Wiper Fuse Keeps Blowing.. Please HEEEELLLPPP..
Ok so as the title states the Wiper Fuse feeps blowing in my '91 240SX.. I already replaced the fuses (A few times) and I even replaced the actual Wiper Motor which seemed to work for the drive home but not this morning.
I'm stuck and it's raining pretty hard over here in the 818, so if anyone can please help me out I'd appreciate it very much. Thank you
Zombi_Army... Coming Soon |
#7 |
yea ok hes gonna do a pull test in the middle of rain with probably no equipment for it. its most likely a short, it could be a motor thats shorted out or maybe even your wiper switch or all the wire that runs from under the steering wheel column to the motor if you really need to get em working and if you wanna risk it you can by pass the fuse and just get a paper clip and put it in place of the fuse it will work, also check what amperage fuse your using because it might not be the correct resistance and thats why it keeps blowing out
#9 | |
After you've downloaded the FSM, go to the Body / Wiring section in the FSM and follow the instructions on how to troubleshoot your electrical short problem. You'll need a voltmeter / continuity tester to test the windshield wiper switch, your ground wires and the wiring between the motor & the switch. You should be able to figure out where your problem is and fix it. It's just going to take you time to isolate the problem. If you're not familiar with troubleshooting electrical problems, then you'll have to take your car in to a mechanic or automotive wiring specialist. Anyhow, hope this helps....Good luck!! ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... ![]() |
#11 | |
Unless you want to COMPLETELY fry your wiring harness and catch your car on fire, I would strongly recommend you NOT do this!!! ![]() ![]() ![]() ID
#12 | |
![]() Join Date: Apr 2004
Most likely you have a faulty ground, or a short in the left front fender harness. Check those two first and look for broken wires. A broken wiper motor would not break the fuse unless there is a short in the ground wire. |
