Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Drivetrain
Old 04-02-2014, 06:12 PM   #1
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
JZ to VQ/350z/G35 transmission adapters!!!!
Introducing the Maverick Motorsports JZ/VQ 6 speed Adapter Kit!
This kit allows you to easily bolt on a stronger, better shifting, and cheaper 350z/370z/g35/g37 6 speed transmission to ANY JZ engine.
Similar to our other kits, we provide a CNC cut, CAD designed adapter plate made from 6061-T6 aluminum. We also include a pilot bearing sleeve to adapt the Nissan pilot bearing in the JZ crank. Additionally we include all the hardware needed(engine bolts, transmission bolts, and flywheel bolts).
The other crucial part of the swap is the custom flywheel made specifically for this swap kit. It is an aluminum 6061-T6 billet machined flywheel with a replaceable friction surface. At 14lbs, it is HALF of the weight of an OEM flywheel.
Best of all, any single plate 350z clutch will bolt right up to it. You are free to choose any clutch manufacturer that makes a kit for a 350z. Holding capacities of 740tq+ available from clutch makers! We also have a 1000tq+ twin disc option as well.
As with our other kits you will still need:
-Bellhousing machining($80)
-Shifter bracket relocation($125)
-Custom Transmission mount(we offer s-chassis ones, $100)
-Clutch line
-Driveshaft
All adapter plates are Laser scanned, CAD designed, CNC machined and real world tested. All scanning and machining is done in an ISO9001:2008 certified machine shop who specializes in MilSpec/Aerospace/Medical machining.
If you previously used one of my SR/KA kits all you need is the adapter and flywheel. The bellhousing mod and shifter mod are identical. It saves you money from doing the work twice!
Please contact [email protected] for further details.
Thank you!
George
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 04-03-2014, 06:22 AM   #2
Cronus577
Cronus577's Avatar
Cronus577 is an unknown quantity at this point
WHOA! Do want. This is awesome!
Cronus577 is offline   Reply With Quote
Old 04-03-2014, 06:36 AM   #3
BooStedS13SleePeR
BooStedS13SleePeR is an unknown quantity at this point
Send a message via AIM to BooStedS13SleePeR
This is fucking incredible. PM sent!
BooStedS13SleePeR is offline   Reply With Quote
Old 04-03-2014, 07:47 AM   #4
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
How about an LS to VQ adapter?
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 04-03-2014, 09:22 AM   #5
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Very cool, Good job guys!
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 04-03-2014, 09:59 AM   #6
maverickmotorsports
Didn't see a PM yet. I checked my inbox and it has room. Try re-sending.
Actually working on that one next.
Thank you!
-George Marstanovic
Old 04-03-2014, 02:16 PM   #7
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
this is stupid y would u want a weaker trans then what u can already get for a ls1 bolt on
a jz with a t56 would be amazing
Old 04-03-2014, 02:48 PM   #8
dudermagee
dudermagee's Avatar
Only the pre-2005's were crap.They have some big powered Z cars running stock transmissions.One is a 1200hp drag car.Oh and VQ transmissions are like 1/3 the price of a T56.
Old 04-03-2014, 04:31 PM   #9
ehp
ehp is an unknown quantity at this point
correct me if im wrong but arent r154s stronger than the vq trans? savin for a possible a jz swap
follow my build on instagram: s14project
ehp is offline   Reply With Quote
Old 04-03-2014, 05:25 PM   #10
blueshark123
Trader Rating: (55)
1/3 price doesnt mean much. t56 is 1500 lets say on the higher side. a 350z trans 350-600+ especially more if u get the cd009 trans which is the better one since the 2003-2005 suck ass. This conversion is 1k + u need to machine bell housing and need a custom mount driveshaft etc granted u still need those 2 in a ls swap but still probably cost more. in the end u have a inferior trans that cost more.
The cost to rebuild a t56 is cheap and would hold high hp.
