Old 02-10-2014, 11:15 PM   #2941
Fuego
Fuego is an unknown quantity at this point
I mean the fronts could be wider but the rears look spot on to me. Pulling too far can start to look sloppy, but if you want to go that route, I'd say bring them down an inch and keep it all clean.
Fuego is offline   Reply With Quote
Old 02-11-2014, 01:07 AM   #2942
NHTKID
NHTKID is an unknown quantity at this point
I just recently installed some work emotion 11r's that are 18x9.5 +30 upfront on my s13 with a 225/40.i have tein super drifts and I'm using a 15mm bolt on spacer and have tucked my harness and hammered my wheel wells lip ect. But I rub my fenders when i turn and hit bumps so im a little too low for this tire but it looks nice where its at. I used to run an 18x9 +22 with a 10mm spacer up front on a 215/35 and didn't have any rubbing issues what so ever. Would switching to a 225/35 remedy the rubbing situation with the new wheels while still being able to be low? Or should I go to a 215/40? If I need to post pics I will.. I'm thinking 225/35 on the new fronts. any advice or examples of te above setup pointing me in the right direction would be greatly appreciated. Thank you.
Please disregard any spelling mistakes. Autocorrect sucks.
NHTKID is offline   Reply With Quote
Old 02-14-2014, 03:38 PM   #2943
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
so if i want mad fitment like this kouki im sure we've all seen http://www.flickr.com/photos/keemay/...n/photostream/ what spacers and tire specs do you have to run? been looking for a while and really havent been able to find much info.
vJilly is offline   Reply With Quote
Old 02-15-2014, 03:53 PM   #2944
pablooo
pablooo is an unknown quantity at this point
im looking for the right amount of camber without going overboard ive searched far and wide.
i would like to fit 17x10 +25 in the rear of my hatch on a 235/40 (yes, done plenty of times before, not my problem) but i want to pass on a pull for now so i can properly fit my 18 later on with aero, no questions asked.
so yes rolled rears are a done deal, but exactly how much camber to tuck a little bit of tire safely (again with no pull) without my rears cambered out like a halfpipe, and stance not 4x4ing....dont mind a bit of spacer which ill probably deal with to fit perfect
pablooo is offline   Reply With Quote
Old 02-15-2014, 05:01 PM   #2945
DRFTSAINT
DRFTSAINT's Avatar
DRFTSAINT is on the path to ruinDRFTSAINT is on the path to ruinDRFTSAINT is on the path to ruin
I am looking to possibly run Enkei Compe's on my daily S13, I am wanting to keep the size at or under 16" and preferably 8" wide. My question is does anyone know if they clear Q45 front brakes (I have fortune coils and only mildly lowered)? The available offsets are 0 and +25, which would be easier to fit without much effort? Thanks for the help...
DRFTSAINT is offline   Reply With Quote
Old 02-16-2014, 12:24 PM   #2946
tiggertsi
tiggertsi is an unknown quantity at this point
i am actually considering getting some 350z anniversary's myself. key word there is "considering". from what i have read so far most likely spacers will not be needed to fit the wheels. as far as how low the kouki is in that and what is needed to go that route i dunno. i personally am not planning on being that low. that kouki looks very clean and mean tho.
if you haven't already i'd look through this oem wheel thread here ....
http://zilvia.net/f/showthread.php?t...ght=350z+wheel
and here is another good one offsite ....
http://forums.nicoclub.com/updated-z...2-t359514.html
also i have been google searching 350z wheels on 240sx/s14 for a while now. there are numerous threads and pics of the combo all over. the above two threads will get you started, i've looked through every page on those threads. good stuff. this guy here mentioned that he got spacers for "better" fitment, or i guess for better flush fitment. http://zilvia.net/f/showpost.php?p=5...&postcount=313 which i care little for in particular. i must be too old or something.
Originally Posted by wurley View Post
that would make 18x9.5 +19. the same specs as in this pic.. i was bored of it after 2 weeks...
bored with it? i think that looks absolutely amazing. except for the stretched tires. but again i must be too old.
