join Date: Nov 2009
^I've had that, you will have to bend the fender ALOT to the point of cracking, but man does the car drive good.. and the harness has to be relocated or raised and zip tied it will rub otherwise. I also removed the inner plastic shielding.
Uuuh being slammed like that, no chances, that's retarded raise your car up. |
#2826 | |
#2827 |
![]() Join Date: May 2003
Trader Rating: (43)
![]() Feedback Score: 43 reviews
Hey guys, I've found similar setups to what I'm trying to run on this thread, but nothing exactly. Here's my setup:
Car: S14 fender modifications: F+R fenders rolled, no pull camber settings: -3 front, 0.5 rear wheel size: 17x9.5 +30 front and rear purpose: autox/track days I want to run a square setup with 255/40 all around, thoughts? Ryan |
#2829 | |
![]() ![]() But if it's all the same, I'd say pick something other than 17x9.5+30. Fitting 255's up front with that ain't for the newly initiated, IMO. The pics above literally have only millimeters of clearance and MOST coilovers would even get close to that kind of room. |
#2830 |
![]() Join Date: Sep 2004
Trader Rating: (24)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 24 reviews
Yeah, 9.5+30 prob won't clear the coil.
With a 9 +22 I run a 255 in front. My setup provides a +14mm increase in inner clearance, and 2mm less outer clearance versus a 9.5 +30. My friend Tyrone put 255s all the way around on his s14, 17x9 +22 all around: http://zilvia.net/f/cars-sale/512890...-15-300-a.html |
#2831 | |
Trader Rating: (43)
E1_griego, do you know if Tyone pulled the rear fenders at all? I can't tell from the pics he posted. Are there any issues running 17x9.5 +30 with a 255/40 tire in the rear? |
#2832 |
Trader Rating: (24)
I'm running 9.5 +33 in back of my s13 with a 255. With an s14 you shouldn't have a problem.
He didn't do a pull, just a roll, but he's running -2.5* or so in back. |
#2833 |
Trader Rating: (43)
I just picked up my track wheels today. I did a quick test fit and just like you guys said i'll need to run a 5mm spacer up front to prevent rubbing. From the looks of it I should be able to get away with a 255/40/17 setup all around but we'll see after I get the tires mounted. I'll be sure to post up pics, thanks again for everyone's help.
#2837 | |
This isn't the stretch thread, its the MAX tire thread...
#2840 |
ImageUploadedByTapatalk1368295303.565994.jpgImageUploadedByTapatalk1368295314.123114.jpgImageUploadedByTapatalk1368295326.607157.jpgImageUploadedByTapatalk1368295335.873554.jpg
Just ordered battle version RUCAs and SPC tension rods, BC coilovers just got delivered to the shop |
#2841 |
Trader Rating: (43)
^ Any reason you didn't go wider or did the +15 offset not allow it? How much camber are you running? I hope to get a meaty setup for my te37's but I need to pull my fenders. For now here's my track/autox setup:
uploadfromtaptalk1368326086833.jpg Rota p45r +30 all around + 5mm spacer to clear coils 255/40/17 all around -3 degrees camber front -1 degree camber rear Stock front fenders Rolled rear fenders I'll take better pictures when I get my meaty volk setup ![]() Sent from my DROID X2 using Tapatalk 2 Last edited by SofaKingFast; 05-11-2013 at 09:17 PM.. |
#2842 |
I'm not sure yet, haven't lowered it. I could easily run a 275, my flared fenders help, I could probably buy a 10.5 and run a 285.
I plan on running 1.5 degree out back and 2 in the front. Anyone see a problem with this? Rubbing shouldn't be an issue, I had all fenders pulled when I did body work |
#2844 |
Function! ImageUploadedByTapatalk1369191007.433481.jpgImageUploadedByTapatalk1369191019.995006.jpg
Need help on alignment. All I keep finding is drift crap. I can run 0-1 degree of camber out back but I'm not sure what is ideal. Also not sure what to put my camber and caster to up front... Daily driver, occasional road course and auto cross. Will hopefully being seeing tail of the dragon too. I also put about 70 highway miles on it everyday driving to school You guys got any ideas? |
#2848 |
Haha, i know they aren't very wide but they're what fit these wheels. Pretty meaty look though.
1995 SE Hardtop - Sold Bicycle ![]() |
#2849 | |
![]() Join Date: Jul 2004
![]() ![]() ![]() ![]() Feedback Score: 8 reviews
There are a lot of tires that'll fit that wheel, including a 245.
* PigNose SMIC Grille/Vent P# 62697-44F00 * LMK What you guys got ![]() |