Old 04-03-2014, 06:01 PM   #11
NNOCENT
NNOCENT is an unknown quantity at this point
will we be able to use our current Spec carbon twin disc, or our Carbonetics carbon triple disc ?
clutches were ~ 5k for both, really hoping your answer is YES
NNOCENT is offline   Reply With Quote
Old 04-04-2014, 06:38 PM   #12
s13mikesr20
s13mikesr20 is an unknown quantity at this point
im running a w58 but
its on a spec super twin disk clutch and i have a cd009 trans with external push type slave
im wondering if i find a special throwout bearing and i run this kit would i be ok
with using the flywheel and clutch setup for a 2jz thanks
s13mikesr20 is offline   Reply With Quote
Old 04-06-2014, 12:47 AM   #13
240sxvaj
Trader Rating: (38)
240sxvaj is an unknown quantity at this point
Feedback Score: 38 reviews
George
Stronger than a Getrag V160? Please elaborate.
240sxvaj is offline   Reply With Quote
Old 04-06-2014, 09:09 PM   #14
FutureFab
Trader Rating: (32)
FutureFab is an unknown quantity at this point
Feedback Score: 32 reviews
This is a great product! I have seen it installed on a 2j. It will be in my next trans setup for sure!
futurefabrication.com
FutureFab is offline   Reply With Quote
Old 04-07-2014, 11:07 PM   #15
bova17
bova17's Avatar
bova17 is an unknown quantity at this point
I love cmc parts, probably best solution for 2jz with a 6 speed
bova17 is offline   Reply With Quote
Old 04-13-2014, 11:35 AM   #16
Got13oost
Got13oost is an unknown quantity at this point
Kit for a 350z TRANS to a sr20 ship to 07032, thanks!
Got13oost is offline   Reply With Quote
Old 04-30-2014, 10:46 PM   #17
crewchief05
crewchief05 is an unknown quantity at this point
pmd u!…...
crewchief05 is offline   Reply With Quote
Old 06-12-2014, 10:28 AM   #18
JohanM
JohanM's Avatar
JohanM is an unknown quantity at this point
send you an email...
JohanM is offline   Reply With Quote
Old 09-28-2014, 10:08 PM   #19
turbob16ef
turbob16ef's Avatar
turbob16ef is an unknown quantity at this point
How much for complete 2j/350z with twin disc, trans mount?
Shipped to 29906
And do you guys off driveshafts?
turbob16ef is offline   Reply With Quote
Old 07-23-2015, 09:48 AM   #20
NOLAGG
NOLAGG's Avatar
NOLAGG is an unknown quantity at this point
This died out quick huh? Any one running one?
NOLAGG is offline   Reply With Quote
Old 07-23-2015, 10:08 AM   #21
TheRealSy90
TheRealSy90's Avatar
Not really died out, everyone just orders through his website.
Such a good signature.
Old 07-23-2015, 10:10 AM   #22
NOLAGG
NOLAGG's Avatar
Do you have the kit can you tell me how it worked out? Thanks in advance
Old 07-23-2015, 12:19 PM   #23
bova17
bova17's Avatar
He has since changed the design so there is no need to mill the bellhousing now. I should be ordering one soon!!
Old 07-23-2015, 12:39 PM   #24
NOLAGG
NOLAGG's Avatar
I think collins adaptor is better solution. Better grade materiel, cheaper price, plus they were the first to do it ands supposedly have a Patten on it.they also have studs welded " the plate so it's easier to remove the starter with out doing the whole trans.
Old 07-23-2015, 12:59 PM   #25
TheRealSy90
Seems like every time I see somebody use a collins kit, there's problems with the clutch release and they have to ship parts back and forth multiple times until they find the right combination of parts.
Old 07-23-2015, 01:15 PM   #26
NOLAGG
NOLAGG's Avatar
Really? Where did you see that?
Old 07-23-2015, 01:42 PM   #27
TheRealSy90
A couple threads with people using the collins z33 to sr20 kits. Maybe they have their jz kit all in order though.
