11-04-2011, 05:34 PM | #331 | |
Trader Rating: (38)
Feedback Score: 38 reviews
Going with 215/40 won't change much, if anything you'll be rubbing a hell of a lot more. And getting a bigger sidewall (45 series) is going to be worse + isn't going to fool anybody. Either way you will need to adjust the coils/fenders in accordance. But to answer your questions, you'll want to try to go lower but since you've got collars removed. I would suggest getting better coilovers. |
11-04-2011, 07:17 PM | #332 |
id like to change the tire in the front to be a little more flush and the rears rub a little and if i add more camber then i start adding toe and it wears my tires so id rather get a smaller tire. dont want to pull the fender though so maybe smaller tire and lil less camber
11-04-2011, 07:48 PM | #333 |
I have a question about Front fitment on a S14...From what I read I understand you can have up to a 10" wheel up front, but depending on the offset you may not be able to go full lock turn to turn because of hitting the wheel well.
Any body know what the lowest offset on a 10" wide wheel would be and still go full lock turn to turn? Thanks |
11-04-2011, 11:25 PM | #335 | |
Trader Rating: (22)
Feedback Score: 22 reviews
Enkei RPF-1 F.17x9.5 +18 / R.17x10 +18 Roll+Pull a little all around. F-225/45/17 and R-255/40/17. Gonna get 215/40 for the front so i can pull a little camber out. Here's a picture i snap at work. Sorry for the quality. lol |
11-05-2011, 01:40 AM | #336 |
11-05-2011, 05:29 AM | #337 |
Can you adjust the camber on an S14 with all stock suspension parts except coilovers installed? If so, how much?
I currently have 18x10 +10 in the rears wrapped in 235/40. The wheel is poking out and I'm trying to tuck tire, but I need more neg. camber. No funds for aftermarket camber kits, rucas, toe, arms, etc. for now. |
11-05-2011, 09:21 AM | #338 | |||
Trader Rating: (38)
If you get the a good set of adjustable arms, you can zero out or get close to zero toe. Quote:
http://zilvia.net/f/chat/169628-pic-...hotoshops.html or google. Quote:
11-05-2011, 01:19 PM | #339 | |
Hmmmm I guess I'll do some more research. Thanks anyways. |
11-05-2011, 01:25 PM | #340 |
11-05-2011, 01:26 PM | #341 | |
Trader Rating: (38)
According to that search, +18 is biggest offset there. If your question is what's the smallest offset to fit in full lock on stock body/stock wheel wells, then it looks like +7 could work. As shown here (Knoop's old set up) If you look on rimtuck, there's a lot of set ups that go into the negative offset range on stock fender pulls. But with wheels that wide, you may need to tub the wheel wells |
11-05-2011, 01:39 PM | #342 |
Cool thanks! Yes this is what I meant, what is the lowest/smallest offset to run on a 10" wheel w/o needing tubs.
Have another question then....for the people who are running WIDE FRONT FENDERS, 30mm/40mm or whatever (and who's wheel is flush with the fenders) can NOT go full lock? Or am I missing something? Even if they run 9" wheel and use spacer to push the wheel out will still be in trouble hitting the Fender well, right? Just trying to figure out a set-up. |
11-05-2011, 02:23 PM | #343 |
I was drifting with the 10 +7s up front with 245/40s and just a roll. I beat the shit out of the inner wheel well with a sledge hammer to keep it from rubbing. You wont be able to even run a 9 +5 with 215/45 without beating out your inner wheel well with a hammer.
I should note with the 10 +7s I had stock knuckles and tien tie rods with spacers, any more angle then that and you'd probably have issues.
Instagram - SJKnoop |
11-05-2011, 03:39 PM | #344 | |
Im figuring out my next wheel set-up for my track car and would like to be able to turn full lock. I am running the same se-up as you, stock knuckles and Tein tie rods w/ spacers. But it seems like the set-up I want...10J +0 (or less) I will definitely be needing tubs. Thanks again for the help! |
11-06-2011, 01:16 PM | #345 |
Thinking about picking up some SP1s, but I'm looking for some opinions.