66 Plymouth Satellite, 96 Nissan 240sx, 03 Harley Sportster. Toys!
tiggertsi is offline   Reply With Quote
Old 02-17-2014, 12:25 AM   #2947
wurley
wurley's Avatar
wurley is an unknown quantity at this point
27 and 32mm spacers, not sure which are on the fronts or back. Tire sidewall is 35. not sure about the width, i'm guessing 205 front and 215 back? If your not going that low i would run 40 or 45 sidewall, you have to go low with 35 to have it look good.
I also know it has stance gr+ coils. If your going that low you would also have to relocated the wiring in the drivers fender well.
Originally Posted by tiggertsi View Post
This guy here mentioned that he got spacers for "better" fitment, or i guess for better flush fitment. http://zilvia.net/f/showpost.php?p=5...&postcount=313 which i care little for in particular. i must be too old or something.
This might not be the thread for you.
wurley is offline   Reply With Quote
Old 02-17-2014, 12:31 AM   #2948
ednakline
ednakline is an unknown quantity at this point
well, thanks for sharing anyway
skiing tours in nz
ednakline is offline   Reply With Quote
Old 02-19-2014, 08:15 PM   #2949
tysan
tysan's Avatar
tysan is an unknown quantity at this point
I just had my set of rims come in today. However, haven't put them on the car yet. I want the lip to sit as close to flush with fender as possible and have the car lowered with the fender about half inch over the tire. The sizes are 8.5" +25 and 10" +25. Tires are 215/40Fr and 235 or maybe 245 in the Rear (Don't have the rear tires yet until I get a little more information). My question is what size spacers should I get and are 235's too small for a 10" or should I go with 245"s. Thx in advance for the reply's.
tysan is offline   Reply With Quote
Old 02-19-2014, 08:45 PM   #2950
jalgo3
jalgo3 is an unknown quantity at this point
help with fitment
Will a 15x10 -45 offset fit on a s14 zenki
jalgo3 is offline   Reply With Quote
Old 02-19-2014, 09:54 PM   #2951
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
A 225/35 would only make the tire shorter, a 215/40 could fix that but idk if you want to run a stretch.
You can do a 225/35 and slap on the 10mm spacers instead and be fine. I'd try the 10mm spacers with your current tire size and see if it still rubs, those 5mm can make a big difference . Also depending on how much camber your running you can add more and solve your rubbing issue with your 225/40 15mm spacer combo.
Dudes voice makes my arm feel punchy.
da_crew10 is offline   Reply With Quote
Old 02-22-2014, 05:45 AM   #2952
Zenki_Kouki.5
Zenki_Kouki.5 is an unknown quantity at this point
any fitment pics of 17x9 +30 bbs lm . on a s14? i searched but I couldn't find any.
Zenki_Kouki.5 is offline   Reply With Quote
Old 02-22-2014, 07:56 PM   #2953
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You probably wont find that specific rim but you can look up matching fitments. Look up S14s with R33 GTR wheels. Those wheels are the same exact specs as those LMs. Might need 5mm spacers up front to clear certain suspensions.
CLICK HERE!!!
Old 02-24-2014, 09:11 PM   #2954
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
So.... 18x9.5j-13et.... can I pull it off on the front of my S14 with stock metal? Aiming for 225/40/18 tires as well. My previous set up was 17x9j-3et with 225/45/17 tires.
From my understanding, I should have 4mm more clearance on the inside, and the wheel should be out an extra 16mm.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 02-28-2014, 11:44 AM   #2955
da_crew10
da_crew10's Avatar
I have a problem with my rear camber. I have Parts Shop Max rucas and to rods, one side is more maxed than the other. The side that is maxed out leaves the wheel at almost 0 camber. The other leaves it negative around almost 3 degree. Any guesses?
Old 03-01-2014, 07:34 PM   #2956
imoverherre
imoverherre's Avatar
imoverherre is an unknown quantity at this point
To start off I'm just learning about this whole wheel fitment stuff. So excuse me noob-ness.
