Hydro Ebrake Set Up!
I got a neal turning brake from ebay. cut it in half for a hydro e brake...
I need a 1 way valve to install in line between hand brake and master... for a s13 of course...any help? I googled it... call every parts place in my neck of the woods! I know there has got to be a 1 way valve to toss in line, I CANT FIND! IT! EDIT! A 1 way checked valve! Last edited by sillyvia13; 06-15-2008 at 10:15 AM.. Reason: ........... |
#6 |
![]() Join Date: May 2007
I know Powered By Max offers a Hydraulic[sp?] Handbrake.
Join theyre site and go to the forums. www.poweredbymax.net
#7 |
I already have it in car...
I will see what I can do... It will be same as CNC but just hill billy rigged i guess... need a ball and spring style 1 way check valve up in this mother!!!!!!!!!!!!! |
#8 |
![]() Join Date: Sep 2003
luke did a write up and install deal a few years back on hydraulic handbrake.. might want to search it out... it was very easy setup to do and not too costly...
S14 TrackSlut coming to a raceway near you... 510 TimeAttack on its way... |
#9 |
any one...
I will pay you!!!!!!!!!!! I have it all installed... I would think it had a valve in it... maybe the other side was the part valved? I should swap it to that one...FUK!!!!!! I hate being cheap sometimes... not really. |
#10 | |
lol at putting one way valve in your brake lines smoooooth. |
#11 | |
![]() Join Date: Dec 2006
If you put a one way valve in that system then once you pressurize that line and it flows past the check valve for that line it will stay pressurized cuz of the check valve unless you have a relief valve installed after the check valve
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#12 |
yeah you cant really plumb the system up like that. if your using a regular brake cylinder on hydro handbrake, then you need secondary e-brake caliper.
if you want to use it with the existing brake, then you need a slave cylinder from a staging brake, so that you can plumb it inline with the existing rear brakes. |
#13 | |
you helped alot...thanks. you guys are such wiseass's use your head...You think that wasnt thought off... DO NOT POST IF YOUR AN ARSE HOLE! with nothing but shit to lay down. a neal turnoing brake was used... A CNC! brake. but it was cut in half and now I have 2! it should have bolted in and been fine!? dunno tho! I was gonna run dual calipers BUT I can get a new cnc brake for 99 I got the setup I have for like 50 so 2 for 50!? well see... I am stubborn and will make it happen. |
#14 |
can you throw up a picture of the setup you have....i think it would aid in coming up with a good solution.
your problem sounds similar to what i ended up with. i just found a different cylinder to bolt to the cnc brake frame, by far the easiest solution i could come up with...im always kinda weary of ghetto rigging rigging brake stuff cause you have to trust it to stop your car later. |
#15 | |
I think I bought a bad hand brake from EBAY!!!!! no? It is leaking internally... I am gonna take it apart and replace the seals...see how it goes... It has to have a 1 way check valve internally...or it wouldnt work...I guess the seal is gone and was leaking back into master...now that its in car and has sat for a few days I can see a small bit of fluid on the base of cylinder... oh well, live and learn...this time being cheap took longer, but well worth it if I EVER GET ER! DONE! ![]() |
#16 | |
![]() Join Date: Aug 2006
![]() ![]() ![]() Feedback Score: 1 reviews
#17 | |
stop cutting up whatever peice of shit brake you bought. buy the hand brake from driftworks or get a K-sport and put a wilwood master in it. done. not rocket science. |
#18 |
there is no way to use a one way valve to plumb in a second master cylinder.
the leaking fluid you saw was from leaving the lines pressurized, eventually it will leak back past the seals, master cylinders are only designed to hold pressure for a certain period of time |