Details: 1991 S13, 5 lug, Front and Rear Z32 brakes. Stance GR+Pro coils. I'm looking to achieve something along the lines of Damon's old setup: 17x9 +12 F/R 225/45 245/40 I want less stretch in the front and 17x10 in the rear, more like Jimmytang's rear fitment, not as low, less poke, less camber, and with a wider tire, more like Broadfield's old setup. 17x10+8(effective) 245/40 18x10 +44 275/ The choices: So, I'm looking for a medium between wheel whore/maximum rubber. Do either of these sound like they'd work? (For a ride height simular to Broadfields old setup) Front:17x9 +11 (NR) 235/40 Rear: 17x10 +24 (SL) 255/40 or Front: 17x9 +11(NR) 235/40 Rear: 17x9 +11 (SL) 255/40 Is 17x10+24 in the rear too high of an offset for coilovers? I don't know if the (SL) disk would clear my z32 rears.. any experience? |
11-06-2011, 03:28 PM | #346 |
Man w/ CTSV & a Car Seat
I'd go with the 17x10 +24, 255/40 will fit perfectly fine with an S13 with just rolling the fender. I think it would be perfect if you're not looking for a stretched/poked look.
11-06-2011, 05:04 PM | #347 | |
If you look close in this picture you can see a slight black mark on the fender. That fender was spray painted so the rubber stuck to it. The side with OEM paint was fine.
11-06-2011, 08:40 PM | #348 | |
i run 17x10 +15 wheels all round on my s14. bit of a hammer in the few places it rubbed and all good 235/40 front and pretty low had to throw a 5mm spacer in there when i got knuckles to avoid hitting the inner edge by chassias rail if you go lower offset it is more likely to hit up top so depends on ride height & tire etc really bad pic to show anything but im too lazy to search for better |
11-07-2011, 04:03 PM | #349 |
looking for suggestions for my coupe for offset and tire size. going to run 20mm front fenders and 30mm rear overs. Will probably be doing a 17" wheel, maybe 18". What offsets/tires sizes do you guys suggest. looking to maybe run a staggered setup with a bit of a lip in the back. Thanks
11-09-2011, 09:45 AM | #350 |
hey everyone im think about buyin 5zigen fn01r-c 17X10.0 + 12, all around, wat do i need to do fit them on s13,do im have problem fittin 17x10 in the front. wat kind a camber need to do. tires stretch an how much of a roll or full, do i need hit anywhere inside the wheel while in the front
11-09-2011, 09:51 AM | #351 | |
Trader Rating: (38)
Yes, 10" can fit on S13. You will need a lot of hammer work for the wheel wells if you don't tub your fenders. The word is camber not chamber. Camber is dependent on your fender clearance (stock or aftermarket) or lack thereof. You will need a roll & pull at the very least. For tire sizes, it depends on how low your car will be. If the car is low, the kind of stretch you will need is 225/40 all around. |
11-09-2011, 10:11 AM | #352 | |
11-09-2011, 11:11 AM | #353 | |
Trader Rating: (38)
Hammer work = slam your car on any set of wheels, remove your fender liner, tuck your harness & look at what rubs & what could rub. Get to work with your hammer. Hammer work. |
11-09-2011, 12:30 PM | #355 | |
opps mybad u guys. well thanks for all the info an the help. next time ill read over it again. but do u guys think i should go with 25mm fenders to clear the front rims. plus i have 300zx calipers in front.
11-10-2011, 05:26 PM | #356 | |
11-10-2011, 11:01 PM | #359 |
Will I need to run spacers? If so what size? 17x9.5 +15 "battles" on an s14zenki with 30mm rear over fenders. Tires are 235/40. I want wheels to sit flush. Thanks in advance. Also any pics of Zenki w/ 17in battles would be great, thanks again.
RELAX BITCHES-IT'S THE FUCKIN INTERNET |