I'm looking to buy some wheels that are 18x8.5 +35 F and and 18x9.5 +45 R
What tires size would be good to run on a stock body coupe, would it even fit? If would help if anybody as a picture running that size.
imoverherre is offline   Reply With Quote
Old 03-02-2014, 09:02 AM   #2957
bikrman2
bikrman2's Avatar
bikrman2 is an unknown quantity at this point
Send a message via AIM to bikrman2
Hoping you guys can help me out a bit. I'm getting new wheels and have a choice first is 17x10+20 front and 18x11+20 rear. The other option is 17x9+10 front and 18x10.5+20 rear. Car is an s13 hatch with 20mm front overs and currently rolled and pulled rears. I also want to do overs on the rear buy I'm unsure what overs to run with said wheel options. As far as tire size I'm planning on 225/40/18 in back but unsure of front ?
Originally Posted by wangan_cruiser View Post
if you dont have any valuable information GTFO.
bikrman2 is offline   Reply With Quote
Old 03-02-2014, 07:40 PM   #2958
fliprayzin240sx
17x10 +20 will be hit or miss up front. May or may not hit your strut/coilover. Rears, if you're gonna go 11j, go wide fenders and go wide tires. 265s would look stretched on 11js. 225/40 on the 11s and you'd be pissing to die. My suggestion is get the 11js, slap some 265s on it, get some typical 50mm fenders (origin or chargespeed), mount the wheels, get them alignment 0 camber/toe, then use the wheels are a reference to mount the fenders (bow them in or out).
CLICK HERE!!!
Old 03-02-2014, 07:45 PM   #2959
fliprayzin240sx
Get something else. If you're gonna get those width, shoot for atleast low 20s offset down to +12.
CLICK HERE!!!
Old 03-02-2014, 08:06 PM   #2960
tauntdevil
tauntdevil's Avatar
tauntdevil is a well-known jackass
So I wont get into math here, but a very very close wheel to strut gap size for the backspacing on a rim is 5.25 inches. Hope that helps.
S14 KA NA two cylinders, 75whp limper
tauntdevil is offline   Reply With Quote
Old 03-02-2014, 08:11 PM   #2961
fliprayzin240sx
You checked to see if the traction rod is binding if its stock and you're slammed?
CLICK HERE!!!
Old 03-03-2014, 06:30 AM   #2962
bikrman2
bikrman2's Avatar
So best bet would be to go with the 17x9 up front. And a much wider tire. In back. Would it make much of a difference to run an 18x9 up front?
Old 03-03-2014, 10:29 AM   #2963
da_crew10
da_crew10's Avatar
Elaborate please?
This is the only suspension item I did not change, just changed the bushing out on it. Never really understood what the traction rod actually did.
I am really low, should I buy an adjustable one?
Old 03-03-2014, 10:47 AM   #2964
bikrman2
bikrman2's Avatar
Elaborate please?
Adjustable reaction rods are for caster adjustment. For a slammed car I personally would change them out for the adjustable ones for the sheer ability to get alignment right
Old 03-03-2014, 10:52 AM   #2965
simmode1
simmode1's Avatar
OMG please do this. This is exactly what I was planning to do when I trade my S14 for another hatch. The 17x10+20 will probably need a samll slip-on spacer to clear most coilovers. 7mm should do the job. 235/40/17 up front and 265/35/18 on the rear 18x11+20's would create the perfect 1 inch wheel/tire stagger from front to rear. Having front offset lower than the rears is a bit odd to me, so I'd probably recommend running 7mm slip-on spacers all around. I defer to Flip on what rear overs to get though...Let me guess... 531's?
Old 03-03-2014, 10:53 AM   #2966
bikrman2
bikrman2's Avatar
I was thinking those or the cosmis mr2
Old 03-03-2014, 11:00 AM   #2967
simmode1
simmode1's Avatar
Yeah, Cosmis are giving us some very nice yet inexpensive & legit options. But XXR is stay relevant with their sizes & pricing. GL man!
Old 03-03-2014, 11:05 AM   #2968
bikrman2
bikrman2's Avatar
Yep cosmis is in the same range price wise as the rpf1.
Old 03-03-2014, 11:44 AM   #2969
simmode1
simmode1's Avatar
^^^I do wanna mention though: It is possible to fit those 18x11's under stock rears with 265/35 rubber, but You might not like the amount of pulling & negative camber required.
Old 03-03-2014, 11:46 AM   #2970
bikrman2
bikrman2's Avatar
Wheel Fitment Question Thread
It's the camber that would bother me. Plus previous owner creamed the passenger side quarter
